another time the automatic snap update stops the instance
only revert to latest version helps and node-red runs again
how to fix the issue on my devices?
~ $ sudo snap revert node-red
node-red reverted to 1.1.3
~ $ uname -a
Linux M203-sn234 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
~ $ cat /etc/*-release
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
VERSION_CODENAME=stretch
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
$ snap info node-red
summary: Low-code programming for event-driven applications
publisher: Node-RED-Team (noderedteam✓)
contact: https://discourse.nodered.org/
license: unset
description: |
Node-RED is a Flow Based Programming tool written in node.js and using a web front end for wiring
together hardware devices, APIs and online services in new and interesting ways.
Many extra nodes are available (see http://flows.nodered.org), and can be installed via the Menu -
Manage Palette option. Due to the restrictions of snaps nodes that require extra access to files,
ports, or have a binary component, may NOT work or install correctly.
For more information see the
[README](https://github.com/dceejay/nodered.snap/blob/master/README.md).
Now based on Core18.
The edge channel contains auto-built versions of the package. The beta channel may contain
beta/next versions (when available).
commands:
- node-red.desktop-launch
- node-red.npm
services:
node-red: simple, enabled, inactive
snap-id: lwGTfxA0S0e61kiyMAuXQkq6Tvni0dYm
tracking: stable
refresh-date: today at 17:43 CET
channels:
stable: 1.2.9 2021-02-10 (673) 40MB -
candidate: ↑
beta: ↑
edge: 1.2.9 2021-02-10 (673) 40MB -
installed: 1.2.9 (673) 40MB -
syslog device 1:
Feb 10 17:43:23 M203-sn234 systemd[1]: Mounting Mount unit for node-red, revision 673...
Feb 10 17:43:23 M203-sn234 systemd[1]: Mounted Mount unit for node-red, revision 673.
Feb 10 17:43:24 M203-sn234 systemd[1]: Stopping Service for snap application node-red.node-red...
Feb 10 17:43:24 M203-sn234 node-red.node-red[18169]: 10 Feb 17:43:24 - [info] Stopping flows
Feb 10 17:43:24 M203-sn234 node-red.node-red[18169]: 10 Feb 17:43:24 - [info] [mqtt-broker:localhost] Disconnected from broker: mqtt://localhost:1883
Feb 10 17:43:24 M203-sn234 node-red.node-red[18169]: 10 Feb 17:43:24 - [info] [mqtt-broker:uv-eg] Disconnected from broker: mqtt://uv-eg:1883
Feb 10 17:43:24 M203-sn234 node-red.node-red[18169]: 10 Feb 17:43:24 - [info] Stopped flows
Feb 10 17:43:24 M203-sn234 systemd[1]: Stopped Service for snap application node-red.node-red.
Feb 10 17:43:39 M203-sn234 systemd[1]: Started Service for snap application node-red.node-red.
Feb 10 17:43:40 M203-sn234 node-red.node-red[13928]: NOW STARTING NODE-RED : /snap/node-red/673/bin/node-red -u /root/snap/node-red/673 on port 1880
Feb 10 17:43:40 M203-sn234 node-red.node-red[13928]: /snap/node-red/673/bin/node: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Feb 10 17:43:40 M203-sn234 systemd[1]: snap.node-red.node-red.service: Main process exited, code=exited, status=127/n/a
Feb 10 17:43:40 M203-sn234 systemd[1]: snap.node-red.node-red.service: Unit entered failed state.
Feb 10 17:43:40 M203-sn234 systemd[1]: snap.node-red.node-red.service: Failed with result 'exit-code'.
Feb 10 17:43:40 M203-sn234 systemd[1]: snap.node-red.node-red.service: Service hold-off time over, scheduling restart.
Feb 10 17:43:40 M203-sn234 systemd[1]: Stopped Service for snap application node-red.node-red.
Feb 10 17:43:40 M203-sn234 systemd[1]: Started Service for snap application node-red.node-red.
Feb 10 17:43:40 M203-sn234 node-red.node-red[13959]: NOW STARTING NODE-RED : /snap/node-red/673/bin/node-red -u /root/snap/node-red/673 on port 1880
Feb 10 17:43:40 M203-sn234 node-red.node-red[13959]: /snap/node-red/673/bin/node: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Feb 10 17:43:40 M203-sn234 node-red.node-red[13983]: NOW STARTING NODE-RED : /snap/node-red/673/bin/node-red -u /root/snap/node-red/673 on port 1880
Feb 10 17:43:40 M203-sn234 node-red.node-red[13983]: /snap/node-red/673/bin/node: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Feb 10 17:43:41 M203-sn234 node-red.node-red[14007]: NOW STARTING NODE-RED : /snap/node-red/673/bin/node-red -u /root/snap/node-red/673 on port 1880
Feb 10 17:43:41 M203-sn234 node-red.node-red[14007]: /snap/node-red/673/bin/node: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Feb 10 17:43:41 M203-sn234 systemd[1]: snap.node-red.node-red.service: Main process exited, code=exited, status=127/n/a
Feb 10 17:43:41 M203-sn234 systemd[1]: snap.node-red.node-red.service: Unit entered failed state.
Feb 10 17:43:41 M203-sn234 systemd[1]: snap.node-red.node-red.service: Failed with result 'exit-code'.
Feb 10 17:43:41 M203-sn234 systemd[1]: snap.node-red.node-red.service: Service hold-off time over, scheduling restart.
Feb 10 17:43:41 M203-sn234 systemd[1]: Stopped Service for snap application node-red.node-red.
Feb 10 17:43:41 M203-sn234 systemd[1]: Started Service for snap application node-red.node-red.
Feb 10 17:43:41 M203-sn234 node-red.node-red[14032]: NOW STARTING NODE-RED : /snap/node-red/673/bin/node-red -u /root/snap/node-red/673 on port 1880
Feb 10 17:43:41 M203-sn234 node-red.node-red[14032]: /snap/node-red/673/bin/node: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Feb 10 17:43:41 M203-sn234 systemd[1]: snap.node-red.node-red.service: Start request repeated too quickly.
Feb 10 17:43:41 M203-sn234 systemd[1]: Failed to start Service for snap application node-red.node-red.
Feb 10 17:43:42 M203-sn234 snapd[878]: storehelpers.go:436: cannot refresh snap "node-red": snap has no updates available
syslog device 2:
Feb 10 17:08:17 L203-sn225 systemd[1]: Mounting Mount unit for node-red, revision 673...
Feb 10 17:08:17 L203-sn225 systemd[1]: Mounted Mount unit for node-red, revision 673.
Feb 10 17:08:17 L203-sn225 systemd[1]: Stopping Service for snap application node-red.node-red...
Feb 10 17:08:17 L203-sn225 node-red.node-red[12990]: 10 Feb 17:08:17 - [info] Stopping flows
Feb 10 17:08:17 L203-sn225 node-red.node-red[12990]: 10 Feb 17:08:17 - [info] [mqtt-broker:UV Keller] Disconnected from broker: mqtt://uv-kg:1883
Feb 10 17:08:17 L203-sn225 node-red.node-red[12990]: 10 Feb 17:08:17 - [info] Stopped flows
Feb 10 17:08:17 L203-sn225 systemd[1]: Stopped Service for snap application node-red.node-red.
Feb 10 17:08:26 L203-sn225 systemd[1]: Started Service for snap application node-red.node-red.
Feb 10 17:08:27 L203-sn225 node-red.node-red[11761]: NOW STARTING NODE-RED : /snap/node-red/673/bin/node-red -u /root/snap/node-red/673 on port 1880
Feb 10 17:08:27 L203-sn225 node-red.node-red[11761]: /snap/node-red/673/bin/node: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Feb 10 17:08:27 L203-sn225 systemd[1]: snap.node-red.node-red.service: Main process exited, code=exited, status=127/n/a
Feb 10 17:08:27 L203-sn225 systemd[1]: snap.node-red.node-red.service: Unit entered failed state.
Feb 10 17:08:27 L203-sn225 systemd[1]: snap.node-red.node-red.service: Failed with result 'exit-code'.
Feb 10 17:08:27 L203-sn225 systemd[1]: snap.node-red.node-red.service: Service hold-off time over, scheduling restart.
Feb 10 17:08:27 L203-sn225 systemd[1]: Stopped Service for snap application node-red.node-red.
Feb 10 17:08:27 L203-sn225 systemd[1]: Started Service for snap application node-red.node-red.
Feb 10 17:08:27 L203-sn225 node-red.node-red[11796]: NOW STARTING NODE-RED : /snap/node-red/673/bin/node-red -u /root/snap/node-red/673 on port 1880
Feb 10 17:08:27 L203-sn225 node-red.node-red[11796]: /snap/node-red/673/bin/node: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Feb 10 17:08:27 L203-sn225 node-red.node-red[11821]: NOW STARTING NODE-RED : /snap/node-red/673/bin/node-red -u /root/snap/node-red/673 on port 1880
Feb 10 17:08:27 L203-sn225 node-red.node-red[11821]: /snap/node-red/673/bin/node: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Feb 10 17:08:28 L203-sn225 systemd[1]: snap.node-red.node-red.service: Service hold-off time over, scheduling restart.
Feb 10 17:08:28 L203-sn225 systemd[1]: Stopped Service for snap application node-red.node-red.
Feb 10 17:08:28 L203-sn225 systemd[1]: Started Service for snap application node-red.node-red.
Feb 10 17:08:28 L203-sn225 node-red.node-red[11858]: NOW STARTING NODE-RED : /snap/node-red/673/bin/node-red -u /root/snap/node-red/673 on port 1880
Feb 10 17:08:28 L203-sn225 node-red.node-red[11858]: /snap/node-red/673/bin/node: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Feb 10 17:08:28 L203-sn225 systemd[1]: snap.node-red.node-red.service: Main process exited, code=exited, status=127/n/a
Feb 10 17:08:28 L203-sn225 systemd[1]: snap.node-red.node-red.service: Unit entered failed state.
Feb 10 17:08:28 L203-sn225 systemd[1]: snap.node-red.node-red.service: Failed with result 'exit-code'.
Feb 10 17:08:28 L203-sn225 snapd[860]: storehelpers.go:436: cannot refresh snap "node-red": snap has no updates available
Feb 10 17:08:28 L203-sn225 node-red.node-red[11882]: NOW STARTING NODE-RED : /snap/node-red/673/bin/node-red -u /root/snap/node-red/673 on port 1880
Feb 10 17:08:28 L203-sn225 node-red.node-red[11882]: /snap/node-red/673/bin/node: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Feb 10 17:08:29 L203-sn225 node-red.node-red[11906]: NOW STARTING NODE-RED : /snap/node-red/673/bin/node-red -u /root/snap/node-red/673 on port 1880
Feb 10 17:08:29 L203-sn225 node-red.node-red[11906]: /snap/node-red/673/bin/node: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Feb 10 17:08:29 L203-sn225 systemd[1]: snap.node-red.node-red.service: Main process exited, code=exited, status=127/n/a
Feb 10 17:08:29 L203-sn225 systemd[1]: snap.node-red.node-red.service: Unit entered failed state.
Feb 10 17:08:29 L203-sn225 systemd[1]: snap.node-red.node-red.service: Failed with result 'exit-code'.
Feb 10 17:08:29 L203-sn225 systemd[1]: snap.node-red.node-red.service: Service hold-off time over, scheduling restart.
Feb 10 17:08:29 L203-sn225 systemd[1]: Stopped Service for snap application node-red.node-red.
Feb 10 17:08:29 L203-sn225 systemd[1]: Started Service for snap application node-red.node-red.
Feb 10 17:08:29 L203-sn225 node-red.node-red[11930]: NOW STARTING NODE-RED : /snap/node-red/673/bin/node-red -u /root/snap/node-red/673 on port 1880
Feb 10 17:08:29 L203-sn225 node-red.node-red[11930]: /snap/node-red/673/bin/node: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Feb 10 17:08:29 L203-sn225 node-red.node-red[11954]: NOW STARTING NODE-RED : /snap/node-red/673/bin/node-red -u /root/snap/node-red/673 on port 1880
Feb 10 17:08:29 L203-sn225 node-red.node-red[11954]: /snap/node-red/673/bin/node: error while loading shared libraries: libatomic.so.1: cannot open shared object file: No such file or directory
Feb 10 17:08:29 L203-sn225 systemd[1]: snap.node-red.node-red.service: Start request repeated too quickly.
Feb 10 17:08:29 L203-sn225 systemd[1]: Failed to start Service for snap application node-red.node-red.
