# Use jquery in template node (not datshboard)
**URL:** <https://discourse.nodered.org/t/use-jquery-in-template-node-not-datshboard/62564>\
**Created:** [12 May 2022 16:17 UTC](https://discourse.nodered.org/t/use-jquery-in-template-node-not-datshboard/62564 "2022-05-12T16:17:30Z")\
**Author:** ![jbudd](https://avatars.discourse-cdn.com/v4/letter/j/5f8ce5/32.png) [@jbudd](https://discourse.nodered.org/u/jbudd)\
**Post date:** [13 May 2022 15:42 UTC](https://discourse.nodered.org/t/use-jquery-in-template-node-not-datshboard/62564/4 "2022-05-13T15:42:28Z")
Your URL is wrong.
If your settings.js file contains `httpStatic: '/home/pi/JQuery/',`
And you have restarted Node-red after editing it,
And that directory contains 123.png:
Then you should be able to see the image at `<IP Address>:1880/123.png`
I don't know if `cproject.arc` rather than IP address makes a difference.
_[View the full topic](https://discourse.nodered.org/t/use-jquery-in-template-node-not-datshboard/62564)._
