I put a 5 second delay between inject and trigger. It works fine now.
I put the following line above the return line:
global.set('ktop',ktop);
I think my last reply is the answer to this. If I remove ground or signal wire, it sends a message with no payload. This is the same thing with the original problem I had. So, maybe it is related to wiring issues, since I am working with a breadboard. When I remove power, it reads 85 degrees (C).
