Returns
(after the msg was passed along into a flow variable)
I want to drop this flow variable onto a HTML page
But when I do, my line breaks don't appear:
(ignore the fact that the names don't match, I hadn't refreshed when I took the screenshots)
I've tried putting <br> in, but I get the text <br> output instead.
I'd love some guidance on how I can pass these line returns along into my HTML template.
Thanks!
hi @mikewoodld
The problem stems from the fact line breaks are ignored in HTML by default.
There are two possible ways to fix it...
- modify your HTML template to wrap your content in
<pre></pre> tags - by default, those tags will honour the whitespace new lines in your content.
<b>Players On Ice:</b>
<pre>{{flow.homeOnIce}}</pre>
- Add html to your content (ie
<br> as you have tried), but then you must update your template to use {{{-triple-brackets-}}} - otherwise the template engine escapes HTML content:
{{{flow.homeOnIce}}}
Perfect, exactly what I was looking for. Thanks so much!
