# VLC video on dashboard
**URL:** <https://discourse.nodered.org/t/vlc-video-on-dashboard/1239>\
**Created:** [2 July 2018 16:04 UTC](https://discourse.nodered.org/t/vlc-video-on-dashboard/1239 "2018-07-02T16:04:11Z")\
**Showing post:** 11
**Post date:** [17 July 2019 10:46 UTC](https://discourse.nodered.org/t/vlc-video-on-dashboard/1239/11 "2019-07-17T10:46:43Z")
> [@nodecentral](#):
> it’s looks like mpeg TS
Never used mpeg-TS, only mjpeg. Since you cannot decode it in your browser, my best guess is that you need to decode it inside Node-RED (before you send the images to the dashboard) using:
- ffmpeg (via Exec-node)
- [jsmpeg](https://github.com/phoboslab/jsmpeg) for a full javascript solution (i.e. without any dependencies that you need to install). But will need some programming skills to get this integrated into Node-RED ...
- Others ?
**[EDIT]** You can **also** use jsmpeg in your browser (i.e. the dashboard), if you don't want to decode the image in your NodeJs (server-side) Node-RED flow.
But I'm afraid I cannot assist you further with this ...
_[View the full topic](https://discourse.nodered.org/t/vlc-video-on-dashboard/1239)._
