# Wiz node-red-contrib-wiz-local-control
**URL:** <https://discourse.nodered.org/t/wiz-node-red-contrib-wiz-local-control/83446>\
**Tags:** docker\
**Created:** [5 December 2023 18:15 UTC](https://discourse.nodered.org/t/wiz-node-red-contrib-wiz-local-control/83446 "2023-12-05T18:15:30Z")\
**Post date:** [5 December 2023 18:25 UTC](https://discourse.nodered.org/t/wiz-node-red-contrib-wiz-local-control/83446/2 "2023-12-05T18:25:46Z")
> [@CAL37](#):
> and found this palette however there isn't a lot of information on it
Before going down that route - you might want to check out this thread
> [@Local control of home devices - Wiz](https://discourse.nodered.org/t/local-control-of-home-devices-wiz/83009):
> Following someone's hint on Mastodon that Wiz devices could be controlled locally, I bought a Wiz GU10 to test out I set up it using their app (usual thing that all smart devices have) couldn't see anything about local control in that or on their website but a bit of googling lead to [https://www.reddit.com/r/wiz/comments/1582jfx/guide\_to\_controlling\_a\_wiz\_lightplug\_via\_windows/](https://www.reddit.com/r/wiz/comments/1582jfx/guide_to_controlling_a_wiz_lightplug_via_windows/) which lead me to install ncap on my win 11 machine and these two command lines switch it off and on! slight_smile …
I think @cymplecy has achieved it without any external Nodes.
But if you wanted to go down the external Node route, my guess is, this is the interface that the UDP return packets should be received on.
I know nothing about WIZ or Docker, so wouldn't know how you get the lan interface that Docker is using
_[View the full topic](https://discourse.nodered.org/t/wiz-node-red-contrib-wiz-local-control/83446)._
