Ability to use hooks to listen to events on Start / Stop / Error of a Flow
Hey Team,
I am looking for some solution to know when a flow started and ended.
Something that allows you to use Hooks Api and listen for events like "onFlowStart" / "onFlowStop",
This will help us monitor the flows and keep track of time taken for various flows which can later be used to identify slowness / flow execution rate etc.
Flows only really start and stop when Node-RED starts and stops. Other than that they are driven by events. So a trigger node creates a message that appears to "start" a flow but really, the flow has been running all along, just that it had no messages.
There are various ways therefore to track timings. Depends on the details.
Thanks for your explanation.
I want to track the timing and input/output of each node's send and receive calls, to store history for debugging.
I am considering adding hooks on onSend and onRecieve to get the events and inject a correlation ID at the trigger node.
Later I can relate this information based on correlation ID, flow ID, and node ID.
I would like to know, whether this is a good approach, or something better is there.
I think there is a contributed node for doing that? Can't find it in the flows but maybe a search through the forum will find it.
