Ok, thanks to those who have responded and gave some mentoring. I feel like I've made some progress, but again stumped so I've included all the documentation to help troubleshoot. I still can't get my session to rotate tabs.
Below is the flow (with code)
This flow gets the socketID and IP from the tab and then a user inputs this into dashboard user form to ensure which browser tab the user wants to rotate.
Dashboard group. After the input, a popup text box shows what was entered and it stores the socketid and socketip in a global variable.
I've ensured the socketid is the same and correct. This is when the tab connects and changes to the "Configuration & Resets" tab which the above dashboard is on.
from the developer network debug. Verified the socketid is correct.
at 20 seconds past the min rotate to tab 1, 40 seconds rotate to tab 2, 0 seconds rotate to tab 3. Here is my function code.
debug out of the function which I'm pushing into the control_UI. All the objects look correct to me. I added the seconds to ensure it was firing at the right time interval.
Only issue I see I have is I'm not getting any debug out of the After Rotate UI Control debug node, well that and it's not rotating.
Kyle
[{"id":"5c4dd14a7c2c8a1e","type":"ui_ui_control","z":"204548a488401a1b","name":"Get IU Control","events":"all","x":1260,"y":1200,"wires":[["3e32507cf496c14e","bee1f8812d8d8760","2743e8dfd93fb7c8"]]},{"id":"e21f3e0591833840","type":"function","z":"204548a488401a1b","name":"Rotate tabs based on seconds","func":"let currentTime = new Date();\nlet seconds = currentTime.getSeconds();\nlet socketid = global.get('socketid');\nlet socketip = global.get('socketip');\n\nif (seconds == 20)\n{\n return {\"payload\":\"change\",\"tab\":1, \"name\":\"Radio Info\", \"socketid\":socketid, \"socketip\":socketip, \"seconds\":seconds};\n}\n\nif (seconds == 40)\n{\n return {\"payload\":\"change\", \"tab\":2, \"name\":\"OP Competition\", \"socketid\":socketid, \"socketip\":socketip, \"seconds\":seconds};\n}\n\nif (seconds == 0)\n{\n return {\"payload\":\"change\", \"tab\":3, \"name\":\"Band Stats\", \"socketid\":socketid, \"socketip\":socketip, \"seconds\":seconds};\n}\n\nreturn;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":390,"y":1220,"wires":[["57273c6d705dbfce","aa4d1f3abac4a62f"]]},{"id":"57273c6d705dbfce","type":"debug","z":"204548a488401a1b","name":"After Function","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":660,"y":1180,"wires":[]},{"id":"0979daa9c078c057","type":"ui_form","z":"204548a488401a1b","name":"","label":"Socket ID & IP","group":"0ae735dd5356d1e8","order":3,"width":8,"height":2,"options":[{"label":"Socket ID","value":"socketid","type":"text","required":true,"rows":null},{"label":"Machine IP","value":"socketip","type":"text","required":true,"rows":null}],"formValue":{"socketid":"","socketip":""},"payload":"","submit":"submit","cancel":"cancel","topic":"topic","topicType":"msg","splitLayout":"","className":"","x":620,"y":1060,"wires":[["80b7b6186bcf121d","e0137d1a709aca80"]]},{"id":"80b7b6186bcf121d","type":"function","z":"204548a488401a1b","name":"Set Global Rotating Session ID","func":"let socketip = msg.payload.socketip\nlet socketid = msg.payload.socketid\nglobal.set(\"socketid\",socketid)\nglobal.set(\"socketip\",socketip)\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":890,"y":1060,"wires":[[]]},{"id":"87bbe35110f717a1","type":"ui_toast","z":"204548a488401a1b","position":"dialog","displayTime":"","highlight":"","sendall":false,"outputs":1,"ok":"OK","cancel":"Cancel","raw":false,"className":"","topic":"","name":"Show Socket ID","x":1080,"y":1100,"wires":[[]]},{"id":"e0137d1a709aca80","type":"function","z":"204548a488401a1b","name":"Set payload to printout","func":"socketid = msg.payload.socketid\nsocketip = msg.payload.socketip\n\nmsg.payload = \"socketid=\" + socketid + \" \" + \"IP=\" + socketip;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":860,"y":1100,"wires":[["87bbe35110f717a1"]]},{"id":"bee1f8812d8d8760","type":"ui_text","z":"204548a488401a1b","group":"0ae735dd5356d1e8","order":1,"width":8,"height":1,"name":"","label":"This Socket ID : ","format":"{{msg.socketid}}","layout":"row-spread","className":"","x":1480,"y":1200,"wires":[]},{"id":"320d94a84c4edd14","type":"inject","z":"204548a488401a1b","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"1","crontab":"","once":false,"onceDelay":0.1,"topic":"","payloadType":"date","x":150,"y":1220,"wires":[["e21f3e0591833840"]]},{"id":"3e32507cf496c14e","type":"debug","z":"204548a488401a1b","name":"Get UI Control","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1480,"y":1160,"wires":[]},{"id":"2743e8dfd93fb7c8","type":"ui_text","z":"204548a488401a1b","group":"0ae735dd5356d1e8","order":2,"width":8,"height":1,"name":"","label":"This IP :","format":"{{msg.socketip}}","layout":"row-spread","className":"","x":1460,"y":1240,"wires":[]},{"id":"aa4d1f3abac4a62f","type":"ui_ui_control","z":"204548a488401a1b","name":"Rotate UI Control","events":"change","x":650,"y":1220,"wires":[["c473245f3df6387a"]]},{"id":"c473245f3df6387a","type":"debug","z":"204548a488401a1b","name":"After Rotate UI Control","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":980,"y":1200,"wires":[]},{"id":"0ae735dd5356d1e8","type":"ui_group","name":"Rotating Dispaly","tab":"08eed6c3517c624e","order":5,"disp":true,"width":8,"collapse":false,"className":""},{"id":"08eed6c3517c624e","type":"ui_tab","name":"Configuration & Resets","icon":"mi-storage","order":6,"disabled":false,"hidden":false}]
