# Websocket node customization
**URL:** <https://discourse.nodered.org/t/websocket-node-customization/21130>\
**Created:** [1 February 2020 09:50 UTC](https://discourse.nodered.org/t/websocket-node-customization/21130 "2020-02-01T09:50:36Z")\
**Post date:** [1 February 2020 11:33 UTC](https://discourse.nodered.org/t/websocket-node-customization/21130/2 "2020-02-01T11:33:29Z")
I'm thinking that only in the same way as suggested in your other thread
> [@Setting Mqtt url through API](https://discourse.nodered.org/t/setting-mqtt-url-through-api/17623/4):
> You could use the Admin API to get the full flow configuration, modify it however you want, and then post it back. [https://nodered.org/docs/api/admin/methods/get/flows/](https://nodered.org/docs/api/admin/methods/get/flows/)[https://nodered.org/docs/api/admin/methods/post/flows/](https://nodered.org/docs/api/admin/methods/post/flows/)
_[View the full topic](https://discourse.nodered.org/t/websocket-node-customization/21130)._
