Allocating one JSON to different topics
I have a JSON published from a data logger and I want to publish the data to MQTT.
Therefore I need to allocate the JSON data to different topics.
I have different types of JSON and for another type I have found a solution which works.
The difference is, that the other JSON only published data for one topic.
But this JSON publishes data for many different topics.
And now I'm looking for a solution to allocate the different data from one JSON to different topics
The JSON looks like this:
	"data": [{
		"uuid": "xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx",
		"tuples": [
			[1538155685317, 20.937]
		"uuid": "xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx",
		"tuples": [
			[1538155686127, 20.375]
		"uuid": "xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx",
		"tuples": [
			[1538155673116, 21.5]
		"uuid": "xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx",
		"tuples": [
			[1538155679647, 22.125]
		"uuid": "xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx",
		"tuples": [
			[1538155682077, 20.375]
		"uuid": "xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx",
		"tuples": [
			[1538155675547, 46.687]
		"uuid": "xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx",
		"tuples": [
			[1538155673927, 20]
		"uuid": "xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx",
		"tuples": [
			[1538155672307, 21.437]
		"uuid": "xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx",
		"tuples": [
			[1538155677168, 20]
		"uuid": "xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx",
		"tuples": [
			[1538155682887, 13.062]
		"uuid": "xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx",
		"tuples": [
			[1538155671497, 22.312]
		"uuid": "xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx",
		"tuples": [
			[1538155683697, 20.187]
And for parsing the JSON I used a function node with following Script:
var uuidMap = {
	'xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Strom/Haus'},
	'xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Strom/WärmepumpeHaupttarif'},
	'xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Strom/WärmepumpeNebentarif'},
	'xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T01Aussen'},
	'xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T02Fortluft'},
	'xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Heizung/T03Warmwasserspeicher'},
	'xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Heizung/T04WarmwasserVorlauf'},
	'xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T05Bad'},
	'xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T06LeniRauchmelder'},
	'xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T07SchlafenWand'},
	'xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T08SchlafenRauchmelder'},
	'xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T12LeniTür'},
// Parse JSON
var myJsonObj = [];
var myJsonObj = JSON.parse(msg.payload);
// Get UUID, timestamp and value
var myUuid = myJsonObj.data[0].uuid;
var myTimestamp = myJsonObj.data[0].tuples[0][0];
var myValue = myJsonObj.data[0].tuples[0][1];
if (uuidMap[myUuid] !== undefined) {
  // Create output payload
  var myOutput = {};
  myOutput.topic = uuidMap[myUuid]['topic'];
  myOutput.payload = myValue;
  return myOutput;
But the output of this script results only in one topic.
Any idea to solve the problem?
Thank you and best regards,
Chris
First of all, if your payload is a valid JSON string, pass it through a json node to make it into a single msg.payload that contains your payload with the data array. Then, use a change node to "Move" msg.payload.data to msg.payload -- now your payload is just the data array. Pass that to a split node to create 1 msg for each element of the array. Then use your function to map the topic to each incoming uuid property, and replace the payload with the one and only element of the tuples array -- so the function code can be simplified to:
var uuidMap = {
'xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/Haus',
'xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/WärmepumpeHaupttarif',
'xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/WärmepumpeNebentarif',
'xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T01Aussen',
'xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T02Fortluft',
'xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T03Warmwasserspeicher',
'xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T04WarmwasserVorlauf',
'xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T05Bad',
'xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T06LeniRauchmelder',
'xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T07SchlafenWand',
'xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T08SchlafenRauchmelder',
'xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T12LeniTür'
msg.topic = uuidMap[msg.payload.uuid];
msg.payload = msg.payload.tuples[0];
You now have each device's payload in its own msg with the proper topic... Here's the flow I used to test it:
[{"id":"436761e8.e63ed","type":"inject","z":"58c8eb7a.5496c4","name":"","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155685317,20.937]]},{\"uuid\":\"xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155686127,20.375]]},{\"uuid\":\"xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155673116,21.5]]},{\"uuid\":\"xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155679647,22.125]]},{\"uuid\":\"xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155682077,20.375]]},{\"uuid\":\"xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155675547,46.687]]},{\"uuid\":\"xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155673927,20]]},{\"uuid\":\"xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155672307,21.437]]},{\"uuid\":\"xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155677168,20]]},{\"uuid\":\"xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155682887,13.062]]},{\"uuid\":\"xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155671497,22.312]]},{\"uuid\":\"xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155683697,20.187]]}]}","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":3720,"wires":[["b4ab4bc1.5619d8"]]},{"id":"cc52e397.9f0ad","type":"split","z":"58c8eb7a.5496c4","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"topic","x":710,"y":3720,"wires":[["d8e68969.450038"]]},{"id":"3144c28a.8a5cee","type":"change","z":"58c8eb7a.5496c4","name":"","rules":[{"t":"move","p":"payload.data","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":3720,"wires":[["cc52e397.9f0ad"]]},{"id":"d8e68969.450038","type":"function","z":"58c8eb7a.5496c4","name":"map uuids to topics","func":"var uuidMap = {\n'xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/Haus',\n'xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/WärmepumpeHaupttarif',\n'xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/WärmepumpeNebentarif',\n'xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T01Aussen',\n'xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T02Fortluft',\n'xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T03Warmwasserspeicher',\n'xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T04WarmwasserVorlauf',\n'xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T05Bad',\n'xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T06LeniRauchmelder',\n'xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T07SchlafenWand',\n'xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T08SchlafenRauchmelder',\n'xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T12LeniTür'\n};\n\nmsg.topic = uuidMap[msg.payload.uuid];\nmsg.payload = msg.payload.tuples[0];\nreturn msg;","outputs":1,"noerr":0,"x":890,"y":3720,"wires":[["88d7ab50.429fc8"]]},{"id":"88d7ab50.429fc8","type":"debug","z":"58c8eb7a.5496c4","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1100,"y":3720,"wires":[]},{"id":"b4ab4bc1.5619d8","type":"json","z":"58c8eb7a.5496c4","name":"","property":"payload","action":"","pretty":false,"x":310,"y":3720,"wires":[["3144c28a.8a5cee"]]}]
FYI, for anyone that may be disappointed because I skipped an opportunity to use the JSONata hammer...
  $uuidMap := {
  payload.data.{
    $lookup($uuidMap, uuid): tuples[0]
This maps all the topics at once -- so the resulting payload array can be passed to a split node directly, using the key as the topic.
Phew. Thought you had lost it there for a moment
Hi Steve,
I tried your first suggestion.
Here is what is Looks like:
After the move node:
30.9.2018, 19:36:26node: 74ae78dd.f41eamsg.payload : Object
object
uuid: "xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx"
tuples: array[1]
0: array[3]
0: 1538328980838
1: 21.437
2: 1
After the split node:
30.9.2018, 19:36:26node: 3e140cd3.1b0d64msg : Object
object
payload: "xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx"
_session: object
type: "websocket"
parts: object
type: "object"
key: "uuid"
index: 0
count: 2
_msgid: "5a21c80c.fb8798"
and:
object
payload: array[1]
0: array[3]
0: 1538328980838
1: 21.437
2: 1
_session: object
type: "websocket"
parts: object
type: "object"
key: "tuples"
index: 1
count: 2
_msgid: "d58eabe4.3a9fe8"
I guess I made something wrong?!
I also tried the JSONata, but it also does not work.
This is a JSON:
    "data": [
            "tuples": [
                    1538329795698,
                    12.125
And this is the JSON Expression in the Change node:
  $uuidMap := {
'xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx':'Haus/Temperatur/T01Aussen',
  payload.data.{
    $lookup($uuidMap, uuid): 1
Not sure why it does not work.
Christian
Christian, it could be just a simple setting that is missing... if you want to export that part of your flow and paste it here, that would give us some clues. Just make sure to put your JSON and any code into a "code block", so it stays formatted for easier importing.
To do that, put your code between 2 lines that contain only 3 backtics -- it should look like this:
your code goes here
and here
etc.
BTW, you can try it out by editing your last posts and adding those lines for us. ;*)
Hi Steve,
to insert a code or formatting in this forum is a little bit strange, but I try it :slight_smile:
This data comes from my "VZ Push-Server".
Here is a sample sequence which does not work as intended:
        "id": "9b5659ce.2f95",
        "type": "debug",
        "z": "aac14499.e7214",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "x": 690,
        "y": 960,
        "id": "cc2b5cda.1585a",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "(\t  $uuidMap := {\t    'xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/Haus',\t    'xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/WärmepumpeHaupttarif',\t    'xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/WärmepumpeNebentarif',\t    'xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T01Aussen',\t    'xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T02Fortluft',\t    'xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T03Warmwasserspeicher',\t    'xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T04WarmwasserVorlauf',\t    'xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T05Bad',\t    'xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T06LeniRauchmelder',\t    'xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T07SchlafenWand',\t    'xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T08SchlafenRauchmelder',\t    'xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T12LeniTür'\t  };\t\t  payload.data.{\t    $lookup($uuidMap, uuid): tuples[0]\t  }\t)\t",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 500,
        "y": 960,
                "9b5659ce.2f95"
        "id": "5751c0f9.352818",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "x": 490,
        "y": 920,
        "id": "1105150.8f5bb6b",
        "type": "json",
        "property": "payload",
        "action": "",
        "pretty": false,
        "x": 330,
        "y": 920,
                "5751c0f9.352818",
                "cc2b5cda.1585a"
        "id": "2e052340.6af554",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "complete": "payload",
        "x": 350,
        "y": 880,
        "id": "21f98674.3b28fa",
        "type": "inject",
        "name": "from VZ Push-Server",
        "topic": "",
        "payload": "{\"data\":[{\"uuid\":\"xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155685317,20.937]]},{\"uuid\":\"xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155686127,20.375]]},{\"uuid\":\"xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155673116,21.5]]},{\"uuid\":\"xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155679647,22.125]]},{\"uuid\":\"xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155682077,20.375]]},{\"uuid\":\"xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155675547,46.687]]},{\"uuid\":\"xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155673927,20]]},{\"uuid\":\"xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155672307,21.437]]},{\"uuid\":\"xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155677168,20]]},{\"uuid\":\"xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155682887,13.062]]},{\"uuid\":\"xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155671497,22.312]]},{\"uuid\":\"xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538155683697,20.187]]}]}",
        "payloadType": "json",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 140,
        "y": 880,
                "2e052340.6af554",
                "1105150.8f5bb6b"
Chris
EDIT: I updated the code on 1.10.2018 10:07 !!!!!
Here is another example from another source.
This data comes from my /vzpush node, which sends different data (meter reading instead of power consumption)
        "id": "58b4a1f0.38211",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "x": 630,
        "y": 1160,
        "id": "2d338874.d09c9",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "tot": "jsonata"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 440,
        "y": 1160,
                "58b4a1f0.38211"
        "id": "cc83ff31.3b724",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "x": 430,
        "y": 1120,
        "id": "d608ad42.0cee48",
        "type": "json",
        "action": "",
        "pretty": false,
        "x": 270,
        "y": 1120,
                "cc83ff31.3b724",
                "2d338874.d09c9"
        "id": "a13bb1ff.e694e",
        "type": "debug",
        "active": false,
        "tosidebar": true,
        "console": false,
        "x": 290,
        "y": 1080,
        "id": "2b063ddf.a29fb2",
        "type": "inject",
        "name": "from /vzpush",
        "topic": "",
        "payload": "{\"_msgid\":\"91a80fdc.ad383\",\"payload\":{\"data\":[{\"uuid\":\"xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292008,20.187]]},{\"uuid\":\"xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292818,19.75]]},{\"uuid\":\"xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380279628,20.562]]},{\"uuid\":\"xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286108,21.125]]},{\"uuid\":\"xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380288744,19.437]]},{\"uuid\":\"xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282058,46.937]]},{\"uuid\":\"xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380280438,19.625]]},{\"uuid\":\"xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380278798,20.437]]},{\"uuid\":\"xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380283678,19.625]]},{\"uuid\":\"xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380289573,12.125]]},{\"uuid\":\"xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380277983,21.562]]},{\"uuid\":\"xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380290388,20.187]]},{\"uuid\":\"xxxxxxxx-cccc-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286917,20.687]]},{\"uuid\":\"xxxxxxxx-dddd-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282868,39.5]]},{\"uuid\":\"xxxxxxxx-eeee-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380287728,31.125]]},{\"uuid\":\"xxxxxxxx-ffff-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380281248,30.875]]},{\"uuid\":\"xxxxxxxx-gggg-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380285298,20.687]]},{\"uuid\":\"xxxxxxxx-hhhh-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380291198,21.187]]}]},\"req\":{\"_readableState\":{\"objectMode\":false,\"highWaterMark\":16384,\"buffer\":{\"head\":null,\"tail\":null,\"length\":0},\"length\":0,\"pipes\":null,\"pipesCount\":0,\"flowing\":true,\"ended\":true,\"endEmitted\":true,\"reading\":false,\"sync\":false,\"needReadable\":false,\"emittedReadable\":false,\"readableListening\":false,\"resumeScheduled\":false,\"destroyed\":false,\"defaultEncoding\":\"utf8\",\"awaitDrain\":0,\"readingMore\":false,\"decoder\":null,\"encoding\":null},\"readable\":false,\"domain\":null,\"_events\":{},\"_eventsCount\":0,\"socket\":\"[internal]\",\"connection\":\"[internal]\",\"httpVersionMajor\":1,\"httpVersionMinor\":1,\"httpVersion\":\"1.1\",\"complete\":true,\"headers\":{\"host\":\"127.0.0.1:1880\",\"content-type\":\"application/json\",\"accept\":\"application/json\",\"user-agent\":\"vzlogger/0.6.0 (libcurl/7.38.0 OpenSSL/1.0.1t zlib/1.2.8 libidn/1.29 libssh2/1.4.3 librtmp/2.3)\",\"content-length\":\"1805\",\"expect\":\"100-continue\"},\"rawHeaders\":[\"Host\",\"127.0.0.1:1880\",\"Content-type\",\"application/json\",\"Accept\",\"application/json\",\"User-Agent\",\"vzlogger/0.6.0 (libcurl/7.38.0 OpenSSL/1.0.1t zlib/1.2.8 libidn/1.29 libssh2/1.4.3 librtmp/2.3)\",\"Content-Length\",\"1805\",\"Expect\",\"100-continue\"],\"trailers\":{},\"rawTrailers\":[],\"upgrade\":false,\"url\":\"/vzpush\",\"method\":\"POST\",\"statusCode\":null,\"statusMessage\":null,\"client\":\"[internal]\",\"_consuming\":true,\"_dumped\":false,\"baseUrl\":\"\",\"originalUrl\":\"/vzpush\",\"_parsedUrl\":{\"protocol\":null,\"slashes\":null,\"auth\":null,\"host\":null,\"port\":null,\"hostname\":null,\"hash\":null,\"search\":null,\"query\":null,\"pathname\":\"/vzpush\",\"path\":\"/vzpush\",\"href\":\"/vzpush\",\"_raw\":\"/vzpush\"},\"params\":{},\"query\":{},\"res\":\"[internal]\",\"body\":{\"data\":[{\"uuid\":\"xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292008,20.187]]},{\"uuid\":\"xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292818,19.75]]},{\"uuid\":\"xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380279628,20.562]]},{\"uuid\":\"xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286108,21.125]]},{\"uuid\":\"xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380288744,19.437]]},{\"uuid\":\"xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282058,46.937]]},{\"uuid\":\"xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380280438,19.625]]},{\"uuid\":\"xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380278798,20.437]]},{\"uuid\":\"xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380283678,19.625]]},{\"uuid\":\"xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380289573,12.125]]},{\"uuid\":\"xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380277983,21.562]]},{\"uuid\":\"xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380290388,20.187]]},{\"uuid\":\"xxxxxxxx-cccc-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286917,20.687]]},{\"uuid\":\"xxxxxxxx-dddd-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282868,39.5]]},{\"uuid\":\"xxxxxxxx-eeee-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380287728,31.125]]},{\"uuid\":\"xxxxxxxx-ffff-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380281248,30.875]]},{\"uuid\":\"xxxxxxxx-gggg-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380285298,20.687]]},{\"uuid\":\"xxxxxxxx-hhhh-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380291198,21.187]]}]},\"_body\":true,\"_passport\":{\"instance\":{\"_key\":\"passport\",\"_strategies\":{\"session\":{\"name\":\"session\"},\"bearer\":{\"name\":\"bearer\",\"_realm\":\"Users\"},\"oauth2-client-password\":{\"name\":\"oauth2-client-password\"},\"anon\":{\"name\":\"anon\"}},\"_serializers\":[],\"_deserializers\":[],\"_infoTransformers\":[],\"_framework\":{},\"_userProperty\":\"user\",\"_sm\":{\"_key\":\"passport\"},\"strategies\":{}}},\"route\":{\"path\":\"/vzpush\",\"stack\":[{\"name\":\"cookieParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"httpMiddleware\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"corsHandler\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"metricsHandler\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"jsonParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"urlencodedParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"multipartParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"rawBodyParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"<anonymous>\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"<anonymous>\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"}],\"methods\":{\"post\":true}},\"cookies\":{},\"signedCookies\":{}},\"res\":{\"_res\":\"[internal]\"}}",
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "x": 110,
        "y": 1080,
                "a13bb1ff.e694e",
                "d608ad42.0cee48"
In the end I need a solutions for both sources, but I hope when one works then one can adapt the solution also for the second dataset.
Chris
Chris, your inject node is set to output JSON, which you are then converting back into a string by passing it to a json node... you only need the json node to convert your mqtt in string payload into a JS object. It seems to work fine if you bypass the json node and wire the inject node directly to the change node.
Hi Steve,
This is crazy: I'm running in a circle and I think I have mixed up some things. And I'm pretty sure I do not know exactly what I do at the moment. But I'm here to learn something.
Anyhow, thank you for your patience!
The first example (VZ Push-Server) never was a problem, but the second example (/vzpush) is really a problem to me.
What should I say, somethimes it seems to work, and sometimes not.
Now I realized, that it depends on what the /vzpush sends. This is not always the same.
This meany I need to explain from the front in detail.
The /vzpush sends following variants:
1.:
{"data":[{"uuid":"xxxxxxxx-0001-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425885138,13924.9]]}]}
2.:
{"data":[{"uuid":"xxxxxxxx-0004-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425891985,7.25]]}]}
3.:
{"data":[{"uuid":"xxxxxxxx-0034-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425899278,20.062]]}, {"uuid":"xxxxxxxx-0033-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425900088,19.625]]},{"uuid":"xxxxxxxx-0026-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425886648,20.5]]},{"uuid":"xxxxxxxx-0025-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425893608,21.25]]},{"uuid":"xxxxxxxx-0024-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425896039,18.875]]},{"uuid":"xxxxxxxx-0006-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425889078,46.937]]},{"uuid":"xxxxxxxx-0032-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425887458,19.562]]},{"uuid":"xxxxxxxx-0014-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425885838,20.312]]},{"uuid":"xxxxxxxx-0023-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425890698,19.5]]},{"uuid":"xxxxxxxx-0005-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425896848,9.937]]},{"uuid":"xxxxxxxx-0008-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425885028,21.437]]},{"uuid":"xxxxxxxx-0031-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425897659,20.187]]},{"uuid":"xxxxxxxx-0022-xxxx-xxxx-xxxxxxxxxxxx","tuples":[1538425894418,20.812]]},{"uuid":"xxxxxxxx-0007-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425889888,39.375]]},{"uuid":"xxxxxxxx-0018-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425895228,29.687]]},{"uuid":"xxxxxxxx-0019-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425888268,29.5]]},{"uuid":"xxxxxxxx-0020-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425892798,20.812]]},{"uuid":"xxxxxxxx-0021-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425898468,21.375]]}]}
4.:
{"data":[{"uuid":"xxxxxxxx-0003-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425943890,12330.1]]},
{"uuid":"xxxxxxxx-0002-xxxx-xxxx-xxxxxxxxxxxx","tuples":[[1538425943080,13704.1]]}]}
And I prepared the new complete mapping for all sensors/channels and made a sequence with all 4 variants in inject nodes for testing:
My text is too Long, I put it in the next post. See below!
There are two questions remaining:
  1. How to seperate the messages to following format:
    {"topic":"Haus/Heizung/T18HausRücklauf","payload":21.062,"_msgid":"c6a81ec4.8f35f"} (only topic and payload needed, _msgid I do not need) ?
  2. How to handle a UUID which is not listed in the uuidMap?
    Currently, this results in following errormessage:
    "Invalid JSONata expression: Key in object structure must evaluate to a string; got: undefined"
Chris
[{"id":"58b4a1f0.38211","type":"debug","z":"aac14499.e7214","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":510,"y":1240,"wires":[]},{"id":"2d338874.d09c9","type":"change","z":"aac14499.e7214","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"(\t  $uuidMap := {\t    'xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/Haus',\t    'xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/WärmepumpeHaupttarif',\t    'xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/WärmepumpeNebentarif',\t    'xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T01Aussen',\t    'xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T02Fortluft',\t    'xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T03Warmwasserspeicher',\t    'xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T04WarmwasserVorlauf',\t    'xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T05Bad',\t    'xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T06LeniRauchmelder',\t    'xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T07SchlafenWand',\t    'xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T08SchlafenRauchmelder',\t    'xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T12LeniTür'\t  };\t\t  payload.data.{\t    $lookup($uuidMap, uuid): tuples[0]\t  }\t)\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":1240,"wires":[["58b4a1f0.38211"]]},{"id":"a13bb1ff.e694e","type":"debug","z":"aac14499.e7214","name":"","active":false,"tosidebar":true,"console":false,"complete":"payload","x":310,"y":1080,"wires":[]},{"id":"2b063ddf.a29fb2","type":"inject","z":"aac14499.e7214","name":"from /vzpush","topic":"","payload":"{\"_msgid\":\"91a80fdc.ad383\",\"payload\":{\"data\":[{\"uuid\":\"xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292008,20.187]]},{\"uuid\":\"xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292818,19.75]]},{\"uuid\":\"xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380279628,20.562]]},{\"uuid\":\"xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286108,21.125]]},{\"uuid\":\"xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380288744,19.437]]},{\"uuid\":\"xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282058,46.937]]},{\"uuid\":\"xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380280438,19.625]]},{\"uuid\":\"xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380278798,20.437]]},{\"uuid\":\"xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380283678,19.625]]},{\"uuid\":\"xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380289573,12.125]]},{\"uuid\":\"xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380277983,21.562]]},{\"uuid\":\"xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380290388,20.187]]},{\"uuid\":\"xxxxxxxx-cccc-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286917,20.687]]},{\"uuid\":\"xxxxxxxx-dddd-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282868,39.5]]},{\"uuid\":\"xxxxxxxx-eeee-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380287728,31.125]]},{\"uuid\":\"xxxxxxxx-ffff-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380281248,30.875]]},{\"uuid\":\"xxxxxxxx-gggg-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380285298,20.687]]},{\"uuid\":\"xxxxxxxx-hhhh-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380291198,21.187]]}]},\"req\":{\"_readableState\":{\"objectMode\":false,\"highWaterMark\":16384,\"buffer\":{\"head\":null,\"tail\":null,\"length\":0},\"length\":0,\"pipes\":null,\"pipesCount\":0,\"flowing\":true,\"ended\":true,\"endEmitted\":true,\"reading\":false,\"sync\":false,\"needReadable\":false,\"emittedReadable\":false,\"readableListening\":false,\"resumeScheduled\":false,\"destroyed\":false,\"defaultEncoding\":\"utf8\",\"awaitDrain\":0,\"readingMore\":false,\"decoder\":null,\"encoding\":null},\"readable\":false,\"domain\":null,\"_events\":{},\"_eventsCount\":0,\"socket\":\"[internal]\",\"connection\":\"[internal]\",\"httpVersionMajor\":1,\"httpVersionMinor\":1,\"httpVersion\":\"1.1\",\"complete\":true,\"headers\":{\"host\":\"127.0.0.1:1880\",\"content-type\":\"application/json\",\"accept\":\"application/json\",\"user-agent\":\"vzlogger/0.6.0 (libcurl/7.38.0 OpenSSL/1.0.1t zlib/1.2.8 libidn/1.29 libssh2/1.4.3 librtmp/2.3)\",\"content-length\":\"1805\",\"expect\":\"100-continue\"},\"rawHeaders\":[\"Host\",\"127.0.0.1:1880\",\"Content-type\",\"application/json\",\"Accept\",\"application/json\",\"User-Agent\",\"vzlogger/0.6.0 (libcurl/7.38.0 OpenSSL/1.0.1t zlib/1.2.8 libidn/1.29 libssh2/1.4.3 librtmp/2.3)\",\"Content-Length\",\"1805\",\"Expect\",\"100-continue\"],\"trailers\":{},\"rawTrailers\":[],\"upgrade\":false,\"url\":\"/vzpush\",\"method\":\"POST\",\"statusCode\":null,\"statusMessage\":null,\"client\":\"[internal]\",\"_consuming\":true,\"_dumped\":false,\"baseUrl\":\"\",\"originalUrl\":\"/vzpush\",\"_parsedUrl\":{\"protocol\":null,\"slashes\":null,\"auth\":null,\"host\":null,\"port\":null,\"hostname\":null,\"hash\":null,\"search\":null,\"query\":null,\"pathname\":\"/vzpush\",\"path\":\"/vzpush\",\"href\":\"/vzpush\",\"_raw\":\"/vzpush\"},\"params\":{},\"query\":{},\"res\":\"[internal]\",\"body\":{\"data\":[{\"uuid\":\"xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292008,20.187]]},{\"uuid\":\"xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292818,19.75]]},{\"uuid\":\"xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380279628,20.562]]},{\"uuid\":\"xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286108,21.125]]},{\"uuid\":\"xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380288744,19.437]]},{\"uuid\":\"xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282058,46.937]]},{\"uuid\":\"xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380280438,19.625]]},{\"uuid\":\"xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380278798,20.437]]},{\"uuid\":\"xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380283678,19.625]]},{\"uuid\":\"xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380289573,12.125]]},{\"uuid\":\"xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380277983,21.562]]},{\"uuid\":\"xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380290388,20.187]]},{\"uuid\":\"xxxxxxxx-cccc-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286917,20.687]]},{\"uuid\":\"xxxxxxxx-dddd-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282868,39.5]]},{\"uuid\":\"xxxxxxxx-eeee-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380287728,31.125]]},{\"uuid\":\"xxxxxxxx-ffff-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380281248,30.875]]},{\"uuid\":\"xxxxxxxx-gggg-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380285298,20.687]]},{\"uuid\":\"xxxxxxxx-hhhh-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380291198,21.187]]}]},\"_body\":true,\"_passport\":{\"instance\":{\"_key\":\"passport\",\"_strategies\":{\"session\":{\"name\":\"session\"},\"bearer\":{\"name\":\"bearer\",\"_realm\":\"Users\"},\"oauth2-client-password\":{\"name\":\"oauth2-client-password\"},\"anon\":{\"name\":\"anon\"}},\"_serializers\":[],\"_deserializers\":[],\"_infoTransformers\":[],\"_framework\":{},\"_userProperty\":\"user\",\"_sm\":{\"_key\":\"passport\"},\"strategies\":{}}},\"route\":{\"path\":\"/vzpush\",\"stack\":[{\"name\":\"cookieParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"httpMiddleware\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"corsHandler\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"metricsHandler\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"jsonParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"urlencodedParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"multipartParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"rawBodyParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"<anonymous>\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"<anonymous>\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"}],\"methods\":{\"post\":true}},\"cookies\":{},\"signedCookies\":{}},\"res\":{\"_res\":\"[internal]\"}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":1080,"wires":[["a13bb1ff.e694e","2d338874.d09c9"]]},{"id":"d9cc42a5.c5641","type":"inject","z":"aac14499.e7214","name":"from /vzpush","topic":"","payload":"{\"_msgid\":\"91a80fdc.ad383\",\"payload\":{\"data\":[{\"uuid\":\"xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292008,20.187]]},{\"uuid\":\"xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292818,19.75]]},{\"uuid\":\"xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380279628,20.562]]},{\"uuid\":\"xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286108,21.125]]},{\"uuid\":\"xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380288744,19.437]]},{\"uuid\":\"xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282058,46.937]]},{\"uuid\":\"xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380280438,19.625]]},{\"uuid\":\"xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380278798,20.437]]},{\"uuid\":\"xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380283678,19.625]]},{\"uuid\":\"xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380289573,12.125]]},{\"uuid\":\"xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380277983,21.562]]},{\"uuid\":\"xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380290388,20.187]]},{\"uuid\":\"xxxxxxxx-cccc-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286917,20.687]]},{\"uuid\":\"xxxxxxxx-dddd-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282868,39.5]]},{\"uuid\":\"xxxxxxxx-eeee-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380287728,31.125]]},{\"uuid\":\"xxxxxxxx-ffff-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380281248,30.875]]},{\"uuid\":\"xxxxxxxx-gggg-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380285298,20.687]]},{\"uuid\":\"xxxxxxxx-hhhh-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380291198,21.187]]}]},\"req\":{\"_readableState\":{\"objectMode\":false,\"highWaterMark\":16384,\"buffer\":{\"head\":null,\"tail\":null,\"length\":0},\"length\":0,\"pipes\":null,\"pipesCount\":0,\"flowing\":true,\"ended\":true,\"endEmitted\":true,\"reading\":false,\"sync\":false,\"needReadable\":false,\"emittedReadable\":false,\"readableListening\":false,\"resumeScheduled\":false,\"destroyed\":false,\"defaultEncoding\":\"utf8\",\"awaitDrain\":0,\"readingMore\":false,\"decoder\":null,\"encoding\":null},\"readable\":false,\"domain\":null,\"_events\":{},\"_eventsCount\":0,\"socket\":\"[internal]\",\"connection\":\"[internal]\",\"httpVersionMajor\":1,\"httpVersionMinor\":1,\"httpVersion\":\"1.1\",\"complete\":true,\"headers\":{\"host\":\"127.0.0.1:1880\",\"content-type\":\"application/json\",\"accept\":\"application/json\",\"user-agent\":\"vzlogger/0.6.0 (libcurl/7.38.0 OpenSSL/1.0.1t zlib/1.2.8 libidn/1.29 libssh2/1.4.3 librtmp/2.3)\",\"content-length\":\"1805\",\"expect\":\"100-continue\"},\"rawHeaders\":[\"Host\",\"127.0.0.1:1880\",\"Content-type\",\"application/json\",\"Accept\",\"application/json\",\"User-Agent\",\"vzlogger/0.6.0 (libcurl/7.38.0 OpenSSL/1.0.1t zlib/1.2.8 libidn/1.29 libssh2/1.4.3 librtmp/2.3)\",\"Content-Length\",\"1805\",\"Expect\",\"100-continue\"],\"trailers\":{},\"rawTrailers\":[],\"upgrade\":false,\"url\":\"/vzpush\",\"method\":\"POST\",\"statusCode\":null,\"statusMessage\":null,\"client\":\"[internal]\",\"_consuming\":true,\"_dumped\":false,\"baseUrl\":\"\",\"originalUrl\":\"/vzpush\",\"_parsedUrl\":{\"protocol\":null,\"slashes\":null,\"auth\":null,\"host\":null,\"port\":null,\"hostname\":null,\"hash\":null,\"search\":null,\"query\":null,\"pathname\":\"/vzpush\",\"path\":\"/vzpush\",\"href\":\"/vzpush\",\"_raw\":\"/vzpush\"},\"params\":{},\"query\":{},\"res\":\"[internal]\",\"body\":{\"data\":[{\"uuid\":\"xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292008,20.187]]},{\"uuid\":\"xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292818,19.75]]},{\"uuid\":\"xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380279628,20.562]]},{\"uuid\":\"xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286108,21.125]]},{\"uuid\":\"xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380288744,19.437]]},{\"uuid\":\"xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282058,46.937]]},{\"uuid\":\"xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380280438,19.625]]},{\"uuid\":\"xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380278798,20.437]]},{\"uuid\":\"xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380283678,19.625]]},{\"uuid\":\"xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380289573,12.125]]},{\"uuid\":\"xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380277983,21.562]]},{\"uuid\":\"xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380290388,20.187]]},{\"uuid\":\"xxxxxxxx-cccc-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286917,20.687]]},{\"uuid\":\"xxxxxxxx-dddd-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282868,39.5]]},{\"uuid\":\"xxxxxxxx-eeee-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380287728,31.125]]},{\"uuid\":\"xxxxxxxx-ffff-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380281248,30.875]]},{\"uuid\":\"xxxxxxxx-gggg-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380285298,20.687]]},{\"uuid\":\"xxxxxxxx-hhhh-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380291198,21.187]]}]},\"_body\":true,\"_passport\":{\"instance\":{\"_key\":\"passport\",\"_strategies\":{\"session\":{\"name\":\"session\"},\"bearer\":{\"name\":\"bearer\",\"_realm\":\"Users\"},\"oauth2-client-password\":{\"name\":\"oauth2-client-password\"},\"anon\":{\"name\":\"anon\"}},\"_serializers\":[],\"_deserializers\":[],\"_infoTransformers\":[],\"_framework\":{},\"_userProperty\":\"user\",\"_sm\":{\"_key\":\"passport\"},\"strategies\":{}}},\"route\":{\"path\":\"/vzpush\",\"stack\":[{\"name\":\"cookieParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"httpMiddleware\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"corsHandler\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"metricsHandler\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"jsonParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"urlencodedParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"multipartParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"rawBodyParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"<anonymous>\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"<anonymous>\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"}],\"methods\":{\"post\":true}},\"cookies\":{},\"signedCookies\":{}},\"res\":{\"_res\":\"[internal]\"}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":1120,"wires":[["2d338874.d09c9","f36a2088.552a6"]]},{"id":"3b1859e2.775fbe","type":"inject","z":"aac14499.e7214","name":"from /vzpush","topic":"","payload":"{\"_msgid\":\"91a80fdc.ad383\",\"payload\":{\"data\":[{\"uuid\":\"xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292008,20.187]]},{\"uuid\":\"xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292818,19.75]]},{\"uuid\":\"xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380279628,20.562]]},{\"uuid\":\"xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286108,21.125]]},{\"uuid\":\"xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380288744,19.437]]},{\"uuid\":\"xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282058,46.937]]},{\"uuid\":\"xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380280438,19.625]]},{\"uuid\":\"xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380278798,20.437]]},{\"uuid\":\"xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380283678,19.625]]},{\"uuid\":\"xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380289573,12.125]]},{\"uuid\":\"xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380277983,21.562]]},{\"uuid\":\"xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380290388,20.187]]},{\"uuid\":\"xxxxxxxx-cccc-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286917,20.687]]},{\"uuid\":\"xxxxxxxx-dddd-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282868,39.5]]},{\"uuid\":\"xxxxxxxx-eeee-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380287728,31.125]]},{\"uuid\":\"xxxxxxxx-ffff-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380281248,30.875]]},{\"uuid\":\"xxxxxxxx-gggg-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380285298,20.687]]},{\"uuid\":\"xxxxxxxx-hhhh-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380291198,21.187]]}]},\"req\":{\"_readableState\":{\"objectMode\":false,\"highWaterMark\":16384,\"buffer\":{\"head\":null,\"tail\":null,\"length\":0},\"length\":0,\"pipes\":null,\"pipesCount\":0,\"flowing\":true,\"ended\":true,\"endEmitted\":true,\"reading\":false,\"sync\":false,\"needReadable\":false,\"emittedReadable\":false,\"readableListening\":false,\"resumeScheduled\":false,\"destroyed\":false,\"defaultEncoding\":\"utf8\",\"awaitDrain\":0,\"readingMore\":false,\"decoder\":null,\"encoding\":null},\"readable\":false,\"domain\":null,\"_events\":{},\"_eventsCount\":0,\"socket\":\"[internal]\",\"connection\":\"[internal]\",\"httpVersionMajor\":1,\"httpVersionMinor\":1,\"httpVersion\":\"1.1\",\"complete\":true,\"headers\":{\"host\":\"127.0.0.1:1880\",\"content-type\":\"application/json\",\"accept\":\"application/json\",\"user-agent\":\"vzlogger/0.6.0 (libcurl/7.38.0 OpenSSL/1.0.1t zlib/1.2.8 libidn/1.29 libssh2/1.4.3 librtmp/2.3)\",\"content-length\":\"1805\",\"expect\":\"100-continue\"},\"rawHeaders\":[\"Host\",\"127.0.0.1:1880\",\"Content-type\",\"application/json\",\"Accept\",\"application/json\",\"User-Agent\",\"vzlogger/0.6.0 (libcurl/7.38.0 OpenSSL/1.0.1t zlib/1.2.8 libidn/1.29 libssh2/1.4.3 librtmp/2.3)\",\"Content-Length\",\"1805\",\"Expect\",\"100-continue\"],\"trailers\":{},\"rawTrailers\":[],\"upgrade\":false,\"url\":\"/vzpush\",\"method\":\"POST\",\"statusCode\":null,\"statusMessage\":null,\"client\":\"[internal]\",\"_consuming\":true,\"_dumped\":false,\"baseUrl\":\"\",\"originalUrl\":\"/vzpush\",\"_parsedUrl\":{\"protocol\":null,\"slashes\":null,\"auth\":null,\"host\":null,\"port\":null,\"hostname\":null,\"hash\":null,\"search\":null,\"query\":null,\"pathname\":\"/vzpush\",\"path\":\"/vzpush\",\"href\":\"/vzpush\",\"_raw\":\"/vzpush\"},\"params\":{},\"query\":{},\"res\":\"[internal]\",\"body\":{\"data\":[{\"uuid\":\"xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292008,20.187]]},{\"uuid\":\"xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292818,19.75]]},{\"uuid\":\"xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380279628,20.562]]},{\"uuid\":\"xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286108,21.125]]},{\"uuid\":\"xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380288744,19.437]]},{\"uuid\":\"xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282058,46.937]]},{\"uuid\":\"xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380280438,19.625]]},{\"uuid\":\"xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380278798,20.437]]},{\"uuid\":\"xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380283678,19.625]]},{\"uuid\":\"xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380289573,12.125]]},{\"uuid\":\"xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380277983,21.562]]},{\"uuid\":\"xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380290388,20.187]]},{\"uuid\":\"xxxxxxxx-cccc-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286917,20.687]]},{\"uuid\":\"xxxxxxxx-dddd-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282868,39.5]]},{\"uuid\":\"xxxxxxxx-eeee-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380287728,31.125]]},{\"uuid\":\"xxxxxxxx-ffff-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380281248,30.875]]},{\"uuid\":\"xxxxxxxx-gggg-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380285298,20.687]]},{\"uuid\":\"xxxxxxxx-hhhh-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380291198,21.187]]}]},\"_body\":true,\"_passport\":{\"instance\":{\"_key\":\"passport\",\"_strategies\":{\"session\":{\"name\":\"session\"},\"bearer\":{\"name\":\"bearer\",\"_realm\":\"Users\"},\"oauth2-client-password\":{\"name\":\"oauth2-client-password\"},\"anon\":{\"name\":\"anon\"}},\"_serializers\":[],\"_deserializers\":[],\"_infoTransformers\":[],\"_framework\":{},\"_userProperty\":\"user\",\"_sm\":{\"_key\":\"passport\"},\"strategies\":{}}},\"route\":{\"path\":\"/vzpush\",\"stack\":[{\"name\":\"cookieParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"httpMiddleware\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"corsHandler\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"metricsHandler\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"jsonParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"urlencodedParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"multipartParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"rawBodyParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"<anonymous>\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"<anonymous>\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"}],\"methods\":{\"post\":true}},\"cookies\":{},\"signedCookies\":{}},\"res\":{\"_res\":\"[internal]\"}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":1160,"wires":[["2d338874.d09c9","9c257f3b.8a2458"]]},{"id":"7f272f2.f6c83d","type":"inject","z":"aac14499.e7214","name":"from /vzpush","topic":"","payload":"{\"_msgid\":\"91a80fdc.ad383\",\"payload\":{\"data\":[{\"uuid\":\"xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292008,20.187]]},{\"uuid\":\"xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292818,19.75]]},{\"uuid\":\"xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380279628,20.562]]},{\"uuid\":\"xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286108,21.125]]},{\"uuid\":\"xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380288744,19.437]]},{\"uuid\":\"xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282058,46.937]]},{\"uuid\":\"xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380280438,19.625]]},{\"uuid\":\"xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380278798,20.437]]},{\"uuid\":\"xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380283678,19.625]]},{\"uuid\":\"xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380289573,12.125]]},{\"uuid\":\"xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380277983,21.562]]},{\"uuid\":\"xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380290388,20.187]]},{\"uuid\":\"xxxxxxxx-cccc-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286917,20.687]]},{\"uuid\":\"xxxxxxxx-dddd-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282868,39.5]]},{\"uuid\":\"xxxxxxxx-eeee-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380287728,31.125]]},{\"uuid\":\"xxxxxxxx-ffff-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380281248,30.875]]},{\"uuid\":\"xxxxxxxx-gggg-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380285298,20.687]]},{\"uuid\":\"xxxxxxxx-hhhh-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380291198,21.187]]}]},\"req\":{\"_readableState\":{\"objectMode\":false,\"highWaterMark\":16384,\"buffer\":{\"head\":null,\"tail\":null,\"length\":0},\"length\":0,\"pipes\":null,\"pipesCount\":0,\"flowing\":true,\"ended\":true,\"endEmitted\":true,\"reading\":false,\"sync\":false,\"needReadable\":false,\"emittedReadable\":false,\"readableListening\":false,\"resumeScheduled\":false,\"destroyed\":false,\"defaultEncoding\":\"utf8\",\"awaitDrain\":0,\"readingMore\":false,\"decoder\":null,\"encoding\":null},\"readable\":false,\"domain\":null,\"_events\":{},\"_eventsCount\":0,\"socket\":\"[internal]\",\"connection\":\"[internal]\",\"httpVersionMajor\":1,\"httpVersionMinor\":1,\"httpVersion\":\"1.1\",\"complete\":true,\"headers\":{\"host\":\"127.0.0.1:1880\",\"content-type\":\"application/json\",\"accept\":\"application/json\",\"user-agent\":\"vzlogger/0.6.0 (libcurl/7.38.0 OpenSSL/1.0.1t zlib/1.2.8 libidn/1.29 libssh2/1.4.3 librtmp/2.3)\",\"content-length\":\"1805\",\"expect\":\"100-continue\"},\"rawHeaders\":[\"Host\",\"127.0.0.1:1880\",\"Content-type\",\"application/json\",\"Accept\",\"application/json\",\"User-Agent\",\"vzlogger/0.6.0 (libcurl/7.38.0 OpenSSL/1.0.1t zlib/1.2.8 libidn/1.29 libssh2/1.4.3 librtmp/2.3)\",\"Content-Length\",\"1805\",\"Expect\",\"100-continue\"],\"trailers\":{},\"rawTrailers\":[],\"upgrade\":false,\"url\":\"/vzpush\",\"method\":\"POST\",\"statusCode\":null,\"statusMessage\":null,\"client\":\"[internal]\",\"_consuming\":true,\"_dumped\":false,\"baseUrl\":\"\",\"originalUrl\":\"/vzpush\",\"_parsedUrl\":{\"protocol\":null,\"slashes\":null,\"auth\":null,\"host\":null,\"port\":null,\"hostname\":null,\"hash\":null,\"search\":null,\"query\":null,\"pathname\":\"/vzpush\",\"path\":\"/vzpush\",\"href\":\"/vzpush\",\"_raw\":\"/vzpush\"},\"params\":{},\"query\":{},\"res\":\"[internal]\",\"body\":{\"data\":[{\"uuid\":\"xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292008,20.187]]},{\"uuid\":\"xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292818,19.75]]},{\"uuid\":\"xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380279628,20.562]]},{\"uuid\":\"xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286108,21.125]]},{\"uuid\":\"xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380288744,19.437]]},{\"uuid\":\"xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282058,46.937]]},{\"uuid\":\"xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380280438,19.625]]},{\"uuid\":\"xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380278798,20.437]]},{\"uuid\":\"xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380283678,19.625]]},{\"uuid\":\"xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380289573,12.125]]},{\"uuid\":\"xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380277983,21.562]]},{\"uuid\":\"xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380290388,20.187]]},{\"uuid\":\"xxxxxxxx-cccc-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286917,20.687]]},{\"uuid\":\"xxxxxxxx-dddd-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282868,39.5]]},{\"uuid\":\"xxxxxxxx-eeee-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380287728,31.125]]},{\"uuid\":\"xxxxxxxx-ffff-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380281248,30.875]]},{\"uuid\":\"xxxxxxxx-gggg-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380285298,20.687]]},{\"uuid\":\"xxxxxxxx-hhhh-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380291198,21.187]]}]},\"_body\":true,\"_passport\":{\"instance\":{\"_key\":\"passport\",\"_strategies\":{\"session\":{\"name\":\"session\"},\"bearer\":{\"name\":\"bearer\",\"_realm\":\"Users\"},\"oauth2-client-password\":{\"name\":\"oauth2-client-password\"},\"anon\":{\"name\":\"anon\"}},\"_serializers\":[],\"_deserializers\":[],\"_infoTransformers\":[],\"_framework\":{},\"_userProperty\":\"user\",\"_sm\":{\"_key\":\"passport\"},\"strategies\":{}}},\"route\":{\"path\":\"/vzpush\",\"stack\":[{\"name\":\"cookieParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"httpMiddleware\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"corsHandler\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"metricsHandler\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"jsonParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"urlencodedParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"multipartParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"rawBodyParser\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"<anonymous>\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"},{\"name\":\"<anonymous>\",\"keys\":[],\"regexp\":{\"fast_star\":false,\"fast_slash\":false},\"method\":\"post\"}],\"methods\":{\"post\":true}},\"cookies\":{},\"signedCookies\":{}},\"res\":{\"_res\":\"[internal]\"}}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":1200,"wires":[["2d338874.d09c9","5d5546f5.439248"]]},{"id":"f36a2088.552a6","type":"debug","z":"aac14499.e7214","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":310,"y":1120,"wires":[]},{"id":"9c257f3b.8a2458","type":"debug","z":"aac14499.e7214","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":310,"y":1160,"wires":[]},{"id":"5d5546f5.439248","type":"debug","z":"aac14499.e7214","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":310,"y":1200,"wires":[]}]
When you copied the data to put into your inject nodes, you grabbed the entire msg object, not just the payload (which is what you are setting inside the inject nodes). So I cut out everything except the payload object.
Then, since some of your uuids are not in the uuidMap, I set a variable to be the lookup value -- if that does not exist, it just uses some other string like "unknown". This keeps the expression from throwing an exception. Good luck...
[{"id":"489785e4.77843c","type":"debug","z":"dbef1f69.ea3a3","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":610,"y":240,"wires":[]},{"id":"26f5454c.e82f4a","type":"change","z":"dbef1f69.ea3a3","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"(\t   $uuidMap := {\t       'xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/Haus',\t       'xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/WärmepumpeHaupttarif',\t       'xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/WärmepumpeNebentarif',\t       'xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T01Aussen',\t       'xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T02Fortluft',\t       'xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T03Warmwasserspeicher',\t       'xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T04WarmwasserVorlauf',\t       'xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T05Bad',\t       'xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T06LeniRauchmelder',\t       'xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T07SchlafenWand',\t       'xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T08SchlafenRauchmelder',\t       'xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T12LeniTür'\t  \t   };\t   payload.data.(\t       $key := $lookup($uuidMap, uuid);\t       {\t           ($key? $key: \"unknown\"): tuples[0] \t       }\t   )\t)\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":240,"wires":[["489785e4.77843c"]]},{"id":"124c7e05.8f2402","type":"debug","z":"dbef1f69.ea3a3","name":"","active":false,"tosidebar":true,"console":false,"complete":"payload","x":410,"y":80,"wires":[]},{"id":"2540b144.b3851e","type":"inject","z":"dbef1f69.ea3a3","name":"from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292008,20.187]]},{\"uuid\":\"xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292818,19.75]]},{\"uuid\":\"xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380279628,20.562]]},{\"uuid\":\"xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286108,21.125]]},{\"uuid\":\"xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380288744,19.437]]},{\"uuid\":\"xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282058,46.937]]},{\"uuid\":\"xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380280438,19.625]]},{\"uuid\":\"xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380278798,20.437]]},{\"uuid\":\"xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380283678,19.625]]},{\"uuid\":\"xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380289573,12.125]]},{\"uuid\":\"xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380277983,21.562]]},{\"uuid\":\"xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380290388,20.187]]},{\"uuid\":\"xxxxxxxx-cccc-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286917,20.687]]},{\"uuid\":\"xxxxxxxx-dddd-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282868,39.5]]},{\"uuid\":\"xxxxxxxx-eeee-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380287728,31.125]]},{\"uuid\":\"xxxxxxxx-ffff-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380281248,30.875]]},{\"uuid\":\"xxxxxxxx-gggg-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380285298,20.687]]},{\"uuid\":\"xxxxxxxx-hhhh-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380291198,21.187]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":80,"wires":[["124c7e05.8f2402","26f5454c.e82f4a"]]},{"id":"d5ee8673.5048f8","type":"inject","z":"dbef1f69.ea3a3","name":"from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292008,20.187]]},{\"uuid\":\"xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292818,19.75]]},{\"uuid\":\"xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380279628,20.562]]},{\"uuid\":\"xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286108,21.125]]},{\"uuid\":\"xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380288744,19.437]]},{\"uuid\":\"xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282058,46.937]]},{\"uuid\":\"xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380280438,19.625]]},{\"uuid\":\"xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380278798,20.437]]},{\"uuid\":\"xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380283678,19.625]]},{\"uuid\":\"xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380289573,12.125]]},{\"uuid\":\"xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380277983,21.562]]},{\"uuid\":\"xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380290388,20.187]]},{\"uuid\":\"xxxxxxxx-cccc-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286917,20.687]]},{\"uuid\":\"xxxxxxxx-dddd-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282868,39.5]]},{\"uuid\":\"xxxxxxxx-eeee-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380287728,31.125]]},{\"uuid\":\"xxxxxxxx-ffff-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380281248,30.875]]},{\"uuid\":\"xxxxxxxx-gggg-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380285298,20.687]]},{\"uuid\":\"xxxxxxxx-hhhh-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380291198,21.187]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":120,"wires":[["26f5454c.e82f4a","459049f2.1f0248"]]},{"id":"d250fc36.496e2","type":"inject","z":"dbef1f69.ea3a3","name":"from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292008,20.187]]},{\"uuid\":\"xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292818,19.75]]},{\"uuid\":\"xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380279628,20.562]]},{\"uuid\":\"xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286108,21.125]]},{\"uuid\":\"xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380288744,19.437]]},{\"uuid\":\"xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282058,46.937]]},{\"uuid\":\"xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380280438,19.625]]},{\"uuid\":\"xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380278798,20.437]]},{\"uuid\":\"xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380283678,19.625]]},{\"uuid\":\"xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380289573,12.125]]},{\"uuid\":\"xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380277983,21.562]]},{\"uuid\":\"xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380290388,20.187]]},{\"uuid\":\"xxxxxxxx-cccc-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286917,20.687]]},{\"uuid\":\"xxxxxxxx-dddd-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282868,39.5]]},{\"uuid\":\"xxxxxxxx-eeee-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380287728,31.125]]},{\"uuid\":\"xxxxxxxx-ffff-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380281248,30.875]]},{\"uuid\":\"xxxxxxxx-gggg-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380285298,20.687]]},{\"uuid\":\"xxxxxxxx-hhhh-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380291198,21.187]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":160,"wires":[["26f5454c.e82f4a","42daee12.5c0da"]]},{"id":"fe3eadfe.e06fd","type":"inject","z":"dbef1f69.ea3a3","name":"from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0000-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292008,20.187]]},{\"uuid\":\"xxxxxxxx-1111-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380292818,19.75]]},{\"uuid\":\"xxxxxxxx-2222-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380279628,20.562]]},{\"uuid\":\"xxxxxxxx-3333-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286108,21.125]]},{\"uuid\":\"xxxxxxxx-4444-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380288744,19.437]]},{\"uuid\":\"xxxxxxxx-5555-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282058,46.937]]},{\"uuid\":\"xxxxxxxx-6666-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380280438,19.625]]},{\"uuid\":\"xxxxxxxx-7777-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380278798,20.437]]},{\"uuid\":\"xxxxxxxx-8888-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380283678,19.625]]},{\"uuid\":\"xxxxxxxx-9999-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380289573,12.125]]},{\"uuid\":\"xxxxxxxx-aaaa-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380277983,21.562]]},{\"uuid\":\"xxxxxxxx-bbbb-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380290388,20.187]]},{\"uuid\":\"xxxxxxxx-cccc-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380286917,20.687]]},{\"uuid\":\"xxxxxxxx-dddd-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380282868,39.5]]},{\"uuid\":\"xxxxxxxx-eeee-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380287728,31.125]]},{\"uuid\":\"xxxxxxxx-ffff-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380281248,30.875]]},{\"uuid\":\"xxxxxxxx-gggg-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380285298,20.687]]},{\"uuid\":\"xxxxxxxx-hhhh-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538380291198,21.187]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":200,"wires":[["26f5454c.e82f4a","110db7e5.417428"]]},{"id":"459049f2.1f0248","type":"debug","z":"dbef1f69.ea3a3","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":410,"y":120,"wires":[]},{"id":"42daee12.5c0da","type":"debug","z":"dbef1f69.ea3a3","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":410,"y":160,"wires":[]},{"id":"110db7e5.417428","type":"debug","z":"dbef1f69.ea3a3","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":410,"y":200,"wires":[]}]
Hi Steve,
of course I copied the complete msg object, because this is was the vzpush server sends?!
This is also the same what the next node needs to handle with, or not?!
You modified the inject nodes and copied this modificated message in all four inject nodes. This makes no sense, because then all four inject nodes have the same content?!
Anyhow, I copied your adaption in my code and also used my latest 4 datasets.
The four inject nodes have the 4 latest messages of my vzpush server.
These 4 messages have different content!
And this is my main problem.
How to handle these 4 different contents with the same output needed?
All four datasets needs to output single topic/value datasets like this:
{"topic":"Haus/Heizung/T18HausRücklauf","payload":21.062,"_msgid":"c6a81ec4.8f35f"} ? (only topic and payload needed, _msgid I do not need)
I tried an additional split and json node, but this does not result in single topic/value datasets like "topic":"Haus/Heizung/T18HausRücklauf","payload":21.062,"_msgid":"c6a81ec4.8f35f"}
Here is the latest version:
[{"id":"8d894176.190608","type":"debug","z":"44c69799.54d068","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":530,"y":1560,"wires":[]},{"id":"e6fd4496.f9f74","type":"change","z":"44c69799.54d068","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"(\t   $uuidMap := {\t       'xxxxxxxx-0001-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/Haus',\t       'xxxxxxxx-0002-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/WärmepumpeHaupttarif',\t       'xxxxxxxx-0003-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/WärmepumpeNebentarif',\t       'xxxxxxxx-0004-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T01Aussen',\t       'xxxxxxxx-0005-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T02Fortluft',\t       'xxxxxxxx-0006-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T03Warmwasserspeicher',\t       'xxxxxxxx-0007-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T04WarmwasserVorlauf',\t       'xxxxxxxx-0008-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T05Bad',\t       'xxxxxxxx-0009-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T06LeniRauchmelder',\t       'xxxxxxxx-0010-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T07SchlafenWand',\t       'xxxxxxxx-0011-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T08SchlafenRauchmelder',\t       'xxxxxxxx-0012-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T09Spitzboden',\t       'xxxxxxxx-0013-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T10BadTür',\t       'xxxxxxxx-0014-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T11TemperaturServerBreadboard',\t       'xxxxxxxx-0015-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/Haus/Temperatur/T12LeniTür',\t       'xxxxxxxx-0016-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T13JoniRauchmelder',\t       'xxxxxxxx-0017-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T14JoniTür',\t       'xxxxxxxx-0018-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T15ZirkulationKüche',\t       'xxxxxxxx-0019-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T16ZirkulationBad',\t       'xxxxxxxx-0020-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T17HausVorlauf',\t       'xxxxxxxx-0021-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T18HausRücklauf',\t       'xxxxxxxx-0022-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T19KellerVorlauf',\t       'xxxxxxxx-0023-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T20KellerRücklauf',\t       'xxxxxxxx-0024-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T21ZuluftHaus',\t       'xxxxxxxx-0025-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T22AbluftHaus',\t       'xxxxxxxx-0026-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T23AbluftKeller',\t       'xxxxxxxx-0027-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T24DieleRauchmelder',\t       'xxxxxxxx-0028-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T25WohnzimmerRauchmelder',\t       'xxxxxxxx-0029-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T26EssenRauchmelder',\t       'xxxxxxxx-0030-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T27EssenTürRaumtemp',\t       'xxxxxxxx-0031-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T28BüroRauchmelder',\t       'xxxxxxxx-0032-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T29HobbyRauchmelder',\t       'xxxxxxxx-0033-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T30FlurKellerRauchmelder',\t       'xxxxxxxx-0034-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T31HWRRauchmelder',\t       'xxxxxxxx-0035-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T32FlurobenRauchmelder',\t       'xxxxxxxx-0036-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T33FlurobenWand',\t       'xxxxxxxx-0037-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T34JoniZuluftmobilerESP_3',\t       'xxxxxxxx-0038-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T35LeniZuluftmobilerESP_4',\t       'xxxxxxxx-0039-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T36SchlafenZuluftmobilerESP_5',\t       'xxxxxxxx-0040-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T37KellerabgangRauchmelder',\t       'xxxxxxxx-0041-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T38Breadboard',\t       'xxxxxxxx-0042-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T39BME280_07',\t       'xxxxxxxx-0043-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T40BME280_08',\t       'xxxxxxxx-0044-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T41BME280_01',\t       'xxxxxxxx-0045-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T42BME280_02',\t       'xxxxxxxx-0046-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T43BME280_03',\t       'xxxxxxxx-0047-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T44BME280_04',\t       'xxxxxxxx-0048-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T45BME280_05',\t       'xxxxxxxx-0049-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T46BME280_06',\t       'xxxxxxxx-0050-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_07',\t       'xxxxxxxx-0051-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_08',\t       'xxxxxxxx-0052-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_01',\t       'xxxxxxxx-0053-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_02',\t       'xxxxxxxx-0054-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_03',\t       'xxxxxxxx-0055-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_04',\t       'xxxxxxxx-0056-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_05',\t       'xxxxxxxx-0057-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_06',\t       'xxxxxxxx-0058-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_07',\t       'xxxxxxxx-0059-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_08',\t       'xxxxxxxx-0060-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_01',\t       'xxxxxxxx-0061-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_02',\t       'xxxxxxxx-0062-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_03',\t       'xxxxxxxx-0063-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_04',\t       'xxxxxxxx-0064-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_05',\t       'xxxxxxxx-0065-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_06',\t       'xxxxxxxx-0066-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/DrehzahlZuluft',\t       'xxxxxxxx-0067-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/DrehzahlAbluft',\t       'xxxxxxxx-0068-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/DrehzahlFortluft',\t       'xxxxxxxx-0069-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Wasser/Meter' \t   \t   };\t   payload.data.(\t       $key := $lookup($uuidMap, uuid);\t       {\t           ($key? $key: \"unknown\"): tuples[0] \t       \t       }\t   \t   )\t\t)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":340,"y":1560,"wires":[["8d894176.190608","6ccc649c.12dbc4"]]},{"id":"f0402de8.2b065","type":"debug","z":"44c69799.54d068","name":"","active":false,"tosidebar":true,"console":false,"complete":"payload","x":330,"y":1340,"wires":[]},{"id":"d27fc9f9.cfbc68","type":"inject","z":"44c69799.54d068","name":"1 from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0001-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425885138,13924.9]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":1340,"wires":[["f0402de8.2b065","e6fd4496.f9f74"]]},{"id":"d44e81a0.9a455","type":"inject","z":"44c69799.54d068","name":"2 from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0004-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425891985,7.25]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":1380,"wires":[["e6fd4496.f9f74","4d9c446.a51e33c"]]},{"id":"63554.3ee8e2acc","type":"inject","z":"44c69799.54d068","name":"3 from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0034-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425899278,20.062]]},{\"uuid\":\"xxxxxxxx-0033-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425900088,19.625]]},{\"uuid\":\"xxxxxxxx-0026-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425886648,20.5]]},{\"uuid\":\"xxxxxxxx-0025-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425893608,21.25]]},{\"uuid\":\"xxxxxxxx-0024-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425896039,18.875]]},{\"uuid\":\"xxxxxxxx-0006-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425889078,46.937]]},{\"uuid\":\"xxxxxxxx-0032-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425887458,19.562]]},{\"uuid\":\"xxxxxxxx-0014-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425885838,20.312]]},{\"uuid\":\"xxxxxxxx-0023-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425890698,19.5]]},{\"uuid\":\"xxxxxxxx-0005-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425896848,9.937]]},{\"uuid\":\"xxxxxxxx-0008-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425885028,21.437]]},{\"uuid\":\"xxxxxxxx-0031-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425897659,20.187]]},{\"uuid\":\"xxxxxxxx-0022-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425894418,20.812]]},{\"uuid\":\"xxxxxxxx-0007-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425889888,39.375]]},{\"uuid\":\"xxxxxxxx-0018-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425895228,29.687]]},{\"uuid\":\"xxxxxxxx-0019-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425888268,29.5]]},{\"uuid\":\"xxxxxxxx-0020-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425892798,20.812]]},{\"uuid\":\"xxxxxxxx-0021-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425898468,21.375]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":1420,"wires":[["e6fd4496.f9f74","cb4f9935.44e3a8"]]},{"id":"5b8323be.e30aec","type":"inject","z":"44c69799.54d068","name":"4 from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0003-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425943890,12330.1]]},{\"uuid\":\"xxxxxxxx-0002-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425943080,13704.1]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":1460,"wires":[["e6fd4496.f9f74","1104813c.00c16f"]]},{"id":"4d9c446.a51e33c","type":"debug","z":"44c69799.54d068","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":330,"y":1380,"wires":[]},{"id":"cb4f9935.44e3a8","type":"debug","z":"44c69799.54d068","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":330,"y":1420,"wires":[]},{"id":"1104813c.00c16f","type":"debug","z":"44c69799.54d068","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":330,"y":1460,"wires":[]},{"id":"6ccc649c.12dbc4","type":"split","z":"44c69799.54d068","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":510,"y":1600,"wires":[["bc58816f.54cd68","7d5599d3.96858"]]},{"id":"bc58816f.54cd68","type":"debug","z":"44c69799.54d068","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":670,"y":1600,"wires":[]},{"id":"7d5599d3.96858","type":"json","z":"44c69799.54d068","name":"","property":"payload","action":"","pretty":false,"x":650,"y":1640,"wires":[["bc480b1.0324f78"]]},{"id":"bc480b1.0324f78","type":"debug","z":"44c69799.54d068","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":810,"y":1640,"wires":[]}]
Well I don't know what a "vzpush" server is... but, no, by convention the data coming in to node-red is just the "payload" portion of the msg object. The node-red mqtt in (or whichever node you are using) wraps the payload into the msg object, complete with topic, msgid, etc. properties. The downstream nodes will normally just expect to operate on the payload and pass the other properties through unchanged, unless documented to expect other properties.
Whatever you put into the JSON field of the inject node will likewise get placed into the msg.payload. This is why I removed the msg "wrapper" structure from your inject nodes -- otherwise you would have your data in msg.payload.payload. But it seems that I did not finish pasting the 4 data examples you gave into my flow. Try this:
[{"id":"489785e4.77843c","type":"debug","z":"dbef1f69.ea3a3","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":610,"y":240,"wires":[]},{"id":"124c7e05.8f2402","type":"debug","z":"dbef1f69.ea3a3","name":"","active":false,"tosidebar":true,"console":false,"complete":"payload","x":410,"y":80,"wires":[]},{"id":"2540b144.b3851e","type":"inject","z":"dbef1f69.ea3a3","name":"from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0001-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425885138,13924.9]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":80,"wires":[["124c7e05.8f2402","7a731172.89e66"]]},{"id":"d5ee8673.5048f8","type":"inject","z":"dbef1f69.ea3a3","name":"from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0004-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425891985,7.25]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":120,"wires":[["459049f2.1f0248","7a731172.89e66"]]},{"id":"d250fc36.496e2","type":"inject","z":"dbef1f69.ea3a3","name":"from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0034-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425899278,20.062]]},{\"uuid\":\"xxxxxxxx-0033-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425900088,19.625]]},{\"uuid\":\"xxxxxxxx-0026-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425886648,20.5]]},{\"uuid\":\"xxxxxxxx-0025-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425893608,21.25]]},{\"uuid\":\"xxxxxxxx-0024-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425896039,18.875]]},{\"uuid\":\"xxxxxxxx-0006-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425889078,46.937]]},{\"uuid\":\"xxxxxxxx-0032-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425887458,19.562]]},{\"uuid\":\"xxxxxxxx-0014-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425885838,20.312]]},{\"uuid\":\"xxxxxxxx-0023-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425890698,19.5]]},{\"uuid\":\"xxxxxxxx-0005-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425896848,9.937]]},{\"uuid\":\"xxxxxxxx-0008-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425885028,21.437]]},{\"uuid\":\"xxxxxxxx-0031-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425897659,20.187]]},{\"uuid\":\"xxxxxxxx-0022-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425894418,20.812]]},{\"uuid\":\"xxxxxxxx-0007-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425889888,39.375]]},{\"uuid\":\"xxxxxxxx-0018-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425895228,29.687]]},{\"uuid\":\"xxxxxxxx-0019-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425888268,29.5]]},{\"uuid\":\"xxxxxxxx-0020-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425892798,20.812]]},{\"uuid\":\"xxxxxxxx-0021-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425898468,21.375]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":160,"wires":[["42daee12.5c0da","7a731172.89e66"]]},{"id":"fe3eadfe.e06fd","type":"inject","z":"dbef1f69.ea3a3","name":"from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0003-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425943890,12330.1]]},{\"uuid\":\"xxxxxxxx-0002-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425943080,13704.1]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":210,"y":200,"wires":[["110db7e5.417428","7a731172.89e66"]]},{"id":"459049f2.1f0248","type":"debug","z":"dbef1f69.ea3a3","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":410,"y":120,"wires":[]},{"id":"42daee12.5c0da","type":"debug","z":"dbef1f69.ea3a3","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":410,"y":160,"wires":[]},{"id":"110db7e5.417428","type":"debug","z":"dbef1f69.ea3a3","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":410,"y":200,"wires":[]},{"id":"7a731172.89e66","type":"change","z":"dbef1f69.ea3a3","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"(\t   $uuidMap := {\t       'xxxxxxxx-0001-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/Haus',\t       'xxxxxxxx-0002-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/WärmepumpeHaupttarif',\t       'xxxxxxxx-0003-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/WärmepumpeNebentarif',\t       'xxxxxxxx-0004-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T01Aussen',\t       'xxxxxxxx-0005-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T02Fortluft',\t       'xxxxxxxx-0006-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T03Warmwasserspeicher',\t       'xxxxxxxx-0007-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T04WarmwasserVorlauf',\t       'xxxxxxxx-0008-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T05Bad',\t       'xxxxxxxx-0009-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T06LeniRauchmelder',\t       'xxxxxxxx-0010-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T07SchlafenWand',\t       'xxxxxxxx-0011-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T08SchlafenRauchmelder',\t       'xxxxxxxx-0012-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T09Spitzboden',\t       'xxxxxxxx-0013-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T10BadTür',\t       'xxxxxxxx-0014-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T11TemperaturServerBreadboard',\t       'xxxxxxxx-0015-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/Haus/Temperatur/T12LeniTür',\t       'xxxxxxxx-0016-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T13JoniRauchmelder',\t       'xxxxxxxx-0017-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T14JoniTür',\t       'xxxxxxxx-0018-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T15ZirkulationKüche',\t       'xxxxxxxx-0019-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T16ZirkulationBad',\t       'xxxxxxxx-0020-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T17HausVorlauf',\t       'xxxxxxxx-0021-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T18HausRücklauf',\t       'xxxxxxxx-0022-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T19KellerVorlauf',\t       'xxxxxxxx-0023-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T20KellerRücklauf',\t       'xxxxxxxx-0024-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T21ZuluftHaus',\t       'xxxxxxxx-0025-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T22AbluftHaus',\t       'xxxxxxxx-0026-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T23AbluftKeller',\t       'xxxxxxxx-0027-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T24DieleRauchmelder',\t       'xxxxxxxx-0028-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T25WohnzimmerRauchmelder',\t       'xxxxxxxx-0029-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T26EssenRauchmelder',\t       'xxxxxxxx-0030-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T27EssenTürRaumtemp',\t       'xxxxxxxx-0031-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T28BüroRauchmelder',\t       'xxxxxxxx-0032-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T29HobbyRauchmelder',\t       'xxxxxxxx-0033-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T30FlurKellerRauchmelder',\t       'xxxxxxxx-0034-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T31HWRRauchmelder',\t       'xxxxxxxx-0035-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T32FlurobenRauchmelder',\t       'xxxxxxxx-0036-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T33FlurobenWand',\t       'xxxxxxxx-0037-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T34JoniZuluftmobilerESP_3',\t       'xxxxxxxx-0038-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T35LeniZuluftmobilerESP_4',\t       'xxxxxxxx-0039-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T36SchlafenZuluftmobilerESP_5',\t       'xxxxxxxx-0040-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T37KellerabgangRauchmelder',\t       'xxxxxxxx-0041-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T38Breadboard',\t       'xxxxxxxx-0042-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T39BME280_07',\t       'xxxxxxxx-0043-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T40BME280_08',\t       'xxxxxxxx-0044-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T41BME280_01',\t       'xxxxxxxx-0045-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T42BME280_02',\t       'xxxxxxxx-0046-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T43BME280_03',\t       'xxxxxxxx-0047-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T44BME280_04',\t       'xxxxxxxx-0048-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T45BME280_05',\t       'xxxxxxxx-0049-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T46BME280_06',\t       'xxxxxxxx-0050-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_07',\t       'xxxxxxxx-0051-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_08',\t       'xxxxxxxx-0052-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_01',\t       'xxxxxxxx-0053-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_02',\t       'xxxxxxxx-0054-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_03',\t       'xxxxxxxx-0055-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_04',\t       'xxxxxxxx-0056-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_05',\t       'xxxxxxxx-0057-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_06',\t       'xxxxxxxx-0058-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_07',\t       'xxxxxxxx-0059-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_08',\t       'xxxxxxxx-0060-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_01',\t       'xxxxxxxx-0061-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_02',\t       'xxxxxxxx-0062-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_03',\t       'xxxxxxxx-0063-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_04',\t       'xxxxxxxx-0064-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_05',\t       'xxxxxxxx-0065-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_06',\t       'xxxxxxxx-0066-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/DrehzahlZuluft',\t       'xxxxxxxx-0067-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/DrehzahlAbluft',\t       'xxxxxxxx-0068-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/DrehzahlFortluft',\t       'xxxxxxxx-0069-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Wasser/Meter' \t   };\t   \t   payload.data.(\t       $key := $lookup($uuidMap, uuid);\t       [{\t           ($key? $key: \"???\"): tuples[0] \t       }]\t   )\t)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":240,"wires":[["489785e4.77843c"]]}]
I also figured you would always want the results in an array, even if the input only contains 1 object. That way, you won't have to check the payload datatype to see if it's an object or an array of objects...
Hi Steve,
the "/vzpush" is a "http in"-node which receives data from my Volkszähler Smart Metering Datalogger.
The format which it sends is given, I cannot change it.
What I would like to do is sending the data to an MQTT Broker and also to a Node-RED Dashbord.
Therefore, I think it makes sense to split all the datasets into separate messages, as it is much easier to set up MQTT dashboards, Node-RED dashboard and even self programmed Arduino displays.
Meanwhile, Frank has found a solution that works for me properly.
But as I've read on the internet, is it better to use standard Node-RED nodes, rather than special coded function nodes, because (how to say?!) it has a better "flow" when it goes through the program.
When using a function node, the "flow" must be interrupted, the external code must be processed and then it comes back into the "flow" of Node-RED. (I am not sure if I have explained it so that you can understand it correctly?)
That's why I'm still looking for an alternative solution, using only your change-node instead of the function-node, even though it's already working the way I need it.
Franks solution has the correct output, but uses a function node (which I would like to avoid if possible)
Your solution has not the correct output up til now.
Here is what I have up til now:
[{"id":"7302fa5a.fb35fc","type":"debug","z":"aac14499.e7214","name":"","active":false,"tosidebar":true,"console":false,"complete":"payload","x":330,"y":1820,"wires":[]},{"id":"8db30bf8.a98f08","type":"inject","z":"aac14499.e7214","name":"1 from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0001-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425885138,13924.9]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":1820,"wires":[["7302fa5a.fb35fc","f193d955.50d8f"]]},{"id":"c718ba1b.74ba98","type":"inject","z":"aac14499.e7214","name":"2 from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0004-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425891985,7.25]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":1860,"wires":[["4e4df194.16e57","f193d955.50d8f"]]},{"id":"35d9aff6.73e3d8","type":"inject","z":"aac14499.e7214","name":"3 from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0034-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425899278,20.062]]},{\"uuid\":\"xxxxxxxx-0033-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425900088,19.625]]},{\"uuid\":\"xxxxxxxx-0026-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425886648,20.5]]},{\"uuid\":\"xxxxxxxx-0025-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425893608,21.25]]},{\"uuid\":\"xxxxxxxx-0024-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425896039,18.875]]},{\"uuid\":\"xxxxxxxx-0006-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425889078,46.937]]},{\"uuid\":\"xxxxxxxx-0032-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425887458,19.562]]},{\"uuid\":\"xxxxxxxx-0014-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425885838,20.312]]},{\"uuid\":\"xxxxxxxx-0023-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425890698,19.5]]},{\"uuid\":\"xxxxxxxx-0005-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425896848,9.937]]},{\"uuid\":\"xxxxxxxx-0008-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425885028,21.437]]},{\"uuid\":\"xxxxxxxx-0031-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425897659,20.187]]},{\"uuid\":\"xxxxxxxx-0022-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425894418,20.812]]},{\"uuid\":\"xxxxxxxx-0007-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425889888,39.375]]},{\"uuid\":\"xxxxxxxx-0018-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425895228,29.687]]},{\"uuid\":\"xxxxxxxx-0019-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425888268,29.5]]},{\"uuid\":\"xxxxxxxx-0020-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425892798,20.812]]},{\"uuid\":\"xxxxxxxx-0021-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425898468,21.375]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":1900,"wires":[["4d208feb.3858d8","f193d955.50d8f"]]},{"id":"802bf900.66516","type":"inject","z":"aac14499.e7214","name":"4 from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0003-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425943890,12330.1]]},{\"uuid\":\"xxxxxxxx-0002-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425943080,13704.1]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":1940,"wires":[["b5dd8c2b.762f7","f193d955.50d8f"]]},{"id":"4e4df194.16e57","type":"debug","z":"aac14499.e7214","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":330,"y":1860,"wires":[]},{"id":"4d208feb.3858d8","type":"debug","z":"aac14499.e7214","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":330,"y":1900,"wires":[]},{"id":"b5dd8c2b.762f7","type":"debug","z":"aac14499.e7214","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":330,"y":1940,"wires":[]},{"id":"589755ad.08c4dc","type":"comment","z":"aac14499.e7214","name":"from Frank with function node:","info":"","x":170,"y":1780,"wires":[]},{"id":"f193d955.50d8f","type":"function","z":"aac14499.e7214","name":"Format payload for MQTT only value","func":"var uuidMap = {\n       'xxxxxxxx-0001-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Strom/Haus'},\n       'xxxxxxxx-0002-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Strom/WärmepumpeHaupttarif'},\n       'xxxxxxxx-0003-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Strom/WärmepumpeNebentarif'},\n       'xxxxxxxx-0004-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T01Aussen'},\n       'xxxxxxxx-0005-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T02Fortluft'},\n       'xxxxxxxx-0006-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Heizung/T03Warmwasserspeicher'},\n       'xxxxxxxx-0007-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Heizung/T04WarmwasserVorlauf'},\n       'xxxxxxxx-0008-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T05Bad'},\n       'xxxxxxxx-0009-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T06LeniRauchmelder'},\n       'xxxxxxxx-0010-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T07SchlafenWand'},\n       'xxxxxxxx-0011-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T08SchlafenRauchmelder'},\n       'xxxxxxxx-0012-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T09Spitzboden'},\n       'xxxxxxxx-0013-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T10BadTür'},\n       'xxxxxxxx-0014-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T11TemperaturServerBreadboard'},\n       'xxxxxxxx-0015-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/Haus/Temperatur/T12LeniTür'},\n       'xxxxxxxx-0016-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T13JoniRauchmelder'},\n       'xxxxxxxx-0017-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T14JoniTür'},\n       'xxxxxxxx-0018-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Heizung/T15ZirkulationKüche'},\n       'xxxxxxxx-0019-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Heizung/T16ZirkulationBad'},\n       'xxxxxxxx-0020-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Heizung/T17HausVorlauf'},\n       'xxxxxxxx-0021-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Heizung/T18HausRücklauf'},\n       'xxxxxxxx-0022-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Heizung/T19KellerVorlauf'},\n       'xxxxxxxx-0023-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Heizung/T20KellerRücklauf'},\n       'xxxxxxxx-0024-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T21ZuluftHaus'},\n       'xxxxxxxx-0025-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T22AbluftHaus'},\n       'xxxxxxxx-0026-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T23AbluftKeller'},\n       'xxxxxxxx-0027-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T24DieleRauchmelder'},\n       'xxxxxxxx-0028-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T25WohnzimmerRauchmelder'},\n       'xxxxxxxx-0029-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T26EssenRauchmelder'},\n       'xxxxxxxx-0030-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T27EssenTürRaumtemp'},\n       'xxxxxxxx-0031-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T28BüroRauchmelder'},\n       'xxxxxxxx-0032-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T29HobbyRauchmelder'},\n       'xxxxxxxx-0033-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T30FlurKellerRauchmelder'},\n       'xxxxxxxx-0034-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T31HWRRauchmelder'},\n       'xxxxxxxx-0035-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T32FlurobenRauchmelder'},\n       'xxxxxxxx-0036-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T33FlurobenWand'},\n       'xxxxxxxx-0037-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T34JoniZuluftmobilerESP_3'},\n       'xxxxxxxx-0038-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T35LeniZuluftmobilerESP_4'},\n       'xxxxxxxx-0039-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T36SchlafenZuluftmobilerESP_5'},\n       'xxxxxxxx-0040-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T37KellerabgangRauchmelder'},\n       'xxxxxxxx-0041-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T38Breadboard'},\n       'xxxxxxxx-0042-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T39BME280_07'},\n       'xxxxxxxx-0043-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T40BME280_08'},\n       'xxxxxxxx-0044-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T41BME280_01'},\n       'xxxxxxxx-0045-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T42BME280_02'},\n       'xxxxxxxx-0046-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T43BME280_03'},\n       'xxxxxxxx-0047-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T44BME280_04'},\n       'xxxxxxxx-0048-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T45BME280_05'},\n       'xxxxxxxx-0049-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Temperatur/T46BME280_06'},\n       'xxxxxxxx-0050-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Luftfeuchtigkeit/BME280_07'},\n       'xxxxxxxx-0051-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Luftfeuchtigkeit/BME280_08'},\n       'xxxxxxxx-0052-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Luftfeuchtigkeit/BME280_01'},\n       'xxxxxxxx-0053-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Luftfeuchtigkeit/BME280_02'},\n       'xxxxxxxx-0054-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Luftfeuchtigkeit/BME280_03'},\n       'xxxxxxxx-0055-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Luftfeuchtigkeit/BME280_04'},\n       'xxxxxxxx-0056-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Luftfeuchtigkeit/BME280_05'},\n       'xxxxxxxx-0057-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Luftfeuchtigkeit/BME280_06'},\n       'xxxxxxxx-0058-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Luftdruck/BME280_07'},\n       'xxxxxxxx-0059-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Luftdruck/BME280_08'},\n       'xxxxxxxx-0060-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Luftdruck/BME280_01'},\n       'xxxxxxxx-0061-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Luftdruck/BME280_02'},\n       'xxxxxxxx-0062-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Luftdruck/BME280_03'},\n       'xxxxxxxx-0063-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Luftdruck/BME280_04'},\n       'xxxxxxxx-0064-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Luftdruck/BME280_05'},\n       'xxxxxxxx-0065-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Luftdruck/BME280_06'},\n       'xxxxxxxx-0066-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Heizung/DrehzahlZuluft'},\n       'xxxxxxxx-0067-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Heizung/DrehzahlAbluft'},\n       'xxxxxxxx-0068-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Heizung/DrehzahlFortluft'},\n       'xxxxxxxx-0069-xxxx-xxxx-xxxxxxxxxxxx':{topic:'Haus/Wasser/Meter'}\n\t}; \n\nvar outputMsgs = [];\t\n\n// loop trough data array\nmsg.payload.data.forEach(function(element) {\n    // Get UUID, timestamp and value\n    var myUuid = element.uuid;\n    var myValue = element.tuples[0][1];\n\n    if (uuidMap[myUuid] !== undefined) {\n        // Create output message\n        var myOutput = {};\n        myOutput.topic = uuidMap[myUuid]['topic'];\n        myOutput.payload = myValue;\n        outputMsgs.push(myOutput);\n    }\n});\n\nreturn [outputMsgs];","outputs":1,"noerr":0,"x":410,"y":1980,"wires":[["ce3a1827.c2346"]]},{"id":"ce3a1827.c2346","type":"debug","z":"aac14499.e7214","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":670,"y":1980,"wires":[]},{"id":"5fca2467.a3ce2c","type":"debug","z":"aac14499.e7214","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":510,"y":2260,"wires":[]},{"id":"114f8fbc.880558","type":"debug","z":"aac14499.e7214","name":"","active":false,"tosidebar":true,"console":false,"complete":"payload","x":310,"y":2100,"wires":[]},{"id":"e12f1824.fc611","type":"inject","z":"aac14499.e7214","name":"from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0001-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425885138,13924.9]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":2100,"wires":[["114f8fbc.880558","48dd57b4.bab0a8"]]},{"id":"b1fb50f7.daea78","type":"inject","z":"aac14499.e7214","name":"from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0004-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425891985,7.25]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":2140,"wires":[["9af6479d.076368","48dd57b4.bab0a8"]]},{"id":"e77ca188.6acd18","type":"inject","z":"aac14499.e7214","name":"from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0034-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425899278,20.062]]},{\"uuid\":\"xxxxxxxx-0033-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425900088,19.625]]},{\"uuid\":\"xxxxxxxx-0026-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425886648,20.5]]},{\"uuid\":\"xxxxxxxx-0025-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425893608,21.25]]},{\"uuid\":\"xxxxxxxx-0024-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425896039,18.875]]},{\"uuid\":\"xxxxxxxx-0006-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425889078,46.937]]},{\"uuid\":\"xxxxxxxx-0032-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425887458,19.562]]},{\"uuid\":\"xxxxxxxx-0014-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425885838,20.312]]},{\"uuid\":\"xxxxxxxx-0023-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425890698,19.5]]},{\"uuid\":\"xxxxxxxx-0005-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425896848,9.937]]},{\"uuid\":\"xxxxxxxx-0008-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425885028,21.437]]},{\"uuid\":\"xxxxxxxx-0031-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425897659,20.187]]},{\"uuid\":\"xxxxxxxx-0022-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425894418,20.812]]},{\"uuid\":\"xxxxxxxx-0007-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425889888,39.375]]},{\"uuid\":\"xxxxxxxx-0018-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425895228,29.687]]},{\"uuid\":\"xxxxxxxx-0019-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425888268,29.5]]},{\"uuid\":\"xxxxxxxx-0020-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425892798,20.812]]},{\"uuid\":\"xxxxxxxx-0021-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425898468,21.375]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":2180,"wires":[["7494c679.c64","48dd57b4.bab0a8"]]},{"id":"c9535c3c.6139f8","type":"inject","z":"aac14499.e7214","name":"from /vzpush","topic":"","payload":"{\"data\":[{\"uuid\":\"xxxxxxxx-0003-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425943890,12330.1]]},{\"uuid\":\"xxxxxxxx-0002-xxxx-xxxx-xxxxxxxxxxxx\",\"tuples\":[[1538425943080,13704.1]]}]}","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":110,"y":2220,"wires":[["a7ac272.c697358","48dd57b4.bab0a8"]]},{"id":"9af6479d.076368","type":"debug","z":"aac14499.e7214","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":310,"y":2140,"wires":[]},{"id":"7494c679.c64","type":"debug","z":"aac14499.e7214","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":310,"y":2180,"wires":[]},{"id":"a7ac272.c697358","type":"debug","z":"aac14499.e7214","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":310,"y":2220,"wires":[]},{"id":"48dd57b4.bab0a8","type":"change","z":"aac14499.e7214","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"(\t   $uuidMap := {\t       'xxxxxxxx-0001-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/Haus',\t       'xxxxxxxx-0002-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/WärmepumpeHaupttarif',\t       'xxxxxxxx-0003-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Strom/WärmepumpeNebentarif',\t       'xxxxxxxx-0004-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T01Aussen',\t       'xxxxxxxx-0005-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T02Fortluft',\t       'xxxxxxxx-0006-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T03Warmwasserspeicher',\t       'xxxxxxxx-0007-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T04WarmwasserVorlauf',\t       'xxxxxxxx-0008-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T05Bad',\t       'xxxxxxxx-0009-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T06LeniRauchmelder',\t       'xxxxxxxx-0010-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T07SchlafenWand',\t       'xxxxxxxx-0011-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T08SchlafenRauchmelder',\t       'xxxxxxxx-0012-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T09Spitzboden',\t       'xxxxxxxx-0013-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T10BadTür',\t       'xxxxxxxx-0014-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T11TemperaturServerBreadboard',\t       'xxxxxxxx-0015-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/Haus/Temperatur/T12LeniTür',\t       'xxxxxxxx-0016-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T13JoniRauchmelder',\t       'xxxxxxxx-0017-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T14JoniTür',\t       'xxxxxxxx-0018-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T15ZirkulationKüche',\t       'xxxxxxxx-0019-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T16ZirkulationBad',\t       'xxxxxxxx-0020-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T17HausVorlauf',\t       'xxxxxxxx-0021-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T18HausRücklauf',\t       'xxxxxxxx-0022-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T19KellerVorlauf',\t       'xxxxxxxx-0023-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/T20KellerRücklauf',\t       'xxxxxxxx-0024-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T21ZuluftHaus',\t       'xxxxxxxx-0025-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T22AbluftHaus',\t       'xxxxxxxx-0026-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T23AbluftKeller',\t       'xxxxxxxx-0027-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T24DieleRauchmelder',\t       'xxxxxxxx-0028-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T25WohnzimmerRauchmelder',\t       'xxxxxxxx-0029-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T26EssenRauchmelder',\t       'xxxxxxxx-0030-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T27EssenTürRaumtemp',\t       'xxxxxxxx-0031-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T28BüroRauchmelder',\t       'xxxxxxxx-0032-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T29HobbyRauchmelder',\t       'xxxxxxxx-0033-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T30FlurKellerRauchmelder',\t       'xxxxxxxx-0034-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T31HWRRauchmelder',\t       'xxxxxxxx-0035-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T32FlurobenRauchmelder',\t       'xxxxxxxx-0036-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T33FlurobenWand',\t       'xxxxxxxx-0037-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T34JoniZuluftmobilerESP_3',\t       'xxxxxxxx-0038-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T35LeniZuluftmobilerESP_4',\t       'xxxxxxxx-0039-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T36SchlafenZuluftmobilerESP_5',\t       'xxxxxxxx-0040-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T37KellerabgangRauchmelder',\t       'xxxxxxxx-0041-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T38Breadboard',\t       'xxxxxxxx-0042-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T39BME280_07',\t       'xxxxxxxx-0043-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T40BME280_08',\t       'xxxxxxxx-0044-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T41BME280_01',\t       'xxxxxxxx-0045-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T42BME280_02',\t       'xxxxxxxx-0046-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T43BME280_03',\t       'xxxxxxxx-0047-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T44BME280_04',\t       'xxxxxxxx-0048-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T45BME280_05',\t       'xxxxxxxx-0049-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Temperatur/T46BME280_06',\t       'xxxxxxxx-0050-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_07',\t       'xxxxxxxx-0051-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_08',\t       'xxxxxxxx-0052-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_01',\t       'xxxxxxxx-0053-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_02',\t       'xxxxxxxx-0054-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_03',\t       'xxxxxxxx-0055-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_04',\t       'xxxxxxxx-0056-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_05',\t       'xxxxxxxx-0057-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftfeuchtigkeit/BME280_06',\t       'xxxxxxxx-0058-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_07',\t       'xxxxxxxx-0059-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_08',\t       'xxxxxxxx-0060-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_01',\t       'xxxxxxxx-0061-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_02',\t       'xxxxxxxx-0062-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_03',\t       'xxxxxxxx-0063-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_04',\t       'xxxxxxxx-0064-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_05',\t       'xxxxxxxx-0065-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Luftdruck/BME280_06',\t       'xxxxxxxx-0066-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/DrehzahlZuluft',\t       'xxxxxxxx-0067-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/DrehzahlAbluft',\t       'xxxxxxxx-0068-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Heizung/DrehzahlFortluft',\t       'xxxxxxxx-0069-xxxx-xxxx-xxxxxxxxxxxx': 'Haus/Wasser/Meter' \t   };\t   \t   payload.data.(\t       $key := $lookup($uuidMap, uuid);\t       [{\t           ($key? $key: \"???\"): tuples[0] \t       }]\t   )\t)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":2260,"wires":[["5fca2467.a3ce2c"]]},{"id":"b7db1ce3.748d88","type":"comment","z":"aac14499.e7214","name":"from Steve with change node:","info":"","x":160,"y":2060,"wires":[]}]
Maybe you can modify your change node that it will output the same format than Franks solution?
Thanks a lot and best regards,
Chris
Unless you are getting messages at rates of hundreds per second there IS NO PROBLEM USING FUNCTION NODES ! The overhead is the order of 1mS on a Raspberry Pi.
By all means treat it as an intellectual exercise to do it again without a function node - but make it your exercise...
