[Announce] node-red-contrib-image-tools - updated v1.3.1
It should. Could you do me a favour. Capture the data from mqtt and put in in an inject (or separate file) and send me your flow?
I won't have time at the moment but I'd like to see what's going on.
Ta.
Edit...
Post it as an issue if you don't mind.
Copy of it here
https://pastebin.com/7dtSC4JF
Hi all,
significant updates to node-red-contrib-image-tools
Many fixes and improvements (and latest + greatest version of Jimp / zxing) but in particular the barcode decoding now supports may more formats...
Demo...
Unfortunately, this is a breaking change - so anyone using the old "2D Barcode Decode" node - please read below...
IMPORTANT - Breaking changes in V1
Version 1 has breaking change ~ vs ~ V0.x versions.
Existing flows using the "2D Barcode Decode" node will need to be modified. The easy way of fixing this is to delete any "2D Barchode Decode" & deploy, then update the node, then re-add the new "Barcode Decode" nodes.
Alternatively, you can avoid this issue by performing the following steps...
  1. Upgrade node-red-contrib-image-tools
  2. Stop node-red
  3. Make a bakup of your flow.json file
  4. Opening your flow.json file in a text editor
  5. Search / replace all instances of "type":"2D Barcode Decoder" with "type":"Barcode Decoder"
  6. Save and close your flow file
  7. Start node-red
sorry folks but I have to break eggs to make the omelette.
Another update. Added UI options to the Barcode Decoder node to simplify user operation
This serves as both a visual clue (of supported formats) and simplifies operation.
Other updates...
  • dont throw error when barcode not found
  • better visual clues (improved node status)
  • documentation update
  • better defaults (faster barcode decoding)
Version bump V1.3.1
  • Adds multiline text printing (something not native to Jimp)
  • Updated examples
  • Updated help info
This is really nice. I installed it and it worked right away!
Is it possible to display the image on the Dashboard group?
Thanks,
Stonez56
Yes.
See this post as an example...
It worked like a charm!
Thanks for this great contribution!
Stonez56
