# Water Tank Gauge Value Display
**URL:** <https://discourse.nodered.org/t/water-tank-gauge-value-display/93302>\
**Tags:** dashboard-2\
**Created:** [21 November 2024 05:21 UTC](https://discourse.nodered.org/t/water-tank-gauge-value-display/93302 "2024-11-21T05:21:23Z")\
**Showing post:** 3
**Post date:** [22 November 2024 14:49 UTC](https://discourse.nodered.org/t/water-tank-gauge-value-display/93302/3 "2024-11-22T14:49:31Z")
And you can use the ui\_template to make your tank level indicators. That way you can make it as you like.
Examples here
> [@Tank level indication inside of ui-template(v2)](https://discourse.nodered.org/t/tank-level-indication-inside-of-ui-template-v2/86595):
> I need to put a tank level indication or ui-gauge inside of a ui-template. Does anyone have a idea on how to achieve that?
_[View the full topic](https://discourse.nodered.org/t/water-tank-gauge-value-display/93302)._
