# Webpage in Node-RED
**URL:** <https://discourse.nodered.org/t/webpage-in-node-red/10715>\
**Created:** [1 May 2019 14:02 UTC](https://discourse.nodered.org/t/webpage-in-node-red/10715 "2019-05-01T14:02:46Z")\
**Post date:** [1 May 2019 14:17 UTC](https://discourse.nodered.org/t/webpage-in-node-red/10715/2 "2019-05-01T14:17:36Z")
Take a look at
[https://cookbook.nodered.org/http/create-an-http-endpoint](https://cookbook.nodered.org/http/create-an-http-endpoint)
where Node-RED builds a webpage, no html on disk.
If you want to serve a file from disk it gets a little more complicated
[https://cookbook.nodered.org/http/serve-a-local-file](https://cookbook.nodered.org/http/serve-a-local-file)
But you will also need to specify in the Node-RED settings file where the root of your web data is stored see [How to enable ability to input local image files in to node red dashboard](https://discourse.nodered.org/t/how-to-enable-ability-to-input-local-image-files-in-to-node-red-dashboard/3085)
_[View the full topic](https://discourse.nodered.org/t/webpage-in-node-red/10715)._
