Add property inside a XML string?
Hi.
Just wondering if it is possible in a function node to add/insert a value in the below XML txt.
I had a good read, but this is above my knowledge level. Is a function node the right node to be using for Soap HTTP header and XML body/payload ?
When i make the auth call, i want to store the session key in flow.context then be able to access it in another flow and insert it in the XML.
msg.payload = '<?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/"><soap:Body><GetVehicleSnapShots xmlns="http://onlineavl2.navmanwireless.com/0907/"><request><Session><SessionId>HOW DO I ADD PROPERTY  VALUE HERE</SessionId></Session><Version>1</Version><OwnerId>123456789</OwnerId><FetchTemperatureData>true</FetchTemperatureData><IncludeVehicleName>true</IncludeVehicleName></request></GetVehicleSnapShots></soap:Body></soap:Envelope>';
Send the payload through an XML node (to change it to a JS object) --> then a change node to change the desired property* --> then back through another XML node to convert the JS object back to XML
* use a debug node to find the path to the property you want to change
Magic. That did the trick, thanks Steve.
