# Writing using file node UTF-8, encoding becomes iso-8859
**URL:** https://discourse.nodered.org/t/writing-using-file-node-utf-8-encoding-becomes-iso-8859/9114
**Category:** General
**Created:** [18 March 2019 10:34 UTC](https://discourse.nodered.org/t/writing-using-file-node-utf-8-encoding-becomes-iso-8859/9114 "2019-03-18T10:34:54Z")
### Author: ![Colin](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/colin/32/17040_2.png) [@Colin](https://discourse.nodered.org/u/Colin)
#### Post date: [18 March 2019 10:50 UTC](https://discourse.nodered.org/t/writing-using-file-node-utf-8-encoding-becomes-iso-8859/9114/2 "2019-03-18T10:50:22Z")
> [@mbot](#):
> Now I hope my first post is correct!
Not quite 🙂 , to make your flow importable you have to follow these instructions:
_[View the full topic](https://discourse.nodered.org/t/writing-using-file-node-utf-8-encoding-becomes-iso-8859/9114)._
