@RGGabe welcome to the forum!
- what version of NR are you using?
- When you say 'dashboard' I think you are referring to the flow editor...correct?
- add a debug node (set to display the complete map object) to the output of the
MoveMoterCodefunction node and run a test. Copy the output and put it in a reply.
- Also export your flow and paste it in a response so people can see what you are doing.
code goes here
icon.
