# Use vcgencmd within a docker node-red container
**URL:** <https://discourse.nodered.org/t/use-vcgencmd-within-a-docker-node-red-container/23050>\
**Created:** [12 March 2020 20:58 UTC](https://discourse.nodered.org/t/use-vcgencmd-within-a-docker-node-red-container/23050 "2020-03-12T20:58:36Z")\
**Showing post:** 16
**Author:** ![mikeS7](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/mikes7/32/2026_2.png) [@mikeS7](https://discourse.nodered.org/u/mikeS7)\
**Post date:** [14 March 2020 17:29 UTC](https://discourse.nodered.org/t/use-vcgencmd-within-a-docker-node-red-container/23050/16 "2020-03-14T17:29:24Z")
@DannyBoyKN
You have different Linux distributions in a host and in a container.
You should build your own image, in your case Dockerfile will looks like:
FROM ctmagazin/ctnodered:latest
RUN apk add --no-cache raspberrypi
you should remove - /opt/vc:/opt/vc:ro from compose file
_[View the full topic](https://discourse.nodered.org/t/use-vcgencmd-within-a-docker-node-red-container/23050)._
