@Steve-Mcl thanks. Requiring ws in the setup of the node was an eye opener ![]()
My code in the function is as follows (the company has advised using Sec-WebSocket-Protocol for sending the Authorization token)
const token = "xxxx";
const options = {
headers: {
"Sec-WebSocket-Protocol": "API-Authorization", token
console.log("Trying to establish a websocket communication ....\n")
// Establish a WebSocket connection
const socket = new WebSocket("wss://unify-api.autostoresystem.com/v1/installations/a031v00001CTMX2AAP/", options);
// Handle incoming messages
socket.onmessage = (event) => {
const message = JSON.parse(event.data);
// Process the received message
console.log("Received message: ", message);
// Handle connection close event
socket.onclose = (event) => {
console.log( "Connection closed with code: ", event.code);
// Handle connection error event
socket.onerror = (error) => {
console.error("WebSocket error: ", error);
It still returns an error, but much more detailed information. At least I can see that the authentication token has been passed in the request header. However, I do not see what in my code has triggered the error response.
WebSocket error: ErrorEvent {
[Symbol(kTarget)]: WebSocket {
_events: [Object: null prototype] {
message: [Function],
close: [Function],
error: [Function]
_eventsCount: 3,
_maxListeners: undefined,
_binaryType: 'nodebuffer',
_closeCode: 1006,
_closeFrameReceived: false,
_closeFrameSent: false,
_closeMessage: <Buffer >,
_closeTimer: null,
_extensions: {},
_paused: false,
_protocol: '',
_readyState: 2,
_receiver: null,
_sender: null,
_socket: null,
_bufferedAmount: 0,
_isServer: false,
_redirects: 0,
_url: 'wss://unify-api.autostoresystem.com/v1/installations/a031v00001CTMX2AAP/',
_req: ClientRequest {
_events: [Object: null prototype],
_eventsCount: 4,
outputData: [],
outputSize: 0,
writable: true,
destroyed: true,
_last: true,
chunkedEncoding: false,
shouldKeepAlive: true,
maxRequestsOnConnectionReached: false,
_defaultKeepAlive: true,
useChunkedEncodingByDefault: false,
sendDate: false,
_removedConnection: false,
_removedContLen: false,
_removedTE: false,
strictContentLength: false,
_contentLength: 0,
_hasBody: true,
_trailer: '',
finished: true,
_headerSent: true,
_closed: false,
socket: [TLSSocket],
_header: 'GET /v1/installations/a031v00001CTMX2AAP/ HTTP/1.1\r\n' +
'Sec-WebSocket-Protocol: API-Authorization\r\n' +
'token: xxxx\r\n‘ +
'Sec-WebSocket-Version: 13\r\n' +
'Sec-WebSocket-Key: bx/QZ1XM5NyAbFyhcdpsHg==\r\n' +
'Connection: Upgrade\r\n' +
'Upgrade: websocket\r\n' +
'Sec-WebSocket-Extensions: permessage-deflate; client_max_window_bits\r\n' +
'Host: unify-api.autostoresystem.com\r\n' +
'\r\n',
_keepAliveTimeout: 0,
_onPendingData: [Function: nop],
agent: undefined,
socketPath: undefined,
method: 'GET',
maxHeaderSize: undefined,
insecureHTTPParser: undefined,
joinDuplicateHeaders: undefined,
path: '/v1/installations/a031v00001CTMX2AAP/',
_ended: false,
res: [IncomingMessage],
aborted: true,
timeoutCb: null,
upgradeOrConnect: false,
parser: null,
maxHeadersCount: null,
reusedSocket: false,
host: 'unify-api.autostoresystem.com',
protocol: 'https:',
[Symbol(kCapture)]: false,
[Symbol(kBytesWritten)]: 0,
[Symbol(kNeedDrain)]: false,
[Symbol(corked)]: 0,
[Symbol(kOutHeaders)]: [Object: null prototype],
[Symbol(errored)]: null,
[Symbol(kUniqueHeaders)]: null,
[Symbol(kAborted)]: true,
[Symbol(kError)]: undefined
[Symbol(kType)]: 'error',
[Symbol(kError)]: Error: Unexpected server response: 500
at ClientRequest.<anonymous> (/Users/peikbremer/.node-red/node_modules/ws/lib/websocket.js:888:7)
at ClientRequest.emit (node:events:513:28)
at HTTPParser.parserOnIncomingClient (node:_http_client:701:27)
at HTTPParser.parserOnHeadersComplete (node:_http_common:119:17)
at TLSSocket.socketOnData (node:_http_client:542:22)
at TLSSocket.emit (node:events:513:28)
at addChunk (node:internal/streams/readable:324:12)
at readableAddChunk (node:internal/streams/readable:297:9)
at TLSSocket.Readable.push (node:internal/streams/readable:234:10)
at TLSWrap.onStreamRead (node:internal/stream_base_commons:190:23),
[Symbol(kMessage)]: 'Unexpected server response: 500'
Connection closed with code: 1006
Anyone seeing what may be the problem?
