# Zigbee2mqtt Aquara triple Sensors WSDCGQ11LM (temp, humidity, pressure) - 2 sensor test-flow
**URL:** https://discourse.nodered.org/t/zigbee2mqtt-aquara-triple-sensors-wsdcgq11lm-temp-humidity-pressure-2-sensor-test-flow/84511
**Category:** Share Your Projects
**Created:** [12 January 2024 16:13 UTC](https://discourse.nodered.org/t/zigbee2mqtt-aquara-triple-sensors-wsdcgq11lm-temp-humidity-pressure-2-sensor-test-flow/84511 "2024-01-12T16:13:23Z")
### Author: ![juntiedt](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/juntiedt/32/58357_2.png) [@juntiedt](https://discourse.nodered.org/u/juntiedt)
#### Post date: [13 January 2024 22:12 UTC](https://discourse.nodered.org/t/zigbee2mqtt-aquara-triple-sensors-wsdcgq11lm-temp-humidity-pressure-2-sensor-test-flow/84511/2 "2024-01-13T22:12:30Z")
I have added min-max values to the flow which is very usefull in sensor use cases.
Reset of min max is set to occur on midnight. Can be changed to week etc.
 ![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/c/a/caabe3d27d7ff26fabcc769c296f4d48b889fcc6.png)
 ![aqara-thp-2](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/0/e/0ecacca4d858035ca5c369d6587427d414138795.png)
 ![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/b/7/b7b29fd95f4321d4e1479b5a52faa11bf9389edc.png)
[Zigbee-27.01.2024.txt](https://discourse.nodered.org/uploads/short-url/m1X2uaPW5Aa9UFPlsfiIlHlb4pv.txt) (146.6 KB)
Flow updated 27.01.2024 at 15:34 (added gauges for Voltage and Linlquality)
_[View the full topic](https://discourse.nodered.org/t/zigbee2mqtt-aquara-triple-sensors-wsdcgq11lm-temp-humidity-pressure-2-sensor-test-flow/84511)._
