Hi Guys. I use Node Red with Home Assistant but i dont think this is a Home Assistant issue and i am not getting anywhere on the forums to resolve. Hoping someone here could help.
I am. trying to Open Plex on my Amazon FireTV Cube. using the command {"command":"Home"} does take my Cube to the home screen. however using {"command":"Plex"} does nothing. Anyone have any ideas?
[{"id":"dbf063a40ab18e58","type":"tab","label":"Flow 2","disabled":false,"info":"","env":[]},{"id":"807624afc0f83d0c","type":"server-state-changed","z":"dbf063a40ab18e58","name":"Living Room Mode Plex Time","server":"7742f894.e9abc8","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.living_room_mode_plex","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":180,"y":40,"wires":[["88da0857df75cfd2"],[]]},{"id":"88da0857df75cfd2","type":"api-call-service","z":"dbf063a40ab18e58","name":"Open Plex","server":"7742f894.e9abc8","version":5,"debugenabled":true,"domain":"androidtv","service":"adb_command","areaId":[],"deviceId":["e3a951caf0e47b3fd5e6581c40bdae14"],"entityId":[],"data":"{\"command\":\"Plex\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":410,"y":80,"wires":[[]]},{"id":"7742f894.e9abc8","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30,"areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
