Action depending on 2 different MQTT messages
Via MQTT there are two outputs/messages from my Sonoff (Tasmota) Dual R3:
tele/Fietsen/STATE = {"Time":"2022-09-18T11:21:07","Uptime":"0T18:50:17","UptimeSec":67817,"Heap":151,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":14,"Berry":{"HeapUsed":3,"Objects":40},"POWER1":"ON","POWER2":"OFF","Wifi":{"AP":1,"SSId":"TIS","BSSId":"2C:91:AB:D4:57:79","Channel":6,"Mode":"11n","RSSI":88,"Signal":-56,"LinkCount":14,"Downtime":"0T00:02:55"}}
and
tele/Fietsen/SENSOR = {"Time":"2022-09-18T11:21:08","Switch1":"ON","Switch2":"ON","ENERGY":{"TotalStartTime":"2022-04-17T10:26:15","Total":13.403,"Yesterday":0.090,"Today":0.000,"Period":[ 0, 0],"Power":[ 0, 0],"ApparentPower":[ 0, 0],"ReactivePower":[ 0, 0],"Factor":[0.00,0.00],"Voltage": 0,"Current":[0.000,0.000]},"ESP32":{"Temperature":57.2},"TempUnit":"C"}
When payload.ENERGY.Current[0] < 0.1 and payload.POWER1 = ON the text must be generated and displayed.
Unfortunately I can't do this, can someone tell me how to do this?
This is my flow so far:
[{"id":"a3b360bc9233ce8f","type":"tab","label":"NR Forum","disabled":false,"info":"","env":[]},{"id":"47f83ff477748825","type":"switch","z":"a3b360bc9233ce8f","name":"1 ON?","property":"payload.Switch2","propertyType":"msg","rules":[{"t":"eq","v":"ON","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":390,"y":100,"wires":[["1b35cf0f6baaa7df"]]},{"id":"1b35cf0f6baaa7df","type":"switch","z":"a3b360bc9233ce8f","name":"< 100 watt?","property":"payload.ENERGY.Current[1]","propertyType":"msg","rules":[{"t":"lt","v":"0.100","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":530,"y":100,"wires":[["639c130714546083"]]},{"id":"639c130714546083","type":"change","z":"a3b360bc9233ce8f","name":"Text","rules":[{"t":"set","p":"payload","pt":"msg","to":"Current < 0.100 and Power ON","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":670,"y":100,"wires":[["ec3b2d98358287e7"]]},{"id":"263716800d132df3","type":"mqtt in","z":"a3b360bc9233ce8f","name":"tele/Fietsen/STATE","topic":"tele/Fietsen/STATE","qos":"2","datatype":"auto-detect","broker":"41cfb26be5b19e42","nl":false,"rap":true,"rh":0,"inputs":0,"x":130,"y":140,"wires":[[]]},{"id":"436f1b8b0c791370","type":"mqtt in","z":"a3b360bc9233ce8f","name":"tele/Fietsen/SENSOR","topic":"tele/Fietsen/SENSOR","qos":"2","datatype":"auto-detect","broker":"41cfb26be5b19e42","nl":false,"rap":true,"rh":0,"inputs":0,"x":140,"y":80,"wires":[[]]},{"id":"ec3b2d98358287e7","type":"debug","z":"a3b360bc9233ce8f","name":"Show result","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":810,"y":100,"wires":[]},{"id":"41cfb26be5b19e42","type":"mqtt-broker","name":"MQTT NAS-B","broker":"192.168.2.155","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""}]
You would need to join the messages, you can use the unique topics to do this.
e.g.
[{"id":"436f1b8b0c791370","type":"mqtt in","z":"a3b360bc9233ce8f","name":"tele/Fietsen/SENSOR","topic":"tele/Fietsen/SENSOR","qos":"2","datatype":"auto-detect","broker":"41cfb26be5b19e42","nl":false,"rap":true,"rh":0,"x":140,"y":40,"wires":[["b0f06c4.3955d9"]]},{"id":"b0f06c4.3955d9","type":"join","z":"a3b360bc9233ce8f","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":270,"y":100,"wires":[["47f83ff477748825"]]},{"id":"263716800d132df3","type":"mqtt in","z":"a3b360bc9233ce8f","name":"tele/Fietsen/STATE","topic":"tele/Fietsen/STATE","qos":"2","datatype":"auto-detect","broker":"41cfb26be5b19e42","nl":false,"rap":true,"rh":0,"x":130,"y":160,"wires":[["b0f06c4.3955d9"]]},{"id":"47f83ff477748825","type":"switch","z":"a3b360bc9233ce8f","name":"1 ON?","property":"payload[\"tele/Fietsen/STATE\"].Switch2","propertyType":"msg","rules":[{"t":"eq","v":"ON","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":390,"y":100,"wires":[["1b35cf0f6baaa7df"]]},{"id":"1b35cf0f6baaa7df","type":"switch","z":"a3b360bc9233ce8f","name":"< 100 watt?","property":"payload[\"tele/Fietsen/SENSOR\"].ENERGY.Current[1]","propertyType":"msg","rules":[{"t":"lt","v":"0.100","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":530,"y":100,"wires":[["639c130714546083"]]},{"id":"639c130714546083","type":"change","z":"a3b360bc9233ce8f","name":"Text","rules":[{"t":"set","p":"payload","pt":"msg","to":"Current < 0.100 and Power ON","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":670,"y":100,"wires":[["ec3b2d98358287e7"]]},{"id":"ec3b2d98358287e7","type":"debug","z":"a3b360bc9233ce8f","name":"Show result","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":810,"y":100,"wires":[]},{"id":"41cfb26be5b19e42","type":"mqtt-broker","name":"MQTT NAS-B","broker":"192.168.2.155","port":"1883","clientid":"","usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
Thanks for helping, learning every day. With some help... :wink:
Unfortunately things are not going well, maybe I misunderstood you. Below the flow and the debug 3 and 4 output, there is no debug 5 output while the conditions (power ON and current < 0.1) are met.
Would you like to take another look?
[{"id":"26a523fefdd4341a","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"49cdfcb4852b929f","type":"mqtt in","z":"26a523fefdd4341a","name":"tele/Fietsen/SENSOR","topic":"tele/Fietsen/SENSOR","qos":"2","datatype":"auto-detect","broker":"41cfb26be5b19e42","nl":false,"rap":true,"rh":0,"inputs":0,"x":140,"y":180,"wires":[["1a394eab18482427","b0b85f463f1ee569"]]},{"id":"1a394eab18482427","type":"join","z":"26a523fefdd4341a","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":370,"y":240,"wires":[["945cf718583b56ee"]]},{"id":"5ece88a78273142c","type":"mqtt in","z":"26a523fefdd4341a","name":"tele/Fietsen/STATE","topic":"tele/Fietsen/STATE","qos":"2","datatype":"auto-detect","broker":"41cfb26be5b19e42","nl":false,"rap":true,"rh":0,"inputs":0,"x":130,"y":300,"wires":[["1a394eab18482427","36b27acc454ce23e"]]},{"id":"945cf718583b56ee","type":"switch","z":"26a523fefdd4341a","name":"1 ON?","property":"payload.POWER1","propertyType":"msg","rules":[{"t":"eq","v":"ON","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":490,"y":240,"wires":[["bfff93ad9d9dda61"]]},{"id":"bfff93ad9d9dda61","type":"switch","z":"26a523fefdd4341a","name":"< 100 watt?","property":"payload.ENERGY.Current[0]","propertyType":"msg","rules":[{"t":"lt","v":"0.100","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":630,"y":240,"wires":[["0bfb2149f6546b97"]]},{"id":"0bfb2149f6546b97","type":"change","z":"26a523fefdd4341a","name":"Text","rules":[{"t":"set","p":"payload","pt":"msg","to":"Current < 0.100 and Power ON","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":240,"wires":[["ba4a6c6941499981"]]},{"id":"b0b85f463f1ee569","type":"debug","z":"26a523fefdd4341a","name":"debug 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":380,"y":180,"wires":[]},{"id":"36b27acc454ce23e","type":"debug","z":"26a523fefdd4341a","name":"debug 4","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":380,"y":300,"wires":[]},{"id":"ba4a6c6941499981","type":"debug","z":"26a523fefdd4341a","name":"debug 5","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":900,"y":240,"wires":[]},{"id":"41cfb26be5b19e42","type":"mqtt-broker","name":"MQTT NAS-B","broker":"192.168.2.155","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""}]
You have not looked at my example fully, if you had you would see that the switch node properties are different.
payload["tele/Fietsen/STATE"].POWER1
payload["tele/Fietsen/SENSOR"].ENERGY.Current[0]
Due to the joining.
The inject node simulate your mqtt nodes.
[{"id":"2717a9ab.e2bcee","type":"inject","z":"26a523fefdd4341a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"tele/Fietsen/SENSOR","payload":"{\"Time\":\"2022-09-18T11:21:08\",\"Switch1\":\"ON\",\"Switch2\":\"ON\",\"ENERGY\":{\"TotalStartTime\":\"2022-04-17T10:26:15\",\"Total\":13.403,\"Yesterday\":0.090,\"Today\":0.000,\"Period\":[ 0, 0],\"Power\":[ 0, 0],\"ApparentPower\":[ 0, 0],\"ReactivePower\":[ 0, 0],\"Factor\":[0.00,0.00],\"Voltage\": 0,\"Current\":[0.000,0.000]},\"ESP32\":{\"Temperature\":57.2},\"TempUnit\":\"C\"}","payloadType":"json","x":100,"y":100,"wires":[["1a394eab18482427"]]},{"id":"1a394eab18482427","type":"join","z":"26a523fefdd4341a","name":"","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":370,"y":240,"wires":[["945cf718583b56ee","b0b85f463f1ee569"]]},{"id":"ed62b708.1472d","type":"inject","z":"26a523fefdd4341a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"tele/Fietsen/STATE","payload":"{\"Time\":\"2022-09-18T11:21:07\",\"Uptime\":\"0T18:50:17\",\"UptimeSec\":67817,\"Heap\":151,\"SleepMode\":\"Dynamic\",\"Sleep\":50,\"LoadAvg\":19,\"MqttCount\":14,\"Berry\":{\"HeapUsed\":3,\"Objects\":40},\"POWER1\":\"ON\",\"POWER2\":\"OFF\",\"Wifi\":{\"AP\":1,\"SSId\":\"TIS\",\"BSSId\":\"2C:91:AB:D4:57:79\",\"Channel\":6,\"Mode\":\"11n\",\"RSSI\":88,\"Signal\":-56,\"LinkCount\":14,\"Downtime\":\"0T00:02:55\"}}","payloadType":"json","x":120,"y":360,"wires":[["1a394eab18482427"]]},{"id":"945cf718583b56ee","type":"switch","z":"26a523fefdd4341a","name":"1 ON?","property":"payload[\"tele/Fietsen/STATE\"].POWER1","propertyType":"msg","rules":[{"t":"eq","v":"ON","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":490,"y":240,"wires":[["bfff93ad9d9dda61"]]},{"id":"b0b85f463f1ee569","type":"debug","z":"26a523fefdd4341a","name":"debug 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":490,"y":160,"wires":[]},{"id":"bfff93ad9d9dda61","type":"switch","z":"26a523fefdd4341a","name":"< 100 watt?","property":"payload[\"tele/Fietsen/SENSOR\"].ENERGY.Current[0]","propertyType":"msg","rules":[{"t":"lt","v":"0.100","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":630,"y":240,"wires":[["0bfb2149f6546b97"]]},{"id":"0bfb2149f6546b97","type":"change","z":"26a523fefdd4341a","name":"Text","rules":[{"t":"set","p":"payload","pt":"msg","to":"Current < 0.100 and Power ON","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":240,"wires":[["ba4a6c6941499981"]]},{"id":"ba4a6c6941499981","type":"debug","z":"26a523fefdd4341a","name":"debug 5","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":900,"y":240,"wires":[]}]
Have you looked at the results of the various STATUS commands on the Sonoff?
It is possible that you can get both values in a single message directly from Tasmota.
Unlike Tele messages, you have to request Status.
For example status 10:
Untitled 1
[{"id":"486b206dd3334970","type":"inject","z":"a32120f79694632f","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"cmnd/Fiesten/status","payload":"10","payloadType":"num","x":280,"y":120,"wires":[["1f5b6b65b060ed1f"]]},{"id":"b32364b61827573a","type":"mqtt in","z":"a32120f79694632f","name":"","topic":"stat/Fietsen/STATUS10","qos":"2","datatype":"json","broker":"41cfb26be5b19e42","nl":false,"rap":true,"rh":0,"inputs":0,"x":280,"y":160,"wires":[["7af69738603ee66c"]]},{"id":"1f5b6b65b060ed1f","type":"mqtt out","z":"a32120f79694632f","name":"","topic":"","qos":"","retain":"","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"41cfb26be5b19e42","x":530,"y":120,"wires":[]},{"id":"7af69738603ee66c","type":"debug","z":"a32120f79694632f","name":"Status","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":530,"y":160,"wires":[]},{"id":"41cfb26be5b19e42","type":"mqtt-broker","name":"MQTT NAS-B","broker":"192.168.2.155","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""}]
https://tasmota.github.io/docs/Commands/#status
Sorry, I didn't really look closely. With your help it works now, thank you very much!
[{"id":"26a523fefdd4341a","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"49cdfcb4852b929f","type":"mqtt in","z":"26a523fefdd4341a","name":"tele/Fietsen/SENSOR","topic":"tele/Fietsen/SENSOR","qos":"2","datatype":"auto-detect","broker":"41cfb26be5b19e42","nl":false,"rap":true,"rh":0,"inputs":0,"x":140,"y":200,"wires":[["1a394eab18482427"]]},{"id":"1a394eab18482427","type":"join","z":"26a523fefdd4341a","name":"Join Topics","mode":"custom","build":"object","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":true,"timeout":"","count":"2","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":350,"y":240,"wires":[["945cf718583b56ee"]]},{"id":"5ece88a78273142c","type":"mqtt in","z":"26a523fefdd4341a","name":"tele/Fietsen/STATE","topic":"tele/Fietsen/STATE","qos":"2","datatype":"auto-detect","broker":"41cfb26be5b19e42","nl":false,"rap":true,"rh":0,"inputs":0,"x":130,"y":280,"wires":[["1a394eab18482427"]]},{"id":"945cf718583b56ee","type":"switch","z":"26a523fefdd4341a","name":"1 ON?","property":"payload[\"tele/Fietsen/STATE\"].POWER1","propertyType":"msg","rules":[{"t":"eq","v":"ON","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":470,"y":300,"wires":[["bfff93ad9d9dda61"]]},{"id":"bfff93ad9d9dda61","type":"switch","z":"26a523fefdd4341a","name":"< 100 mw?","property":"payload[\"tele/Fietsen/SENSOR\"].ENERGY.Current[0]","propertyType":"msg","rules":[{"t":"lt","v":"0.100","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":590,"y":360,"wires":[["0bfb2149f6546b97"]]},{"id":"0bfb2149f6546b97","type":"change","z":"26a523fefdd4341a","name":"Text","rules":[{"t":"set","p":"payload","pt":"msg","to":"Current < 0.100 and Power ON","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":710,"y":420,"wires":[["ba4a6c6941499981"]]},{"id":"ba4a6c6941499981","type":"debug","z":"26a523fefdd4341a","name":"Show text","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":820,"y":480,"wires":[]},{"id":"41cfb26be5b19e42","type":"mqtt-broker","name":"MQTT NAS-B","broker":"192.168.2.155","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""}]
Thanks for your advice! The Dual R3 is fairly new and based on an ESP32. Flashing and working with Tasmota is not as easy as with the ESP8266 based hardware. I don't have much experience with it yet and maybe future versions of Tasmota will work better on this hardware. However, my problem has been solved with E1cid's advice.
It's nice to see that I always get good and fast help on this forum!
