# Using a dashboard switch node to activate motor/step counter
**URL:** <https://discourse.nodered.org/t/using-a-dashboard-switch-node-to-activate-motor-step-counter/96261>\
**Tags:** node-red-dashboard\
**Created:** [26 March 2025 00:22 UTC](https://discourse.nodered.org/t/using-a-dashboard-switch-node-to-activate-motor-step-counter/96261 "2025-03-26T00:22:59Z")\
**Post date:** [26 March 2025 09:55 UTC](https://discourse.nodered.org/t/using-a-dashboard-switch-node-to-activate-motor-step-counter/96261/2 "2025-03-26T09:55:41Z")
@RGGabe welcome to the forum!
1. what version of NR are you using?
2. When you say 'dashboard' I think you are referring to the flow editor...correct?
3. add a debug node (set to display the complete map object) to the output of the `MoveMoterCode` function node and run a test. Copy the output and put it in a reply.
There’s a great page in the docs ([Working with messages : Node-RED](https://nodered.org/docs/user-guide/messages)) that will explain how to use the debug panel to find the right path/value for any data item.
1. Also export your flow and paste it in a response so people can see what you are doing.
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/using-a-dashboard-switch-node-to-activate-motor-step-counter/96261)._
