AI hardware for camera stream processing
I found a useful rtsp source from some older topics that works ok
rtsp://wowzaec2demo.streamlock.net/vod/mp4:BigBuckBunny_115k.mp4
I think I will add another IP CAM example (in HSS) using this. For the stimeout, what is a recommended value when using rtsp? I 'm using 1000000 microseconds (1s). Is that "a good value" or should it be longer or shorter?
It restarts after it has finished (takes around 12 min) so the recovery seems to work as expected
