Sure, but while you are at it...
The alignment is pushed to the bottom. Could the content be centered more
This is a really great gauge! I'll leave you to your muddy walk.
If you place it next to regular gauge the the labels are aligned. (almost , and only if standard layout sizes in use)
Without need to major redesign I can give this kind of results
That looks excellent!
As to change input value mechanics takes much more effort than I can steal from today's "do nothing more" schedule, I'll publish this change.
Now available
Stumbled across this promising node, installed it but cannot seem to get it to work. Whatever I try it is not showing up on the dashboard.
I am getting 2 errors related to my gauge in the startup log:
I installed v1.22 of the node through the palette manager.
Any tips/hits?
Node-RED version: v1.0.4
Node.js version: v10.17.0
Linux 4.19.66-v7+ arm LE
Running on a Raspberry
It will be easier for us if you show the node-red startup log.
Here you go, hope this is enough information.
20 Apr 16:52:01 - [info] Starting flows
20 Apr 16:52:02 - [info] [ui_artlessgauge:L1] Couldn't reach to the site parameters. Using hardcoded default parameters!
TypeError: Cannot read property 'value' of undefined
at new ArtlessGaugeNode (/home/pi/.node-red/node_modules/node-red-contrib-ui-artless-gauge/ui-artless-gauge.js:471:55)
at Object.createNode (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/flows/util.js:483:31)
at Flow.start (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/flows/Flow.js:190:48)
at start (/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/flows/index.js:345:33)
at tryCatchReject (/usr/lib/node_modules/node-red/node_modules/when/lib/makePromise.js:845:30)
at runContinuation1 (/usr/lib/node_modules/node-red/node_modules/when/lib/makePromise.js:804:4)
at Fulfilled.when (/usr/lib/node_modules/node-red/node_modules/when/lib/makePromise.js:592:4)
at Pending.run (/usr/lib/node_modules/node-red/node_modules/when/lib/makePromise.js:483:13)
at Scheduler._drain (/usr/lib/node_modules/node-red/node_modules/when/lib/Scheduler.js:62:19)
at Scheduler.drain (/usr/lib/node_modules/node-red/node_modules/when/lib/Scheduler.js:27:9)
at process._tickCallback (internal/process/next_tick.js:61:11)
20 Apr 16:52:03 - [info] Started flows
(node:26037) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 nodes-started listeners added. Use emitter.setMaxListeners() to increase limit
Actually I meant if from beginning but if you have sensitive information to hide, make image of it and share the image with sensitive info erased.
I wanted to see what is the dashboard you are using and version of it.
20 Apr 16:51:52 - [info] Node-RED version: v1.0.4
20 Apr 16:51:52 - [info] Node.js version: v10.17.0
20 Apr 16:51:52 - [info] Linux 4.19.66-v7+ arm LE
20 Apr 16:51:53 - [info] Loading palette nodes
20 Apr 16:51:58 - [info] Dashboard version 2.13.2 started at /ui
20 Apr 16:52:00 - [info] Settings file : /home/pi/.node-red/settings.js
20 Apr 16:52:00 - [info] HTTP Static : /home/pi/.node-red/public
20 Apr 16:52:00 - [info] Context store : 'default' [module=localfilesystem]
20 Apr 16:52:00 - [info] User directory : /home/pi/.node-red
20 Apr 16:52:00 - [warn] Projects disabled : editorTheme.projects.enabled=false
20 Apr 16:52:00 - [info] Flows file : /home/pi/.node-red/flows_PI01.json
20 Apr 16:52:00 - [info] Server now running at http://127.0.0.1:1880/
20 Apr 16:52:03 - [info] serial port /dev/ttyUSB0 opened at 4800 baud 8N2
20 Apr 16:52:03 - [info] [mqtt-broker:PI-01 Mosquitto] Connected to broker: PI-01-Red@http://x.x.x.x.
20 Apr 16:52:06 - [info] [alexa-remote-account:xxxx.xxxxx intialising with the PROXY method and saved data...
Dashboard version is too old. Try to update it.
That's interesting, I thought I was at the latest.
I'll try to find what happened and report back.
I have update the dashboard to 2.21.0 and the gauge now shows.
Thanks for the support!
Weekend special
Since v0.1.27 there is no more "...add change node before gauge "
Excellent
That's great news ![]()
That has shed a lot of nodes - and this is just one group.
Before
After
Is this a bug in v0.1.27
I've been using fa-plug as a icon in one radial gauge which until now has worked fine.
I have it set in differential mode with a center of 0, but since updating to v0.1.27, the icon is missing (not sure of my pre-update version - but no older than previous 7 days);
If I disable 'differential mode'...
....and the icon returns. (don't worry about the actual gauge display, it has the 'Range settings' still setup for differential).
Six jointed legs, two compound eyes, pair of antennae. Definitely a bug.
Fixed in 0.1.28
