# Using Node RED as an API management platform
**URL:** <https://discourse.nodered.org/t/using-node-red-as-an-api-management-platform/82328>\
**Created:** [25 October 2023 09:53 UTC](https://discourse.nodered.org/t/using-node-red-as-an-api-management-platform/82328 "2023-10-25T09:53:11Z")\
**Post date:** [25 October 2023 11:29 UTC](https://discourse.nodered.org/t/using-node-red-as-an-api-management-platform/82328/2 "2023-10-25T11:29:52Z")
Hi @Josh.
Note: Plenty of battle hardened users here, who may have crucial advise, but here is mine.
> - I want community inputs on if we can use Node red for these purposes?
> - I could achieve basic CRUD operations but then any other complex things can be done?
Sky is the limit, as long as you address any hurdles/shortcomings, I can't see why not.
Under normal circumstance, this should not be a problem, but keep in mind JavaScript is single threaded,
> - If Yes, What are the best practices involved or should be considered?
I wouldn't put Node RED at the front, I would use something like NGINX, this gives you access to throttling, MUCH MUCH better security, and more to help protect Node RED
> - I couldn't create a custom middleware to authenticate.
> - Still worried about the security measures associated with it.
Unless you are a security expert - try to use something that is tried and tested, NGINX is used a lot for both the SSL layer and Authentication.
Read this
[https://discourse.nodered.org/t/safely-accessing-node-red-over-the-internet/](https://discourse.nodered.org/t/safely-accessing-node-red-over-the-internet/)
And enjoy this recent event to re-enforce the need to keep security top priority
[https://discourse.nodered.org/t/node-red-compromise-hack](https://discourse.nodered.org/t/node-red-compromise-hack)
_[View the full topic](https://discourse.nodered.org/t/using-node-red-as-an-api-management-platform/82328)._
