# Will there be any performance hit because of using many MQTT nodes
**URL:** <https://discourse.nodered.org/t/will-there-be-any-performance-hit-because-of-using-many-mqtt-nodes/3204>\
**Created:** [17 September 2018 09:35 UTC](https://discourse.nodered.org/t/will-there-be-any-performance-hit-because-of-using-many-mqtt-nodes/3204 "2018-09-17T09:35:11Z")\
**Showing post:** 5
**Author:** ![nithinbandaru1](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/nithinbandaru1/32/2513_2.png) [@nithinbandaru1](https://discourse.nodered.org/u/nithinbandaru1)\
**Post date:** [17 September 2018 10:01 UTC](https://discourse.nodered.org/t/will-there-be-any-performance-hit-because-of-using-many-mqtt-nodes/3204/5 "2018-09-17T10:01:57Z")
@cymplecy Thanks for the reply. I will consider testing in the way you suggested.
Actually, I am doing stream processing(stream analytics) using node-red.
**This below link will give more info regarding what I am doing:**
> [@Any suggestion on architecture/Design pattern for node-red?](https://discourse.nodered.org/t/any-suggestion-on-architecture-design-pattern-for-node-red/2987):
> Hi, I am doing stream analytics using node-red with MQTT and data is coming form OPC. On flow start: Using inject function will minimum time I will initialize common functions, objects, variables, configurations needed for processing the data coming form OPC through MQTT node. First layer: I have couple of flows with 400-500 MQTT nodes. Second layer: Each MQTT output goes to one function node.(Having one for each to add meta data to the message like type of message and index if I am using ar…
_[View the full topic](https://discourse.nodered.org/t/will-there-be-any-performance-hit-because-of-using-many-mqtt-nodes/3204)._
