# Using environment variable during another environment variable definiton in flow properties - issue
**URL:** <https://discourse.nodered.org/t/using-environment-variable-during-another-environment-variable-definiton-in-flow-properties-issue/70316>\
**Created:** [9 November 2022 11:14 UTC](https://discourse.nodered.org/t/using-environment-variable-during-another-environment-variable-definiton-in-flow-properties-issue/70316 "2022-11-09T11:14:44Z")\
**Showing post:** 12
**Post date:** [12 November 2022 11:25 UTC](https://discourse.nodered.org/t/using-environment-variable-during-another-environment-variable-definiton-in-flow-properties-issue/70316/12 "2022-11-12T11:25:04Z")
I thought this was about subflow properties as in the post you linked to and the example I posted.
Edit: For the future please post flows inline as described in this canned message.
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/using-environment-variable-during-another-environment-variable-definiton-in-flow-properties-issue/70316)._
