A scrolling terminal display in dashboard 2
Hi all, I did a demo for someone recently and thought I'd share for you all to enjoy (or ignore)
I have not made a contrib node out of it, but that would not be too difficult to do.
Here is a gif for your viewing pleasure:
chrome_urnbkVJRsY
click me for a biglier view
And more importantly, here is the demo flow:
[{"id":"575c755afa443ca9","type":"tab","label":"Dashboard terminal","disabled":false,"info":"","env":[]},{"id":"7bab5965093a262f","type":"group","z":"575c755afa443ca9","name":"Dashboard Terminal \\n ","style":{"stroke":"#000000","stroke-opacity":"0.87","label":true,"fill":"#000000","fill-opacity":"0.7","color":"#92d04f"},"nodes":["fe38a45454245194","c2ab95f1fc818b4e","fad233b0126b26de","645574ddf19bb3a1","8e472dbf0ce76b58"],"x":154,"y":43,"w":922,"h":98},{"id":"fe38a45454245194","type":"link in","z":"575c755afa443ca9","g":"7bab5965093a262f","name":"Log to Dashboard Teminal","links":["2526f2d1c4691e31","645574ddf19bb3a1","594b1355ce316660","110cb7c42ddbbcb7","5c2536861f0a8205"],"x":290,"y":100,"wires":[["c2ab95f1fc818b4e"]],"l":true},{"id":"c2ab95f1fc818b4e","type":"function","z":"575c755afa443ca9","g":"7bab5965093a262f","name":"log to context.log","func":"const MAX_ROWS = 200\n\nif (msg.topic === \"clear-log\") {\n    context.set('log', [])\n    msg.topic = ''\n    msg.payload = []\n    return msg\n}\n\nconst incomingMessage = msg.payload\nlet log = context.get('log') || []\nif (!Array.isArray(log)) {\n    log = []\n}\n\nlet logMessages = normaliseLogEntry(msg.payload)\n\nfunction normaliseLogEntry(data) {\n    const result = []\n    if (data === null) {\n        return normaliseLogEntry(\"null\") \n    } else if (typeof data === \"undefined\") {\n        return normaliseLogEntry(\"undefined\")\n    } else if (typeof data === 'number') {\n        return normaliseLogEntry(\"\" + data)\n    } else if (Array.isArray(data)) {\n        const arrStr = [\"[\"]\n        for (let index = 0; index < data.length; index++) {\n            if (index > 0) { arrStr.push(', ') }\n            arrStr.push(normaliseLogEntry(data[index]))\n        }\n        arrStr.push(\"]\")\n        return normaliseLogEntry(arrStr.join(''))\n    } else if (typeof data === 'object') {\n        result.push(\"> \" + JSON.stringify(data, null, 2))\n    } else if (Buffer.isBuffer(data)) {\n        result.push(\"> \" + data.toJSON())\n    } else if (data && typeof data !== 'string') {\n        result.push(\"> \" + data.toString())\n    } else {\n        if (data.includes('\\n')) {\n            const lines = data.split('\\n').map(m => \"> \" + m)\n            result.push(...lines)\n        } else {\n            result.push(\"> \" + data)\n        }\n    }\n    return result\n}\n\nlog.push(...logMessages.flat())\n\nif(log.length >= MAX_ROWS) {\n    // remove the oldest messages which are at the beginning of the array\n    log = log.slice(-MAX_ROWS)\n}\n\ncontext.set('log', log)\nmsg.payload = log\nreturn msg\n\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":550,"y":100,"wires":[["fad233b0126b26de"]]},{"id":"fad233b0126b26de","type":"ui-template","z":"575c755afa443ca9","g":"7bab5965093a262f","group":"284bc3bf9214f38d","page":"","ui":"","name":"","order":1,"width":0,"height":0,"head":"","format":"<template>\n    <div class=\"terminal\" ref=\"terminal\">\n        <div class=\"log-entry\" v-for=\"(log, index) in logData\" :key=\"index\">\n            {{ log }}\n        </div>\n    </div>\n    <v-btn @click=\"clearLog()\">Clear</v-btn>\n</template>\n\n<script>\n    export default {\n        data() {\n            return {\n                logData: []\n            }\n        },\n        watch: {\n            msg: function () {               \n                if (Array.isArray(this.msg.payload)) {\n                    const terminal = this.$refs.terminal;\n                    const graceDistance = 25 //px\n                    const isAtBottom = terminal.scrollHeight - terminal.scrollTop - terminal.clientHeight <= graceDistance;\n                    if (isAtBottom) {\n                        this.$nextTick(() => {\n                            terminal.scrollTop = terminal.scrollHeight;\n                        })\n                    }\n                    this.logData = this.msg.payload\n                }\n            }\n        },\n        methods: {\n            clearLog: function () {\n                this.send({topic: \"clear-log\"})\n            },\n        }\n    }\n</script>\n<style scoped>\n    .terminal {\n        background-color: black;\n        color: limegreen;\n        font-family: 'Courier New', Courier, monospace;\n        padding: 20px;\n        border-radius: 5px;\n        height: 600px;\n        overflow-y: auto;\n        box-shadow: inset 0 0 10px rgba(0, 0, 0, 0.5);\n    }\n\n    .log-entry {\n        margin: 0;\n        line-height: 1.5;\n    }\n</style>","storeOutMessages":true,"passthru":false,"resendOnRefresh":true,"templateScope":"local","className":"","x":760,"y":100,"wires":[["8e472dbf0ce76b58"]]},{"id":"59cfcb76bbc0dc5c","type":"inject","z":"575c755afa443ca9","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"Hello world","payloadType":"str","x":240,"y":240,"wires":[["2526f2d1c4691e31"]]},{"id":"08215b5cb4982c90","type":"inject","z":"575c755afa443ca9","name":"long test","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"This is a long looooooooooooooooooong loooooooooooooooooooooooong  loooooooooooooooooooooooooooooooong test message","payloadType":"str","x":240,"y":280,"wires":[["2526f2d1c4691e31"]]},{"id":"2526f2d1c4691e31","type":"link out","z":"575c755afa443ca9","name":"link out 3","mode":"link","links":["fe38a45454245194"],"x":385,"y":280,"wires":[]},{"id":"777cab562491a8a4","type":"comment","z":"575c755afa443ca9","name":"simple test messages","info":"","x":260,"y":200,"wires":[]},{"id":"645574ddf19bb3a1","type":"link out","z":"575c755afa443ca9","g":"7bab5965093a262f","name":"link out 10","mode":"link","links":["fe38a45454245194"],"x":1035,"y":100,"wires":[]},{"id":"8e472dbf0ce76b58","type":"switch","z":"575c755afa443ca9","g":"7bab5965093a262f","name":"clear-log?","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"clear-log","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":920,"y":100,"wires":[["645574ddf19bb3a1"]]},{"id":"e6c68773c06acbfb","type":"ui-form","z":"575c755afa443ca9","name":"","group":"192c891a3de910f5","label":"Delete Task","order":1,"width":0,"height":0,"options":[{"label":"Task Name","key":"task","type":"text","required":true,"rows":null},{"label":"Reason","key":"reason","type":"multiline","required":false,"rows":3}],"formValue":{"task":"","reason":""},"payload":"","submit":"Delete","cancel":"Clear","resetOnSubmit":false,"topic":"task-control","topicType":"str","splitLayout":"","className":"","dropdownOptions":[],"x":770,"y":240,"wires":[["6139cd66dd07d730","90ee03051095e7f3"]]},{"id":"f9fe03e7b03a0695","type":"comment","z":"575c755afa443ca9","name":"Demo form","info":"","x":760,"y":200,"wires":[]},{"id":"594b1355ce316660","type":"link out","z":"575c755afa443ca9","name":"link out 11","mode":"link","links":["fe38a45454245194"],"x":1065,"y":240,"wires":[]},{"id":"6139cd66dd07d730","type":"debug","z":"575c755afa443ca9","name":"debug 14","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":940,"y":280,"wires":[]},{"id":"90ee03051095e7f3","type":"function","z":"575c755afa443ca9","name":"delete (sim)","func":"const sleep = ms => new Promise(r => setTimeout(r, ms));\nconst sendString = str => node.send({payload: str});\n\n// send initial message\nsendString(`🗑️ Deleting task: '${msg.payload.task}', reason: '${msg.payload.reason || '<empty>'}'`)\n\n// pretend to do work\nawait sleep(350)\nsendString('⚙️ Processing your request. Please wait...')\nawait sleep(1000)\nsendString('✅ Your task was deleted. Please remember words are useful for saying things on a screen or on paper. In this instance, I am simply using them to generate a long response - for demonstration purposes! 😉')\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":950,"y":240,"wires":[["594b1355ce316660"]]},{"id":"781a18c082aab908","type":"inject","z":"575c755afa443ca9","name":"empty line","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":240,"y":320,"wires":[["2526f2d1c4691e31"]]},{"id":"d084e92102e0c7f8","type":"inject","z":"575c755afa443ca9","name":"object test","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"info\":\"testing object payload with a data array\",\"data\":[1,2,\"three\",4,5]}","payloadType":"json","x":520,"y":240,"wires":[["110cb7c42ddbbcb7"]]},{"id":"3eb46205eaac1e46","type":"inject","z":"575c755afa443ca9","name":"buffer test","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[65,32,115,116,114,105,110,103,32,111,102,32,99,104,97,114,115,32,115,101,110,100,32,97,115,32,97,32,98,117,102,102,101,114]","payloadType":"bin","x":520,"y":280,"wires":[["110cb7c42ddbbcb7"]]},{"id":"29550367b518fc51","type":"comment","z":"575c755afa443ca9","name":"complex test messages","info":"","x":540,"y":200,"wires":[]},{"id":"110cb7c42ddbbcb7","type":"link out","z":"575c755afa443ca9","name":"link out 12","mode":"link","links":["fe38a45454245194"],"x":645,"y":260,"wires":[]},{"id":"d91b1897d6eecd52","type":"inject","z":"575c755afa443ca9","name":"multi line","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"\"\\nGood morning\\n\\nand in case I don't see ya...\\ngood afternoon, good evening and good night!\"","payloadType":"jsonata","x":520,"y":320,"wires":[["110cb7c42ddbbcb7"]]},{"id":"f0e5b13cdee7a589","type":"inject","z":"575c755afa443ca9","name":"","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"clear-log","x":240,"y":420,"wires":[["5c2536861f0a8205"]]},{"id":"5c2536861f0a8205","type":"link out","z":"575c755afa443ca9","name":"link out 1","mode":"link","links":["fe38a45454245194"],"x":355,"y":420,"wires":[]},{"id":"284bc3bf9214f38d","type":"ui-group","name":"Terminal","page":"11a250b56df8dffa","width":"9","height":"1","order":2,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"192c891a3de910f5","type":"ui-group","name":"Tasks","page":"11a250b56df8dffa","width":"3","height":"1","order":1,"showTitle":true,"className":"","visible":"true","disabled":"false"},{"id":"11a250b56df8dffa","type":"ui-page","name":"Terminal","ui":"83289142e2632cc2","path":"/terminal","icon":"home","layout":"grid","theme":"f36403a3012e6880","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":2,"className":"","visible":"true","disabled":"false"},{"id":"83289142e2632cc2","type":"ui-base","name":"My Dashboard","path":"/dashboard","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"headerContent":"page","navigationStyle":"default","titleBarStyle":"default","notificationDisplayTime":5},{"id":"f36403a3012e6880","type":"ui-theme","name":"Default Theme","colors":{"surface":"#ffffff","primary":"#0094CE","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}}]
UPDATE 2025-04-05:
  • Modified page path to avoid clashing with users existing pages
  • Code tidy
Very handy for log files ! Thanks
