2.0.3 http request node with tls - valid certificates no longer work
I upgraded my instance today to 2.0.3 from 1.3.5 and noticed all of my HTTP request nodes are displaying errors under the node "SELF_SIGNED_CERT_IN_CHAIN" However the server these are going to has a valid cert, and openssl verify against the CA cert, comes back successful. I restored my backup from 1.3.5 install and everything works fine. The only way I have identified to get rid of the errors is to turn off certificate verification, but even with a valid cert, valid ca present nodered request node seems to think its untrusted or self signed.
Anyone else exhibit this?
example flow (works in 1.3.5, fails once upgraded to 2.0.3):
        "id": "ede8f8bc3ed1d623",
        "type": "http request",
        "z": "90a227ad3d39d234",
        "method": "POST",
        "ret": "txt",
        "paytoqs": "ignore",
        "url": "https://em01.ag.home.lab/api/login",
        "tls": "06b9d026eb93bb05",
        "persist": false,
        "proxy": "",
        "authType": "",
        "credentials": {},
        "x": 400,
        "y": 400,
                "7ff06071f1d48158"
        "id": "06b9d026eb93bb05",
        "type": "tls-config",
        "name": "CA Verify",
        "cert": "",
        "key": "",
        "ca": "",
        "certname": "",
        "keyname": "",
        "caname": "ca01",
        "servername": "",
        "verifyservercert": true,
        "alpnprotocol": "",
        "credentials": {}
error returned in debug message:
RequestError: self signed certificate in certificate chain
Anyone else run into this? I checked github issue tracker and didn't see any relevant issues opened so figure I'd check here first.
Please do raise an issue.
Ok, will move this discussion to issue tracker. Thanks for the quick reply!
