This works !!!
could you help me understand if we can use the shift operator to read the data from start to end .
instead of the loops that has been used
var newMsg = {};
var data_time = msg.payload.data.substr(16, 8) ;
var Temp = Number(hexTo8p8(msg.payload.data.substr(16+8, 4)));
var Humidity = Number(hexTo8p8(msg.payload.data.substr(16 + 8+4, 4)));
var data = msg.payload.data.substr(16, 8);
for(var i=1;i<=30;i++)
data_time = msg.payload.data.substr(16 * i, 8 );
Temp = Number(hexTo8p8(msg.payload.data.substr(24 * i, 4 )));
Humidity = Number(hexTo8p8(msg.payload.data.substr(28 * i, 4 )));
data = msg.payload.data.substr(16 * i, 8 );
let UTC_ISO = new Date(parseInt(msg.payload.data.substr(16 * i, 8), 16) * 1000).toISOString();
var converted_payload = UTC_ISO.split(/\.|T/).slice(0, 2).join(" ");
var checktime = 1546337502;
if(checktime>data_time)
newMsg.payload = [{
time: data_time,
utc: converted_payload,
temp: Temp,
humidity: Humidity,
history: 1
node.send(newMsg);
return null;
function calculateDistance(rssi) {
let P = -69; // @TODO This value should come from MQTT message
let n = 3;
let d = Math.pow(10, ((P - rssi) / (10 * n))); //(n ranges from 2 to 4)
return d * 2;
function hexTo8p8(/** @type {string} */ value) {
let intValue = parseInt(value, 16);
let signed = (intValue & 0x8000) > 0 ? -1/10 : 1;
return signed * intValue / Math.pow(2, 8);
function int2float( /** @type {string} */value_int) {
// Create new Buffer based on array bytes
const buf = Buffer.from(value_int);
// swap the words
const temp0 = buf[0];
const temp1 = buf[1];
buf[0] = buf[2];
buf[1] = buf[3];
buf[2] = temp0;
buf[3] = temp1;
// Represent these bytes as 32-bit unsigned int
const value = buf.readInt32BE();
// save the value
msg.payload = value;
