I would like to adjust my Dashboard size. Is there an option for this?. My Dashboard currently looks like this.
I would like the map to be full screen. Thank you in advance
If you edit the group node your template node is in you can change its size. There is no 'full screen' option, but you can certainly make it wider than the default.
Hey thank you for your reply. I was able to increase the length of that but I could not do in width. The default size was 6x6. And the width is fixed to 6. Can it be increased somehow?
A widget's width is limited by the width of the group it is in.
Yes thank you ver much. Very clear explanation
