# Write Slide Value
**URL:** <https://discourse.nodered.org/t/write-slide-value/7450>\
**Created:** [31 January 2019 21:54 UTC](https://discourse.nodered.org/t/write-slide-value/7450 "2019-01-31T21:54:27Z")\
**Post date:** [2 February 2019 11:40 UTC](https://discourse.nodered.org/t/write-slide-value/7450/4 "2019-02-02T11:40:55Z")
If you look at the result in a debug node does it look correct?
Also your flow is not importable, you need to edit the previous post as described in [How to share code or flow json](https://discourse.nodered.org/t/how-to-share-code-or-flow-json/506)
_[View the full topic](https://discourse.nodered.org/t/write-slide-value/7450)._
