A buffer as payload from function node
I have a flow in Node-red in which a function will have to send a binary message to the serial port node.
I set up the function node with code similar to this
blReply =[217,181,0,75];
    for (i=0; i< blReply.length; i++){
        msg.payload = blReply[i];
        node.send(msg);
When I receive the data on the serial port , the data received is actually a string (ASCII encoded)
the string received on the other end of the serial port is actually [217,181,0, 75].
I was expecting to receive the binary equivalent of the integers 217 181 0 and 75.
When I inject using the inject node the buffer [217,181,0, 75] the data recieved on the other end of the serial port is as expected the integers 217, 181, 0 and 75.
I Can't see what is wrong in the function node code, can you please help me out with this ?
Regards
lbh00
do you need to send one character at a time ? Why not just send the array as-is ? ie
msg.payload = [217,181,0,75];
node.send msg;
The serial port should send that as a binary payload.
Hello Dceejay,
Thanks for your reply.
Well sending 1 byte after the other was one way of debugging to understand what is going on.
I retried your proposal and I still get the data as an ASCII encoded message.
I connected a debug node to snoop on the data transiting from the function node to the serialport node I notice some differences:
the data sent from the function node the msg.payload is typed as array, while the msg.payload injected by the inject node is typed as buffer. What is the difference ?
Regards
lbh00
I looked at the code of serialport node, and apparently if the typeof msg.payload is not a buffer, serial port will convert it to a string. a snip from the serialport node code:
encodePayload:
function (payload) {
                            if (!Buffer.isBuffer(payload)) {
                                if (typeof payload === "object") {
                                    payload = JSON.stringify(payload);
                                else {
                                    payload = payload.toString();
                                if (addchar !== "") { payload += addchar; }
                            else if (addchar !== "") {
                                payload = Buffer.concat([payload,Buffer.from(addchar)]);
                            return payload;
so what I did, is convert the array to a buffer inside my function as follows:
var payload = Buffer.from([217,181,0,75])
then send it to serialport node.
I hope this helps someone who is having this issue too.
Regards
lbh00
Aha - of course... yes - do exactly that.
