Add Types to the message payload
Hey there,
I'm loving the new monaco editor that was released in node-red v2. It seems like the msg.payload now has an "any" type:
I'm wondering if there is a way that we could type the msg.payload coming in if we have more information about it. Say if we knew the msg.payload was an object with the following structure:
{name: string, age: number} is there a way we could get that to show up in the auto-complete?
Thanks!
No. Because the function node has no way of knowing what is coming. Node-red nodes have no means of telling connected nodes what they send. Even if they did, what happens if you connected 2 it more wires.
What you can do though, is use jsdoc to describe a variable & you will get auto completion. Unfortunately, this is per editor, not global.
example...
Thanks @Steve-Mcl . That's too bad but I guess just a limitation of the system for now.
Cheers,
Thomas
