# WebSocket Node multiple clients
**URL:** <https://discourse.nodered.org/t/websocket-node-multiple-clients/29917>\
**Created:** [11 July 2020 20:37 UTC](https://discourse.nodered.org/t/websocket-node-multiple-clients/29917 "2020-07-11T20:37:38Z")\
**Post date:** [11 July 2020 23:11 UTC](https://discourse.nodered.org/t/websocket-node-multiple-clients/29917/4 "2020-07-11T23:11:50Z")
Hi @wahibmichael
From the sidebar help of the WebSocket Out node:
> If you want to broadcast a message that started at a WebSocket In node, you should delete the `msg._session` property within the flow.
So, the property you are interested in is the `msg._session` property.
Have a look at that property with a Debug node for a message that has arrived from a WebSocket In node.
_[View the full topic](https://discourse.nodered.org/t/websocket-node-multiple-clients/29917)._
