Add autoreset option to delay node
Hi, often it happens to me that I need to deay a message, but if another event happens I have to push in the same delay node the new message, and I need to delete the previous one. If I don't send a reset:1 before sending the new message I'll have 2 queues in the delay node, and I don't want this.
To be sure only the previous message is delayed I always add an extra delay node on the flow, to delay the new message after a reset:1. So, briefly, in the function node I need to add an extra output which sends a reset:1, and on the main output a fixed delay node (like 10 milliseconds), that push the new message.
It would be lovely to have an option on delay node "when a new message is incoming, forget the one before waiting to be outputed".
Or maybe there is anothe way? Thanks
Does the trigger node work for this?
thanks, trigger is very powerful node! I have to keep that in mind
