Accumulates data in a variable
So show me where in your code AND how many times do you get that flow variable.
when i get the stopingtime i want to accumulate it in the down time variable so i get the last stopingtime and the last value of the down time
that should be in the first time = a zero
and sum them and restore it to downtime flow variable
what does flow.get("downtime") contain at this (see arrow) point in the code?
get the last downtime value stored
i think generally
but what and when have you stored a value???
this is the issue i want in the first time to store a 0 in the downtime and for the rest of the day accumulate the stooping time when i store a 0 in the begin the script always give the downtime 0
What do you notice that is different in the two places you get downtime?
i don't know
or i still don't understand the logic of javascript or if i need to use a while or do while
It seems to me you need to take a tutorial about javascript - I suggest looking at JavaScript Tutorial
Lets look at the original version of the function node from your first post:
var stopingT= flow.get("stopingT") || 0;
var downtime1= flow.get("downtime1") || 0;
var downtime= flow.get("downtime") || 0;
if (msg.payload) {
    // payload is true so save start time
    startTime = new Date()
    context.set("startTime", startTime)
    msg = null      // don't send a message
} else {
    // payload is false so send start and end time
    startTime = context.get("startTime") || 0
    if ( startTime === 0) {
        // no start time recorded so must be first time through so ignore it
        msg = null
    } else {
        var stopTime =new Date()
        var stoping = (stopTime - startTime)/60000
        stoping =Math.round(stoping * 100) / 100
        flow.set("downtime1",stoping);
    // to store the data
        if(flow.get("downtime1")!== 0)
        { var a
           a = flow.get("downtime") + flow.get("downtime1");
            flow.set("downtime",a)
        a=0;
        stoping = stoping.toLocaleString(undefined, {minimumFractionDigits: 2, maximumFractionDigits: 2})
       // stoping =parseFloat("stoping")
        flow.set("stopingT",stoping);
        msg.payload = startTime.toLocaleString("nl-BE") +"#"+stopTime.toLocaleString("nl-BE")+"#"+stoping
        // clear start time
        context.set("startTime", 0)
In line 3 you have
which says "if the flow variable "downtime' contains something, put it in the local variable 'downtime' otherwise put 0 in the local variable 'downtime'. So far so good!
Further down you have this code:
        { var a
           a=0;
So if flow.get("downtime1" is not zero, you execute the following code. Note: since you set a local variable downtime1 in line 2 you should code this line as `if (downtime1 !== 0)'
So you create a variable 'a' and try to set it to the flow variables downtime and downtime1 BUT if you have never set those variables, they might contain nothing and cause a NaN error to occur!
had you coded that line as: `a = downtime + downtime1;' using the two local variables you setup on lines 2 and 3, you would never have hit the NaN issue.
All this tells me you should stop using the function node until you have taken a Javascript tutorial.
@zenofmud thank you for your time SIR yes i will take the tutorial that you give me yes it's my first experience with javascript
sorry .
