# Want to override .nr-dashboard-theme for custom widgets
**URL:** <https://discourse.nodered.org/t/want-to-override-nr-dashboard-theme-for-custom-widgets/60783>\
**Tags:** node-red-dashboard\
**Created:** [4 April 2022 15:21 UTC](https://discourse.nodered.org/t/want-to-override-nr-dashboard-theme-for-custom-widgets/60783 "2022-04-04T15:21:44Z")\
**Post date:** [4 April 2022 16:36 UTC](https://discourse.nodered.org/t/want-to-override-nr-dashboard-theme-for-custom-widgets/60783/2 "2022-04-04T16:36:35Z")
Hi & welcome.
Can you share a minimal flow (only the parts that demonstrate this)?
To export a part of a flow, select the nodes of interest, press CTRL-E, copy to clip-board, paste into a code-block (described below)
### CANNED TEXT...
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/want-to-override-nr-dashboard-theme-for-custom-widgets/60783)._
