Object Detection using node-red-contrib-tfjs-coco-ssd
Hi all ,
i try to use @dceejay node-red-contrib-tfjs-coco-ssd to detect object in picture with the example attached :
[{"id":"a2e68203.7be26","type":"tensorflowCoco","z":"d0cece46.87ac6","name":"","model":"","x":510,"y":1160,"wires":[["f7c2654b.8582b8","92bee663.a421b8","19ca5cc7.3b49d3"]]},{"id":"f7c2654b.8582b8","type":"debug","z":"d0cece46.87ac6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":810,"y":1200,"wires":[]},{"id":"92bee663.a421b8","type":"debug","z":"d0cece46.87ac6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"classes","targetType":"msg","x":810,"y":1240,"wires":[]},{"id":"69f3ad28.a4b994","type":"base64","z":"d0cece46.87ac6","name":"","action":"str","property":"payload","x":500,"y":1100,"wires":[["a4ad37b6.b74438"]]},{"id":"a4ad37b6.b74438","type":"template","z":"d0cece46.87ac6","name":"","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"<img width=\"320px\" height=\"240px\" src=\"data:image/jpg;base64,{{{payload}}}\">","output":"str","x":640,"y":1100,"wires":[["b54432f0.8059a"]]},{"id":"b54432f0.8059a","type":"ui_template","z":"d0cece46.87ac6","group":"aef761dd.7e9dd","name":"","order":2,"width":7,"height":5,"format":"<div ng-bind-html=\"msg.payload\"></div>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":800,"y":1100,"wires":[[]]},{"id":"19ca5cc7.3b49d3","type":"ui_table","z":"d0cece46.87ac6","group":"aef761dd.7e9dd","name":"","order":15,"width":9,"height":3,"columns":[],"outputs":0,"cts":false,"x":790,"y":1160,"wires":[]},{"id":"dd9cd04b.d370a","type":"http request","z":"d0cece46.87ac6","name":"","method":"GET","ret":"bin","paytoqs":false,"url":"https://loremflickr.com/320/240/sport","tls":"","persist":false,"proxy":"","authType":"","x":330,"y":1100,"wires":[["a2e68203.7be26","69f3ad28.a4b994"]]},{"id":"9c31f01c.dd7c4","type":"ui_button","z":"d0cece46.87ac6","name":"","group":"aef761dd.7e9dd","order":13,"width":7,"height":1,"passthru":false,"label":"New Picture","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":170,"y":1100,"wires":[["dd9cd04b.d370a"]]},{"id":"aef761dd.7e9dd","type":"ui_group","z":"","name":"Object detection","tab":"3dce94d.cb4316c","disp":true,"width":"9","collapse":false},{"id":"3dce94d.cb4316c","type":"ui_tab","z":"","name":"Home","icon":"dashboard"}]
The readme is like this :
A Node-RED node for Object Detection using TensorFlowJS CoCo SSD.
NOTE : Tensorflow.js is only available on certain OS/Hardware/processor combinations. It does not autimatically install/work on all platforms. You may be unlucky.
The installation with the palette went well with the addition of the ui-table node. But I have this error:
Error: Cannot find module 'C:\Users\christian\.Node-RED-Desktop\node_modules\@tensorflow\tfjs-node\lib\napi-v4\tfjs_binding.node'Require stack:- C:\Users\christian\.Node-RED-Desktop\node_modules\@tensorflow\tfjs-node\dist\index.js- C:\Users\christian\.Node-RED-Desktop\node_modules\node-red-contrib-tfjs-coco-ssd\tfjs.js- C:\Users\christian\AppData\Local\Programs\node-red-desktop\resources\app.asar\node_modules\@node-red\registry\lib\loader.js- C:\Users\christian\AppData\Local\Programs\node-red-desktop\resources\app.asar\node_modules\@node-red\registry\lib\index.js- C:\Users\christian\AppData\Local\Programs\node-red-desktop\resources\app.asar\node_modules\@node-red\runtime\lib\nodes\index.js- C:\Users\christian\AppData\Local\Programs\node-red-desktop\resources\app.asar\node_modules\@node-red\runtime\lib\index.js- C:\Users\christian\AppData\Local\Programs\node-red-desktop\resources\app.asar\main\node-red.js- C:\Users\christian\AppData\Local\Programs\node-red-desktop\resources\app.asar\main\config-manager.js- C:\Users\christian\AppData\Local\Programs\node-red-desktop\resources\app.asar\main\main.js-
Is something missing from the installation, or am I just "out of luck"?
Should I install node-red-contrib-tfjs? I can't find it in the manage palette.
P.S. I use Node-Red Desktop on Win10 64Bits (NR version v1.0.3, Node.js v12.8.1)
[EDIT] Compatible material
To date, here is the list of devices compatible and not, with this node (this list will be updated according to future testers) :
  • Raspberry PI 3B and 3B+
  • Mac
  • Lenovo with Debian
  • WIN10 PC with nodejs : v12.16.1 & npm : 6.13.4
Unsupported hardware (at the time of this writing)
  • Pi Zero W
  • NVIDIA jetson Nano
Nice!!!
I did just install the node (and the ui_table that I didn't have installed already)
Very impressive I must say. On a Pi3 it takes just around 1000 ms for the node to analyze the picture for objects. That is by far the best I have seen on a Pi!!!
The node also supports pictures delivered via mqtt. Next, I have to try this on one of my Nvidia Jetson Nano where I have the GPU waiting for this
EDIT: This failed, same error as Christian (@SuperNinja) reported above, seems not to be compatible with the Nvidia platform
Challenge, would be nice to have a rectangle overlayed in the picture representing the box coordinates
This is what i'm working on :yum:! Screenshot_20200311-075403|690x388, 50%
:clap:
Very nice!!!
Myself, trying to figure out how to make this work with a GPU. I have the Nvidia stuff and expect it should increase performance rather significant (if I will figure out).
Tried it already also with an old laptop running debian, analyze is ready in approx 200 ms
Challenge : rectangle overlayed in the picture : NEED HELP !
In this test i display only the first class
As you can see the "person" is detected, the box displayed BUT the picture flash 1ms and disapear !
[{"id":"24bd5862.38b1b8","type":"ui_template","z":"a8b1b208.7036f","group":"7c26c8d0.c1e658","name":"highlightPict","order":2,"width":9,"height":6,"format":"<!DOCTYPE html>\n<html>\n<style type=\"text/css\"> \n.wrapper {\n    position:relative;\n    width:320px;\n    height:240px;\n    border:2px solid grey;\n}\n\n.box {\n    position:absolute;\n    top:{{msg.y}}px;\n    left:{{msg.x}}px;\n    width:{{msg.width}}px;\n    height:{{msg.height}}px;\n    border:2px solid red;\n    background-color:transparent\n}\n </style> \n<body>\n\n\n<div class=\"wrapper\">\n     <img src=\"data:image/jpg;base64,{{msg.payload}}\"  />\n     <div class=\"box\"></div>\n</div>\n</body>\n</html>\n\n\n\n<!--\n//////////////////////////////////////////////////////////////////////////////\n<!DOCTYPE html>\n<html>\n<head>\n<style> \n#example1 {\n  background-image: url(data:image/jpg;base64,{{msg.payload}});\n  border: 1px solid blue;  \n  background-size:auto 100% ;\n  background-repeat: no-repeat;\n  /*\n}\nhttp://newscrane.com/wp-content/uploads/2019/09/Car-insurance-Newscrane-02.jpg\nsvg {\n border: 1px solid green;\n}\n*/\n</style>\n</head>\n<body>\n<div id=\"example1\">\n<svg width=\"320\" height=\"240\" style=\"border: 1px solid lightgrey;\">\n  <rect x={{msg.x}} y={{msg.y}} width={{msg.width}} height={{msg.height}} style=\"stroke:red;stroke-width:2;fill-opacity:0\" />\n  Sorry, your browser does not support inline SVG.  \n</svg>\n</div>\n</body>\n</html>\n-->\n<!--\n<img width=\"100%\" height=\"100%\" alt=\"HighLight Picture\" src=\"data:image/png;base64,{{msg.payload}}\" />\n<span style=\"font-size:10px;\">{{msg.fileName}} {{msg.affSlideIndex}}/{{msg.numSlides}}</span> \n-->\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":1120,"y":1800,"wires":[[]]},{"id":"86f3292b.6471b8","type":"tensorflowCoco","z":"a8b1b208.7036f","name":"","model":"","scoreThreshold":"","x":590,"y":1840,"wires":[["2665fee8.ccc712","5b1ba3a2.77ebdc","61d7c39d.c5efdc","acbb43ee.e63df","c2a407c5.827fb8"]]},{"id":"2665fee8.ccc712","type":"debug","z":"a8b1b208.7036f","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":770,"y":1900,"wires":[]},{"id":"5b1ba3a2.77ebdc","type":"debug","z":"a8b1b208.7036f","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"classes","targetType":"msg","x":770,"y":1870,"wires":[]},{"id":"f2874676.b4f3b8","type":"base64","z":"a8b1b208.7036f","name":"","action":"str","property":"payload","x":580,"y":1770,"wires":[["d215245.d4919d8","24bd5862.38b1b8"]]},{"id":"61d7c39d.c5efdc","type":"ui_table","z":"a8b1b208.7036f","group":"7c26c8d0.c1e658","name":"table detection","order":8,"width":10,"height":2,"columns":[],"outputs":0,"cts":false,"x":780,"y":1810,"wires":[]},{"id":"bf528beb.36b538","type":"http request","z":"a8b1b208.7036f","name":"","method":"GET","ret":"bin","paytoqs":false,"url":"https://loremflickr.com/320/240/sport","tls":"","persist":false,"proxy":"","authType":"","x":370,"y":1850,"wires":[["86f3292b.6471b8","f2874676.b4f3b8","97a97ff2.45acd","64c32917.ff8b28"]]},{"id":"fd369cc7.f262b","type":"ui_button","z":"a8b1b208.7036f","name":"","group":"7c26c8d0.c1e658","order":6,"width":1,"height":1,"passthru":true,"label":"New Picture","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":220,"y":1850,"wires":[["bf528beb.36b538"]]},{"id":"64c32917.ff8b28","type":"image-info","z":"a8b1b208.7036f","name":"","x":590,"y":1910,"wires":[[]]},{"id":"27cb047f.a8173c","type":"function","z":"a8b1b208.7036f","name":"posiRectangle","func":"//let pictureB64[] = msg.payload;\nlet box = msg.detect[0];\nmsg.x = box.bbox[0];\nmsg.y = box.bbox[1];\nmsg.width = box.bbox[2];\nmsg.height= box.bbox[3];\nmsg.class = box[\"class\"];\nmsg.score = box[\"score\"];\n\nreturn msg;\n\n\n\n\n\n/*\n252x200 : person devant chalet\n0: object\n    bbox: array[4]\n        0: 127\n        1: 86\n        2: 29\n        3: 90\n    class: \"person\"\n    score: 0.9015087080001831\n    \n    x=127 y=86 width=127-90  height=86-29\n*/","outputs":1,"noerr":0,"x":930,"y":1840,"wires":[["91b9bccd.feaa9","24bd5862.38b1b8"]]},{"id":"91b9bccd.feaa9","type":"debug","z":"a8b1b208.7036f","name":"rectangle","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1110,"y":1840,"wires":[]},{"id":"97a97ff2.45acd","type":"image","z":"a8b1b208.7036f","name":"","width":"400","data":"payload","dataType":"msg","thumbnail":false,"active":true,"x":600,"y":1980,"wires":[]},{"id":"5f00cc2e.197f64","type":"inject","z":"a8b1b208.7036f","name":"test","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":80,"y":1850,"wires":[["fd369cc7.f262b"]]},{"id":"c2a407c5.827fb8","type":"change","z":"a8b1b208.7036f","name":"pay to detect","rules":[{"t":"move","p":"payload","pt":"msg","to":"detect","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":1840,"wires":[["27cb047f.a8173c"]]},{"id":"d215245.d4919d8","type":"debug","z":"a8b1b208.7036f","name":"b64","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":890,"y":1720,"wires":[]},{"id":"7c26c8d0.c1e658","type":"ui_group","z":"","name":"detection","tab":"b123e6c8.d3e948","order":2,"disp":true,"width":"10","collapse":true},{"id":"b123e6c8.d3e948","type":"ui_tab","z":"","name":"Slide","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
In an other hand , there is "nothing" to detect :
Detect nothing = the picture is loaded
This is the template node :
<!DOCTYPE html>
<html>
<style type="text/css">
.wrapper {
    position:relative;
    width:320px;
    height:240px;
.box {
    position:absolute;
    top:{{msg.y}}px;
    left:{{msg.x}}px;
 </style>
<body>
<div class="wrapper">
     <img src="data:image/jpg;base64,{{msg.payload}}"  />
     <div class="box"></div>
</div>
</body>
</html>
I would like the image to persist, before displaying the box! How to do ?
The problem here is that the image is overwritten by the msg from the posiRectangle. Somehow the image needs to be "saved" in the ui template and then used in the html code when the box data comes in
I tested a bit by instead saving the image to file and then load it in the html when the box data arrives and then it works but this is of course not a good way doing it
not bad !!
that's for sure, it saves an image on the SD card, it's not good for its life.
We are not far from the goal, it would be nice to be able to combine the image + the box in a file and then display it in the HTML code
Is it possible to put in a function, the msg.payload of the image + msg.x, msg.y, msg.width ... so as to send everything at once? It will avoid overwriting the image on arrival of msg.x, y, ...
It's alive !!! :star_struck:
[{"id":"86f3292b.6471b8","type":"tensorflowCoco","z":"a8b1b208.7036f","name":"","model":"","scoreThreshold":"","x":590,"y":1840,"wires":[["2665fee8.ccc712","5b1ba3a2.77ebdc","61d7c39d.c5efdc","c2a407c5.827fb8"]]},{"id":"2665fee8.ccc712","type":"debug","z":"a8b1b208.7036f","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":770,"y":1900,"wires":[]},{"id":"5b1ba3a2.77ebdc","type":"debug","z":"a8b1b208.7036f","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"classes","targetType":"msg","x":770,"y":1870,"wires":[]},{"id":"f2874676.b4f3b8","type":"base64","z":"a8b1b208.7036f","name":"","action":"str","property":"payload","x":580,"y":1770,"wires":[["d215245.d4919d8","cc75d53b.4b47b8"]]},{"id":"61d7c39d.c5efdc","type":"ui_table","z":"a8b1b208.7036f","group":"7c26c8d0.c1e658","name":"table detection","order":8,"width":10,"height":2,"columns":[],"outputs":0,"cts":false,"x":780,"y":1810,"wires":[]},{"id":"bf528beb.36b538","type":"http request","z":"a8b1b208.7036f","name":"","method":"GET","ret":"bin","paytoqs":false,"url":"https://loremflickr.com/320/240/sport","tls":"","persist":false,"proxy":"","authType":"","x":370,"y":1850,"wires":[["fb2a6f1a.6c4ed"]]},{"id":"fd369cc7.f262b","type":"ui_button","z":"a8b1b208.7036f","name":"","group":"7c26c8d0.c1e658","order":6,"width":1,"height":1,"passthru":true,"label":"New Picture","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":220,"y":1850,"wires":[["bf528beb.36b538"]]},{"id":"64c32917.ff8b28","type":"image-info","z":"a8b1b208.7036f","name":"","x":590,"y":1910,"wires":[[]]},{"id":"27cb047f.a8173c","type":"function","z":"a8b1b208.7036f","name":"posiRectangle","func":"var pictureBuffer = flow.get('pictureBuffer')|| [];\nmsg.pictureBuffer = pictureBuffer;\n//let pictureB64[] = msg.payload;\nlet box = msg.detect[0];\nmsg.x = box.bbox[0];\nmsg.y = box.bbox[1];\nmsg.width = box.bbox[2];\nmsg.height= box.bbox[3];\nmsg.class = box[\"class\"];\nmsg.score = box[\"score\"];\n\nreturn msg;\n\n\n\n\n\n/*\n252x200 : person devant chalet\n0: object\n    bbox: array[4]\n        0: 127\n        1: 86\n        2: 29\n        3: 90\n    class: \"person\"\n    score: 0.9015087080001831\n    \n    x=127 y=86 width=127-90  height=86-29\n*/","outputs":1,"noerr":0,"x":950,"y":1840,"wires":[["91b9bccd.feaa9","4d7ff98d.d0a008"]]},{"id":"91b9bccd.feaa9","type":"debug","z":"a8b1b208.7036f","name":"rectangle","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1110,"y":1840,"wires":[]},{"id":"97a97ff2.45acd","type":"image","z":"a8b1b208.7036f","name":"","width":"400","data":"payload","dataType":"msg","thumbnail":false,"active":true,"x":600,"y":1980,"wires":[]},{"id":"5f00cc2e.197f64","type":"inject","z":"a8b1b208.7036f","name":"test","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":80,"y":1850,"wires":[["fd369cc7.f262b"]]},{"id":"c2a407c5.827fb8","type":"change","z":"a8b1b208.7036f","name":"pay to detect","rules":[{"t":"move","p":"payload","pt":"msg","to":"detect","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":770,"y":1840,"wires":[["27cb047f.a8173c"]]},{"id":"d215245.d4919d8","type":"debug","z":"a8b1b208.7036f","name":"b64","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":890,"y":1720,"wires":[]},{"id":"66276b4a.5c6cb4","type":"link in","z":"a8b1b208.7036f","name":"coco","links":["fb2a6f1a.6c4ed","39e7bc7c.c0a794","308e49b6.df1dc6"],"x":455,"y":1940,"wires":[["f2874676.b4f3b8","97a97ff2.45acd","64c32917.ff8b28","86f3292b.6471b8"]]},{"id":"fb2a6f1a.6c4ed","type":"link out","z":"a8b1b208.7036f","name":"","links":["66276b4a.5c6cb4"],"x":320,"y":1940,"wires":[]},{"id":"4d7ff98d.d0a008","type":"ui_template","z":"a8b1b208.7036f","group":"7c26c8d0.c1e658","name":"highlightPict","order":2,"width":9,"height":6,"format":"<!DOCTYPE html>\n<html>\n<style type=\"text/css\"> \n.wrapper {\n    position:relative;\n    width:320px;\n    height:240px;\n    border:2px solid grey;\n}\n\n.box {\n    position:absolute;\n    top:{{msg.y}}px;\n    left:{{msg.x}}px;\n    width:{{msg.width}}px;\n    height:{{msg.height}}px;\n    border:2px solid red;\n    background-color:transparent\n}\n\n.text {\n    position:absolute;\n    top:{{msg.y}}px;\n    left: {{msg.x}}px;\n    color: red;\n\n}\n </style> \n<body>\n\n\n<div class=\"wrapper\">\n    <img src=\"data:image/jpg;base64,{{msg.pictureBuffer}}\"/> \n     <div class=\"box\"></div>\n     <div class=\"text\">{{msg.class}}</div>\n     \n</div>\n</body>\n</html>\n <!-- \n\n-->\n<!--\n//////////////////////////////////////////////////////////////////////////////\n<!DOCTYPE html>\n<html>\n<head>\n<style> \n#example1 {\n  background-image: url(data:image/jpg;base64,{{msg.payload}});\n  border: 1px solid blue;  \n  background-size:auto 100% ;\n  background-repeat: no-repeat;\n  /*\n}\nhttp://newscrane.com/wp-content/uploads/2019/09/Car-insurance-Newscrane-02.jpg\nsvg {\n border: 1px solid green;\n}\n*/\n</style>\n</head>\n<body>\n<div id=\"example1\">\n<svg width=\"320\" height=\"240\" style=\"border: 1px solid lightgrey;\">\n  <rect x={{msg.x}} y={{msg.y}} width={{msg.width}} height={{msg.height}} style=\"stroke:red;stroke-width:2;fill-opacity:0\" />\n  Sorry, your browser does not support inline SVG.  \n</svg>\n</div>\n</body>\n</html>\n-->\n<!--\n<img width=\"100%\" height=\"100%\" alt=\"HighLight Picture\" src=\"data:image/png;base64,{{msg.payload}}\" />\n<span style=\"font-size:10px;\">{{msg.fileName}} {{msg.affSlideIndex}}/{{msg.numSlides}}</span> \n-->\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":1120,"y":1760,"wires":[[]]},{"id":"cc75d53b.4b47b8","type":"function","z":"a8b1b208.7036f","name":"flow.set pictureBuffer","func":"// Créé une variable pour stocker le pictureBuffer si inexistante\nvar pictureBuffer = flow.get('pictureBuffer')|| [];\npictureBuffer = msg.payload;\n// store the value \nflow.set('pictureBuffer',pictureBuffer);\n\n\n\n\n\n","outputs":0,"noerr":0,"x":680,"y":1690,"wires":[]},{"id":"7c26c8d0.c1e658","type":"ui_group","z":"","name":"detection","tab":"b123e6c8.d3e948","order":2,"disp":true,"width":"10","collapse":true},{"id":"b123e6c8.d3e948","type":"ui_tab","z":"","name":"Slide","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
[EDIT]
Nice, and this is my suggestion, just got it working as well!
[{"id":"8a69170a.2a6d78","type":"ui_template","z":"2d489fd9.1eedd","group":"31b5112.2d60fee","name":"highlightPict","order":2,"width":9,"height":6,"format":"<!DOCTYPE html>\n<html>\n<style type=\"text/css\"> \n.wrapper {\n    position:absolute;\n    width:320px;\n    height:240px;\n    border:2px solid grey;\n}\n\n.box {\n    position:absolute;\n    top:{{msg.y}}px;\n    left:{{msg.x}}px;\n    width:{{msg.width}}px;\n    height:{{msg.height}}px;\n    border:2px solid red;\n    background-color:transparent\n    z-index: 2;\n}\n</style> \n\n<script type=\"text/javascript\">\nscope.$watch('msg', function(msg) {\n    inMessage(msg);\n});\n\nfunction inMessage(event) {\n    if (event.payload) {\n        //image = event.payload;\n        //alert(image);\n        document.getElementById('cX').src = \"data:image/jpg;base64,\"+event.payload;\n\n    }\n}\n\n</script>\n\n\n<body>\n\n\n<div class=\"wrapper\">\n     <img src=\"\" id=\"cX\" />\n     <div class=\"box\"></div>\n</div>\n</body>\n</html>\n\n\n\n<!--\n//////////////////////////////////////////////////////////////////////////////\n<!DOCTYPE html>\n<html>\n<head>\n<style> \n#example1 {\n  background-image: url(data:image/jpg;base64,{{msg.payload}});\n  border: 1px solid blue;  \n  background-size:auto 100% ;\n  background-repeat: no-repeat;\n  /*\n}\nhttp://newscrane.com/wp-content/uploads/2019/09/Car-insurance-Newscrane-02.jpg\nsvg {\n border: 1px solid green;\n}\n*/\n</style>\n</head>\n<body>\n<div id=\"example1\">\n<svg width=\"320\" height=\"240\" style=\"border: 1px solid lightgrey;\">\n  <rect x={{msg.x}} y={{msg.y}} width={{msg.width}} height={{msg.height}} style=\"stroke:red;stroke-width:2;fill-opacity:0\" />\n  Sorry, your browser does not support inline SVG.  \n</svg>\n</div>\n</body>\n</html>\n-->\n<!--\n<img width=\"100%\" height=\"100%\" alt=\"HighLight Picture\" src=\"data:image/png;base64,{{msg.payload}}\" />\n<span style=\"font-size:10px;\">{{msg.fileName}} {{msg.affSlideIndex}}/{{msg.numSlides}}</span> \n-->\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":1140,"y":410,"wires":[[]]},{"id":"2fccc750.eba658","type":"tensorflowCoco","z":"2d489fd9.1eedd","name":"","model":"","scoreThreshold":"","x":560,"y":510,"wires":[["efbd6894.4216b8","8f62009e.983cb","f37f4cb9.3def6","99bb537b.b3b73"]]},{"id":"efbd6894.4216b8","type":"debug","z":"2d489fd9.1eedd","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":720,"y":570,"wires":[]},{"id":"8f62009e.983cb","type":"debug","z":"2d489fd9.1eedd","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"classes","targetType":"msg","x":740,"y":540,"wires":[]},{"id":"2085ac81.9563d4","type":"base64","z":"2d489fd9.1eedd","name":"","action":"str","property":"payload","x":560,"y":410,"wires":[["1dd54700.7468b9","8a69170a.2a6d78"]]},{"id":"f37f4cb9.3def6","type":"ui_table","z":"2d489fd9.1eedd","group":"31b5112.2d60fee","name":"table detection","order":8,"width":10,"height":2,"columns":[],"outputs":0,"cts":false,"x":750,"y":480,"wires":[]},{"id":"2ac71df3.5060f2","type":"http request","z":"2d489fd9.1eedd","name":"","method":"GET","ret":"bin","paytoqs":false,"url":"https://loremflickr.com/320/240/sport","tls":"","persist":false,"proxy":"","authType":"","x":370,"y":470,"wires":[["2fccc750.eba658","2085ac81.9563d4"]]},{"id":"dfc95a0d.0305c8","type":"ui_button","z":"2d489fd9.1eedd","name":"","group":"31b5112.2d60fee","order":6,"width":1,"height":1,"passthru":true,"label":"New Picture","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":190,"y":520,"wires":[["2ac71df3.5060f2"]]},{"id":"9031a37c.91ff","type":"function","z":"2d489fd9.1eedd","name":"posiRectangle","func":"//let pictureB64[] = msg.payload;\nif(msg.detect.length>0){\n    let box = msg.detect[0];\n    msg.x = box.bbox[0];\n    msg.y = box.bbox[1];\n    msg.width = box.bbox[2];\n    msg.height= box.bbox[3];\n    msg.class = box[\"class\"];\n    msg.score = box[\"score\"];\n    \n    return msg;\n}\n\n\n\n\n\n/*\n252x200 : person devant chalet\n0: object\n    bbox: array[4]\n        0: 127\n        1: 86\n        2: 29\n        3: 90\n    class: \"person\"\n    score: 0.9015087080001831\n    \n    x=127 y=86 width=127-90  height=86-29\n*/","outputs":1,"noerr":0,"x":920,"y":510,"wires":[["bbd8edb4.45372","8a69170a.2a6d78"]]},{"id":"bbd8edb4.45372","type":"debug","z":"2d489fd9.1eedd","name":"rectangle","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1090,"y":510,"wires":[]},{"id":"fba73baf.e43ef8","type":"inject","z":"2d489fd9.1eedd","name":"test","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":140,"y":430,"wires":[["dfc95a0d.0305c8"]]},{"id":"99bb537b.b3b73","type":"change","z":"2d489fd9.1eedd","name":"pay to detect","rules":[{"t":"move","p":"payload","pt":"msg","to":"detect","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":740,"y":510,"wires":[["9031a37c.91ff"]]},{"id":"1dd54700.7468b9","type":"debug","z":"2d489fd9.1eedd","name":"b64","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":780,"y":380,"wires":[]},{"id":"31b5112.2d60fee","type":"ui_group","z":"","name":"detection","tab":"da82a0d.14db76","order":2,"disp":true,"width":"10","collapse":true},{"id":"da82a0d.14db76","type":"ui_tab","z":"","name":"Slide","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
great, another variation :+1:
now you should be able to display the other objects present, at least the 2 with the best score
Just a sample, displaying detected objects one-by-one
(This one is also supporting images received via mqtt, you can just delete that part)
[{"id":"379c521a.e9d72e","type":"comment","z":"2d489fd9.1eedd","name":"NR Object detection","info":"","x":170,"y":40,"wires":[]},{"id":"8a69170a.2a6d78","type":"ui_template","z":"2d489fd9.1eedd","group":"31b5112.2d60fee","name":"highlightPict","order":2,"width":"18","height":"12","format":"<!DOCTYPE html>\n<html>\n<style type=\"text/css\"> \n.wrapper {\n    position:absolute;\n    width:320px;\n    height:240px;\n    border:2px solid grey;\n}\n\n.box {\n    position:absolute;\n    top:{{msg.y}}px;\n    left:{{msg.x}}px;\n    width:{{msg.width}}px;\n    height:{{msg.height}}px;\n    border:2px solid red;\n    background-color:transparent\n    z-index: 2;\n}\n.text {\n    position:absolute;\n    top:{{msg.y+5}}px;\n    left: {{msg.x+5}}px;\n    color: red;\n\n}\n</style> \n\n<script type=\"text/javascript\">\nscope.$watch('msg', function(msg) {\n    inMessage(msg);\n});\n\nfunction inMessage(event) {\n    if (event.payload) {\n        document.getElementById('cX').src = \"data:image/jpg;base64,\"+event.payload;\n    }\n}\n\n</script>\n\n\n<body>\n\n\n<div class=\"wrapper\">\n     <img src=\"\" id=\"cX\" />\n     <div class=\"box\"></div>\n     <div class=\"text\">{{msg.class}}</div>\n</div>\n</body>\n</html>\n\n\n\n","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":1130,"y":60,"wires":[[]]},{"id":"2fccc750.eba658","type":"tensorflowCoco","z":"2d489fd9.1eedd","name":"","model":"","scoreThreshold":"","x":570,"y":240,"wires":[["efbd6894.4216b8","8f62009e.983cb","f37f4cb9.3def6","99bb537b.b3b73","9a7b8548.3747c8"]]},{"id":"efbd6894.4216b8","type":"debug","z":"2d489fd9.1eedd","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":820,"y":310,"wires":[]},{"id":"8f62009e.983cb","type":"debug","z":"2d489fd9.1eedd","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"classes","targetType":"msg","x":840,"y":260,"wires":[]},{"id":"2085ac81.9563d4","type":"base64","z":"2d489fd9.1eedd","name":"","action":"str","property":"payload","x":560,"y":60,"wires":[["8a69170a.2a6d78"]]},{"id":"f37f4cb9.3def6","type":"ui_table","z":"2d489fd9.1eedd","group":"31b5112.2d60fee","name":"table detection","order":8,"width":10,"height":2,"columns":[],"outputs":0,"cts":false,"x":850,"y":160,"wires":[]},{"id":"2ac71df3.5060f2","type":"http request","z":"2d489fd9.1eedd","name":"","method":"GET","ret":"bin","paytoqs":false,"url":"https://loremflickr.com/320/240/sport","tls":"","persist":false,"proxy":"","authType":"","x":350,"y":140,"wires":[["2fccc750.eba658","2085ac81.9563d4","9a7b8548.3747c8"]]},{"id":"dfc95a0d.0305c8","type":"ui_button","z":"2d489fd9.1eedd","name":"","group":"31b5112.2d60fee","order":6,"width":1,"height":1,"passthru":true,"label":"New Picture","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":150,"y":140,"wires":[["2ac71df3.5060f2"]]},{"id":"9031a37c.91ff","type":"function","z":"2d489fd9.1eedd","name":"posiRectangle","func":"if(msg.detect.length>0){\n    msg.detect.forEach(element => writeBox(element))\n}\n\nfunction writeBox(element) {\n    let box = element;\n    msg.x = box.bbox[0];\n    msg.y = box.bbox[1];\n    msg.width = box.bbox[2];\n    msg.height= box.bbox[3];\n    msg.class = box[\"class\"];\n    msg.score = box[\"score\"];\n    node.send(msg);\n}\n\n\n","outputs":1,"noerr":0,"x":1030,"y":210,"wires":[["bbd8edb4.45372","ac45a3a3.d45b5"]]},{"id":"bbd8edb4.45372","type":"debug","z":"2d489fd9.1eedd","name":"rectangle","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1240,"y":210,"wires":[]},{"id":"fba73baf.e43ef8","type":"inject","z":"2d489fd9.1eedd","name":"test","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":80,"wires":[["dfc95a0d.0305c8"]]},{"id":"99bb537b.b3b73","type":"change","z":"2d489fd9.1eedd","name":"pay to detect","rules":[{"t":"move","p":"payload","pt":"msg","to":"detect","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":840,"y":210,"wires":[["9031a37c.91ff"]]},{"id":"9a7b8548.3747c8","type":"function","z":"2d489fd9.1eedd","name":"","func":"var time = new Date().getTime()\nnode.warn(time)\n","outputs":0,"noerr":0,"x":570,"y":140,"wires":[]},{"id":"3bf60ae8.caf4f6","type":"mqtt in","z":"2d489fd9.1eedd","name":"","topic":"image/#","qos":"2","datatype":"auto","broker":"2a019090.5ba4d","x":160,"y":240,"wires":[["adb4835c.d0472","1804351d.75eb0b"]]},{"id":"adb4835c.d0472","type":"switch","z":"2d489fd9.1eedd","name":"","property":"payload","propertyType":"msg","rules":[{"t":"istype","v":"buffer","vt":"buffer"}],"checkall":"true","repair":false,"outputs":1,"x":370,"y":240,"wires":[["2085ac81.9563d4","9a7b8548.3747c8","2fccc750.eba658"]]},{"id":"1804351d.75eb0b","type":"debug","z":"2d489fd9.1eedd","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":360,"y":310,"wires":[]},{"id":"ac45a3a3.d45b5","type":"delay","z":"2d489fd9.1eedd","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"3","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":1090,"y":130,"wires":[["8a69170a.2a6d78"]]},{"id":"31b5112.2d60fee","type":"ui_group","z":"","name":"detection","tab":"da82a0d.14db76","order":2,"disp":true,"width":"18","collapse":true},{"id":"2a019090.5ba4d","type":"mqtt-broker","z":"","name":"","broker":"192.168.0.240","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"da82a0d.14db76","type":"ui_tab","z":"","name":"Slide","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
Loving what you guys are doing !
nice add !
Thank you for creating this node @dceejay !
Do you have any idea why your node is not working on WIN10 (see error log at the start of the post)? The bad luck ?
I know, this was for @dceejay but I could not keep my mouth shut; I believe it is because the javascrript version tensorflow (tfjs) is not supported on your platform. I got this error message on the Nvidia Jetson Nano when I tried installing
npm install @tensorflow/tfjs-node-gpu
GPU-linux-1.7.0.tar.gz
* Downloading libtensorflow
(node:9011) UnhandledPromiseRejectionWarning: Error: Unsupported system: gpu-linux-arm64
oh come on :wink:
yep, I saw that shows you a plug-in error on your platform, but me it says
"Error: Cannot find module ..."
Can we conclude that the platform is not compatible or do I have a module to add? so which one?
hmmm got the same thing trying to install it on a Pi Zero W (just thought I'd try) though mine ends with Error: Unsupported system: gpu-linux-arm
So for now, the only hardware that works is the RPI 3B (for me).
Surely the RPI 3B + ...
I have it working on a RPI 3B+
