Addition of 2 variables
Hi, I want to add 2 variables ¨V1¨ and¨ V2¨ that are voltage readings from 2 sensors in CA. These readings are sent via HTTP POST to node red in a STRING format, then converted to JSON, and finally extracted their value. I want to sum these 2 variables but when I do it the result is NAN
Although you have converted the data to an object, the values of the items in the object are all strings.
In the code remove the space between the parseFloat and the open (
Also, you are setting the variables to the object not the number. Just set them to msg.payload.xxx
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
