An oldshcool gauge
Just for fun.
[{"id":"1e1a0b8d6b5f1c5a","type":"ui_template","z":"bf0d83d32eec75c2","group":"55888982bdd0637f","name":"oldscool-gauge with blue negative digits","order":6,"width":"6","height":"1","format":"<style>\n    .negative-blue .fg-num:nth-child(-n+3) {\n        color: #0052d7;\n    }\n</style>\n<div ng-init=\"init()\" id=\"{{'fg_'+$id}}\" class=\"fg-body\">\n    <div class=\"fg-display\">\n        <div class=\"fg-backplate\">\n            <div class=\"fg-numbers\">            \n            </div>\n        </div>\n        <div class=\"fg-needle\"></div>\n    </div>    \n</div>\n\n<script>\n(function(scope) {\n    //display contains those numbers. min and max will be taken from this\n    const numbers = [-3,-2,-1,0,1,2,3,4,5,6,7,8,9,10,11,12,13] \n\n    // the width of the plate must be big enough to fit all numbers.\n    // bigger plate with less numbers increases the spacing betwwen digits\n    \n    const plateSize = 600;\n    \n    //boundaries must be determined by using browser developer tools\n    //find element with class name \"fg-backplate\" and change the \"right\" property\n    //to find suitable value - left for lowest limit and right for highest limit \n    const movingLimits = {left:-132,right:435};\n    \n    const min = numbers[0];\n    const max = numbers[numbers.length-1];\n    let nums\n    let root\n    let plate\n    let lastValue = null\n    \n    scope.init = function(){\n        if($(\"#fg_\"+scope.$id).length){\n            actuallyInit()\n        }\n        else{\n            setTimeout(function(){\n                actuallyInit()\n            },40)\n        }\n    }\n\n    const range = function (n, p, a, r) {\n        if (a == \"clamp\") {\n            if (n < p.minin) { \n                n=p.minin; \n            } \n            if (n> p.maxin) {\n                n = p.maxin;\n            }\n        }\n        if (a == \"roll\") {\n            let d = p.maxin - p.minin;\n            n = ((n - p.minin) % d + d) % d + p.minin;\n        }\n        let v = ((n - p.minin) / (p.maxin - p.minin) * (p.maxout - p.minout)) + p.minout;\n        if (r) {\n            v = Math.round(v);\n        }\n        return v\n    }\n\n    const actuallyInit = function(){\n       root = $(\"#fg_\"+scope.$id)\n       nums = root.find(\".fg-numbers\")[0]\n       plate = root.find(\".fg-backplate\")\n       plate.css('width',plateSize)\n       build()\n       draw()\n    }\n\n    const build = function(){\n        numbers.forEach(n => {\n            let num = document.createElement('div')\n            num.className = 'fg-num';\n            num.textContent = n\n            nums.appendChild(num)\n        })\n    }\n    const position = function(v){        \n        const p = {minin:min, maxin:max, minout:movingLimits.left, maxout:movingLimits.right};        \n        return range(v,p,'clamp',false) + 'px';\n    }\n\n    const draw = function(){\n        if(plate && lastValue){\n            plate.css('right',position(lastValue))\n        }\n    }\n\n    scope.$watch('msg', function(msg) {\n        if (msg) { \n            lastValue = msg.payload\n            draw()\n        }\n    });\n})(scope);\n</script>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"negative-blue","x":660,"y":1020,"wires":[[]]},{"id":"e44443b8b3e42e1c","type":"inject","z":"bf0d83d32eec75c2","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"2.5","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":230,"y":1020,"wires":[["f3b778e1c2cee77f"]]},{"id":"f3b778e1c2cee77f","type":"function","z":"bf0d83d32eec75c2","name":"random","func":"function randomBetween(min, max) { // min and max included \n    return Math.random() * (max - min + 1) + min\n}\n\nmsg.payload = randomBetween(-3, 13)\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":380,"y":1020,"wires":[["1e1a0b8d6b5f1c5a"]]},{"id":"66a438e99e4a8c78","type":"ui_template","z":"bf0d83d32eec75c2","group":"55888982bdd0637f","name":"oldscool-gauge","order":6,"width":"6","height":"1","format":"<div ng-init=\"init()\" id=\"{{'fg_'+$id}}\" class=\"fg-body\">\n    <div class=\"fg-display\">\n        <div class=\"fg-backplate\">\n            <div class=\"fg-numbers\">            \n            </div>\n        </div>\n        <div class=\"fg-needle\"></div>\n    </div>    \n</div>\n\n\n<script>\n(function(scope) {\n    //display contains those numbers. min and max will be taken from this\n    const numbers = [0,10,20,30,40,50,60,70,80,90,100] \n\n    // the width of the plate must be big enough to fit all numbers.\n    // bigger plate with less numbers increases the spacing betwwen digits\n    \n    const plateSize = 600;\n    \n    //boundaries must be determined by using browser developer tools\n    //find element with class name \"fg-backplate\" and change the \"right\" property\n    //to find suitable value - left for lowest limit and right for highest limit \n    const movingLimits = {left:-132,right:435};\n    \n    const min = numbers[0];\n    const max = numbers[numbers.length-1];\n    let nums\n    let root\n    let plate\n    let lastValue = null\n    \n    scope.init = function(){\n        if($(\"#fg_\"+scope.$id).length){\n            actuallyInit()\n        }\n        else{\n            setTimeout(function(){\n                actuallyInit()\n            },40)\n        }\n    }\n\n    const range = function (n, p, a, r) {\n        if (a == \"clamp\") {\n            if (n < p.minin) { \n                n=p.minin; \n            } \n            if (n> p.maxin) {\n                n = p.maxin;\n            }\n        }\n        if (a == \"roll\") {\n            let d = p.maxin - p.minin;\n            n = ((n - p.minin) % d + d) % d + p.minin;\n        }\n        let v = ((n - p.minin) / (p.maxin - p.minin) * (p.maxout - p.minout)) + p.minout;\n        if (r) {\n            v = Math.round(v);\n        }\n        return v\n    }\n\n    const actuallyInit = function(){\n       root = $(\"#fg_\"+scope.$id)\n       nums = root.find(\".fg-numbers\")[0]\n       plate = root.find(\".fg-backplate\")\n       plate.css('width',plateSize)\n       build()\n       draw()\n    }\n\n    const build = function(){\n        numbers.forEach(n => {\n            let num = document.createElement('div')\n            num.className = 'fg-num';\n            num.textContent = n\n            nums.appendChild(num)\n        })\n    }\n    const position = function(v){        \n        const p = {minin:min, maxin:max, minout:movingLimits.left, maxout:movingLimits.right};        \n        return range(v,p,'clamp',false) + 'px';\n    }\n\n    const draw = function(){\n        if(plate && lastValue){\n            plate.css('right',position(lastValue))\n        }\n    }\n\n    scope.$watch('msg', function(msg) {\n        if (msg) { \n            lastValue = msg.payload\n            draw()\n        }\n    });\n})(scope);\n</script>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":580,"y":1060,"wires":[[]]},{"id":"5384461fccbc85cb","type":"inject","z":"bf0d83d32eec75c2","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"2","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":230,"y":1060,"wires":[["94d17c103c63e67b"]]},{"id":"94d17c103c63e67b","type":"function","z":"bf0d83d32eec75c2","name":"random","func":"function randomBetween(min, max) { // min and max included \n    return Math.random() * (max - min + 1) + min\n}\n\nmsg.payload = randomBetween(0, 100)\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":380,"y":1060,"wires":[["66a438e99e4a8c78"]]},{"id":"c8e9293339d84eb3","type":"ui_template","z":"bf0d83d32eec75c2","group":"674712f8d915bcc0","name":"oldscool-gauge-css","order":6,"width":0,"height":0,"format":"<style>\n    .fg-body {\n        position: relative;\n        width: 100%;\n        height: 100%;\n        display: flex;\n        align-content: center;\n        flex-wrap: wrap;\n    }\n\n    .fg-numbers {\n        display: flex;\n        flex-direction: row;\n        justify-content: space-between;\n        height: 30px;\n        align-content: center;\n        flex-wrap: wrap;\n    }\n\n\n    .fg-backplate {\n        width: 600px;\n        position: relative;\n        transition: 1s ease-in-out;\n    }\n\n    .fg-backplate:before {\n        content: \"\";\n        position: absolute;\n        right: 0%;\n        width: 100%;\n        top: 0px;\n        height: 25%;\n        background: linear-gradient(to right,\n                #00000050,\n                #00000050 50%,\n                transparent 50%,\n                transparent);\n        background-size: 0.6% 100%;\n    }\n\n    .fg-backplate:after {\n        content: \"Gauges by hotNipi ®\";\n        position: absolute;\n        font-size: 9px;\n        left: -90px;\n        top: 9px;\n        color: #00000080;\n    }\n\n    .fg-display {\n        width: 100%;\n        position: relative;\n        box-sizing: border-box;\n        overflow: hidden;\n        border: 3px solid black;\n        background-color: #c7c7c7;\n        outline: 1px solid #4d4d4d;\n        outline-offset: -2px;\n        border-radius: 6px;\n        box-shadow: inset 0 0 9px 1px black;\n    }\n\n    .fg-display:before,\n    .fg-display:after {\n        content: \"\";\n        position: absolute;\n        inset: 0;\n\n    }\n\n    .fg-display:before {\n        background: linear-gradient(270deg, #000000b0, transparent 20%);\n    }\n\n    .fg-display:after {\n        background: linear-gradient(90deg, #000000b0, transparent 20%);\n    }\n\n    .fg-num {\n        position: relative;\n        text-align: center;\n        top: 3px;\n        width: 30px;\n        color: black;\n    }\n\n    .fg-needle {\n        position: absolute;\n        left: calc(50% - 1px);\n        top: 1px;\n        width: 2px;\n        height: 21px;\n        background-color: #eb1e1e;\n        box-shadow: 0px 0px 7px 2px #0000008c;\n    }\n</style>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"global","className":"","x":590,"y":980,"wires":[[]]},{"id":"55888982bdd0637f","type":"ui_group","name":"1. group","tab":"62083694d0eab7ca","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"674712f8d915bcc0","type":"ui_group","name":"1. group","tab":"8482b305c416b850","order":1,"disp":true,"width":"6","collapse":true,"className":"ordered-1"},{"id":"62083694d0eab7ca","type":"ui_tab","name":"Home","icon":"dashboard","order":1,"disabled":false,"hidden":false},{"id":"8482b305c416b850","type":"ui_tab","name":"Away","icon":"dashboard","disabled":false,"hidden":false}]
One more beautiful than the other, compliments!
Are these @hotNipi gauges on Amazon yet?
:stuck_out_tongue_winking_eye:
You are too good. I liked the Mechanical display also very much.
Now your next project I am sure is this :smiley:
7w2J
a3242f54507275923fa8d0eed140e6fb
I tried but the refused cos it is priceless. But I have more analog gauges to try.
