&& and || can not be combined?
HI and sorry
I need again help to figure out a maybe syntax problem
if( a=="1" || b=="10" || c=="100"){ ......... working, :grinning:
if( (a=="1" || b=="10" || c=="100") && d >1000){ ........is not working.
do I have a bracket problem? :thinking:
THX
does changing it to (d>1000) do anything?
Is a,b,c and d a string or an number?
With a=="1" you a comparing a string, not a number.
d >1000 can only works with a number.
Maybe you can show where the values are coming from and what type variable they are.
if( (a==1 || b==10 || c==100) && d > 1000){
this works if all your variable are number
@ edje11
a, b c are strings coming von mqtt,
d is a counter so it is a number
@cymplecy
no no change, not working
This code works fine:
let a="2";
let b="3";
let c="100";
let d=1001;
    msg.payload = "OK";
If you then change to this, you won't see ok in the debug so this code is working
let a="2";
let b="3";
let c="100";
let d=1000;
    msg.payload = "OK";
To be sure, stick this into your function.
node.warn("a is "+typeof a +", b is "+typeof b +", c is "+typeof c +", d is "+typeof d)
Thanks for the tip with node.warn. My if syntax is correct only a value is a number instead of a string. So I have two strings and two numbers. With this knowledge my function is running and learned something new again!
THX
