Hi everyone,
We've just published a Node-RED Storage API plugin backed by
SurrealDB 4.x: GitHub:
npm: @topcs/node-red-storage-surrealdb
We use Node-RED as the IVR engine in a multi-tenant contact center
(FreeSWITCH ESL + Node-RED). Once you run Node-RED in stateless containers
alongside an existing backend, local flows.json files start getting in the way:
• You want every deploy to leave an auditable, immutable revision you can
roll back without wiring up Git/Projects on every container.
• You want draft/publish semantics so someone can prepare a change without
touching live calls.
• You want to map external domain entities (in our case, phone numbers / DNIS
and brands) to specific flow tabs from the same database the rest of the
platform already backs up.
What is SurrealDB, and why it fits Node-RED storage well
If you haven't tried yet, it's an open-source multi-model database written in Rust. It combines document storage, relational tables, graph edges, and realtime LIVE SELECT subscriptions in a
single binary — it runs in-memory for tests (surreal start memory), on disk with SurrealKV, or distributed.
A few things made it a surprisingly good match for the Node-RED Storage API:
1.Strict metadata + flexible JSON payloads in the same table.
2.Atomic transactions for revisioning.
3. Clean isolation via NAMESPACE / DATABASE
4.Zero-friction local testing.
Feedback, bug reports, and PRs are very welcome.
