# Using dashboard widget inside UI-template?
**URL:** <https://discourse.nodered.org/t/using-dashboard-widget-inside-ui-template/7809>\
**Created:** [10 February 2019 16:50 UTC](https://discourse.nodered.org/t/using-dashboard-widget-inside-ui-template/7809 "2019-02-10T16:50:18Z")\
**Author:** ![r0ller](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/r0ller/32/14327_2.png) [@r0ller](https://discourse.nodered.org/u/r0ller)\
**Post date:** [26 November 2020 11:59 UTC](https://discourse.nodered.org/t/using-dashboard-widget-inside-ui-template/7809/4 "2020-11-26T11:59:17Z")
This may be too late and I hopefully get what you want right but considering your second question, it could be solved in a way that you put your widgets in separate ui\_groups and position them yourself via css.
Here is an example how to position a group (though 'position: fixed' shall be 'absolute' I guess): [How to lock the dashboards groups locations](https://discourse.nodered.org/t/how-to-lock-the-dashboards-groups-locations/7458/7)
Besides that if you load that css from a file (must be put in the folder defined by httpStatic) via an http template added to the html head like:
`<link rel="stylesheet" type="text/css" href="/mystyle.css?id=2313143423423">`
by modifying the id you may even be able to force the browser to reload it whenever the css is modified dynamically. However, I haven't tried that so this is just theory.
_[View the full topic](https://discourse.nodered.org/t/using-dashboard-widget-inside-ui-template/7809)._
