Gauge.js library & Node-Red
I have used gauge.js library on a HTML/python project with good results.
How can I now use this library within Node-Red or Node-Red-template?
Add the gauge.js to a ui-template set for head, add the Gauge building code to a normal ui-template.
ppZEpqucQw
[{"id":"0181a540cb556a30","type":"ui_template","z":"9af9141769558c7a","group":"dce9e7a2.d20c78","name":"gauge.js","order":6,"width":0,"height":0,"format":"<script>\n(function(){function t(t,i){for(var e in i)m.call(i,e)&&(t[e]=i[e]);function s(){this.constructor=t}return s.prototype=i.prototype,t.prototype=new s,t.__super__=i.prototype,t}var i,e,s,n,o,p,a,h,r,l,g,c,u,d=[].slice,m={}.hasOwnProperty,x=[].indexOf||function(t){for(var i=0,e=this.length;i<e;i++)if(i in this&&this[i]===t)return i;return-1};function f(t,i){null==t&&(t=!0),this.clear=null==i||i,t&&AnimationUpdater.add(this)}function v(){return v.__super__.constructor.apply(this,arguments)}function y(t,i){this.el=t,this.fractionDigits=i}function V(t,i){if(this.elem=t,this.text=null!=i&&i,V.__super__.constructor.call(this),void 0===this.elem)throw new Error(\"The element isn't defined.\");this.value=1*this.elem.innerHTML,this.text&&(this.value=0)}function w(t){if(this.gauge=t,void 0===this.gauge)throw new Error(\"The element isn't defined.\");this.ctx=this.gauge.ctx,this.canvas=this.gauge.canvas,w.__super__.constructor.call(this,!1,!1),this.setOptions()}function S(t){this.elem=t}function M(t){var i,e;this.canvas=t,M.__super__.constructor.call(this),this.percentColors=null,\"undefined\"!=typeof G_vmlCanvasManager&&(this.canvas=window.G_vmlCanvasManager.initElement(this.canvas)),this.ctx=this.canvas.getContext(\"2d\"),i=this.canvas.clientHeight,e=this.canvas.clientWidth,this.canvas.height=i,this.canvas.width=e,this.gp=[new p(this)],this.setOptions()}function C(t){this.canvas=t,C.__super__.constructor.call(this),\"undefined\"!=typeof G_vmlCanvasManager&&(this.canvas=window.G_vmlCanvasManager.initElement(this.canvas)),this.ctx=this.canvas.getContext(\"2d\"),this.setOptions(),this.render()}function _(){return _.__super__.constructor.apply(this,arguments)}!function(){var s,n,t,o,i,e,a;for(t=0,i=(a=[\"ms\",\"moz\",\"webkit\",\"o\"]).length;t<i&&(e=a[t],!window.requestAnimationFrame);t++)window.requestAnimationFrame=window[e+\"RequestAnimationFrame\"],window.cancelAnimationFrame=window[e+\"CancelAnimationFrame\"]||window[e+\"CancelRequestAnimationFrame\"];s=null,o=0,n={},requestAnimationFrame?window.cancelAnimationFrame||(s=window.requestAnimationFrame,window.requestAnimationFrame=function(t,i){var e;return e=++o,s(function(){if(!n[e])return t()},i),e},window.cancelAnimationFrame=function(t){return n[t]=!0}):(window.requestAnimationFrame=function(t,i){var e,s,n,o;return e=(new Date).getTime(),o=Math.max(0,16-(e-n)),s=window.setTimeout(function(){return t(e+o)},o),n=e+o,s},window.cancelAnimationFrame=function(t){return clearTimeout(t)})}(),u=function(t){var i,e;for(t-=3600*(i=Math.floor(t/3600))+60*(e=Math.floor((t-3600*i)/60)),t+=\"\",e+=\"\";e.length<2;)e=\"0\"+e;for(;t.length<2;)t=\"0\"+t;return(i=i?i+\":\":\"\")+e+\":\"+t},g=function(){var t,i,e;return e=(i=1<=arguments.length?d.call(arguments,0):[])[0],t=i[1],r(e.toFixed(t))},c=function(t,i){var e,s,n;for(e in s={},t)m.call(t,e)&&(n=t[e],s[e]=n);for(e in i)m.call(i,e)&&(n=i[e],s[e]=n);return s},r=function(t){var i,e,s,n;for(s=(e=(t+=\"\").split(\".\"))[0],n=\"\",1<e.length&&(n=\".\"+e[1]),i=/(\\d+)(\\d{3})/;i.test(s);)s=s.replace(i,\"$1,$2\");return s+n},l=function(t){return\"#\"===t.charAt(0)?t.substring(1,7):t},f.prototype.animationSpeed=32,f.prototype.update=function(t){var i;return null==t&&(t=!1),!(!t&&this.displayedValue===this.value||(this.ctx&&this.clear&&this.ctx.clearRect(0,0,this.canvas.width,this.canvas.height),i=this.value-this.displayedValue,Math.abs(i/this.animationSpeed)<=.001?this.displayedValue=this.value:this.displayedValue=this.displayedValue+i/this.animationSpeed,this.render(),0))},t(v,h=f),v.prototype.displayScale=1,v.prototype.forceUpdate=!0,v.prototype.setTextField=function(t,i){return this.textField=t instanceof a?t:new a(t,i)},v.prototype.setMinValue=function(t,i){var e,s,n,o,a;if(this.minValue=t,null==i&&(i=!0),i){for(this.displayedValue=this.minValue,a=[],s=0,n=(o=this.gp||[]).length;s<n;s++)e=o[s],a.push(e.displayedValue=this.minValue);return a}},v.prototype.setOptions=function(t){return null==t&&(t=null),this.options=c(this.options,t),this.textField&&(this.textField.el.style.fontSize=t.fontSize+\"px\"),.5<this.options.angle&&(this.options.angle=.5),this.configDisplayScale(),this},v.prototype.configDisplayScale=function(){var t,i,e,s,n;return s=this.displayScale,!1===this.options.highDpiSupport?delete this.displayScale:(i=window.devicePixelRatio||1,t=this.ctx.webkitBackingStorePixelRatio||this.ctx.mozBackingStorePixelRatio||this.ctx.msBackingStorePixelRatio||this.ctx.oBackingStorePixelRatio||this.ctx.backingStorePixelRatio||1,this.displayScale=i/t),this.displayScale!==s&&(n=this.canvas.G__width||this.canvas.width,e=this.canvas.G__height||this.canvas.height,this.canvas.width=n*this.displayScale,this.canvas.height=e*this.displayScale,this.canvas.style.width=n+\"px\",this.canvas.style.height=e+\"px\",this.canvas.G__width=n,this.canvas.G__height=e),this},v.prototype.parseValue=function(t){return t=parseFloat(t)||Number(t),isFinite(t)?t:0},s=v,y.prototype.render=function(t){return this.el.innerHTML=g(t.displayedValue,this.fractionDigits)},a=y,t(V,h),V.prototype.displayedValue=0,V.prototype.value=0,V.prototype.setVal=function(t){return this.value=1*t},V.prototype.render=function(){var t;return t=this.text?u(this.displayedValue.toFixed(0)):r(g(this.displayedValue)),this.elem.innerHTML=t},i=V,t(w,h),w.prototype.displayedValue=0,w.prototype.value=0,w.prototype.options={strokeWidth:.035,length:.1,color:\"#000000\",iconPath:null,iconScale:1,iconAngle:0},w.prototype.img=null,w.prototype.setOptions=function(t){if(null==t&&(t=null),this.options=c(this.options,t),this.length=2*this.gauge.radius*this.gauge.options.radiusScale*this.options.length,this.strokeWidth=this.canvas.height*this.options.strokeWidth,this.maxValue=this.gauge.maxValue,this.minValue=this.gauge.minValue,this.animationSpeed=this.gauge.animationSpeed,this.options.angle=this.gauge.options.angle,this.options.iconPath)return this.img=new Image,this.img.src=this.options.iconPath},w.prototype.render=function(){var t,i,e,s,n,o,a,h,r;if(t=this.gauge.getAngle.call(this,this.displayedValue),h=Math.round(this.length*Math.cos(t)),r=Math.round(this.length*Math.sin(t)),o=Math.round(this.strokeWidth*Math.cos(t-Math.PI/2)),a=Math.round(this.strokeWidth*Math.sin(t-Math.PI/2)),i=Math.round(this.strokeWidth*Math.cos(t+Math.PI/2)),e=Math.round(this.strokeWidth*Math.sin(t+Math.PI/2)),this.ctx.beginPath(),this.ctx.fillStyle=this.options.color,this.ctx.arc(0,0,this.strokeWidth,0,2*Math.PI,!1),this.ctx.fill(),this.ctx.beginPath(),this.ctx.moveTo(o,a),this.ctx.lineTo(h,r),this.ctx.lineTo(i,e),this.ctx.fill(),this.img)return s=Math.round(this.img.width*this.options.iconScale),n=Math.round(this.img.height*this.options.iconScale),this.ctx.save(),this.ctx.translate(h,r),this.ctx.rotate(t+Math.PI/180*(90+this.options.iconAngle)),this.ctx.drawImage(this.img,-s/2,-n/2,s,n),this.ctx.restore()},p=w,S.prototype.updateValues=function(t){return this.value=t[0],this.maxValue=t[1],this.avgValue=t[2],this.render()},S.prototype.render=function(){var t,i;return this.textField&&this.textField.text(g(this.value)),0===this.maxValue&&(this.maxValue=2*this.avgValue),i=this.value/this.maxValue*100,t=this.avgValue/this.maxValue*100,$(\".bar-value\",this.elem).css({width:i+\"%\"}),$(\".typical-value\",this.elem).css({width:t+\"%\"})},t(M,s),M.prototype.elem=null,M.prototype.value=[20],M.prototype.maxValue=80,M.prototype.minValue=0,M.prototype.displayedAngle=0,M.prototype.displayedValue=0,M.prototype.lineWidth=40,M.prototype.paddingTop=.1,M.prototype.paddingBottom=.1,M.prototype.percentColors=null,M.prototype.options={colorStart:\"#6fadcf\",colorStop:void 0,gradientType:0,strokeColor:\"#e0e0e0\",pointer:{length:.8,strokeWidth:.035,iconScale:1},angle:.15,lineWidth:.44,radiusScale:1,fontSize:40,limitMax:!1,limitMin:!1},M.prototype.setOptions=function(t){var i,e,s,n,o;for(null==t&&(t=null),M.__super__.setOptions.call(this,t),this.configPercentColors(),this.extraPadding=0,this.options.angle<0&&(n=Math.PI*(1+this.options.angle),this.extraPadding=Math.sin(n)),this.availableHeight=this.canvas.height*(1-this.paddingTop-this.paddingBottom),this.lineWidth=this.availableHeight*this.options.lineWidth,this.radius=(this.availableHeight-this.lineWidth/2)/(1+this.extraPadding),this.ctx.clearRect(0,0,this.canvas.width,this.canvas.height),e=0,s=(o=this.gp).length;e<s;e++)(i=o[e]).setOptions(this.options.pointer),i.render();return this.render(),this},M.prototype.configPercentColors=function(){var t,i,e,s,n,o,a;if(this.percentColors=null,void 0!==this.options.percentColors){for(this.percentColors=new Array,o=[],e=s=0,n=this.options.percentColors.length-1;0<=n?s<=n:n<=s;e=0<=n?++s:--s)a=parseInt(l(this.options.percentColors[e][1]).substring(0,2),16),i=parseInt(l(this.options.percentColors[e][1]).substring(2,4),16),t=parseInt(l(this.options.percentColors[e][1]).substring(4,6),16),o.push(this.percentColors[e]={pct:this.options.percentColors[e][0],color:{r:a,g:i,b:t}});return o}},M.prototype.set=function(t){var i,e,s,n,o,a,h,r,l;for(t instanceof Array||(t=[t]),e=s=0,h=t.length-1;0<=h?s<=h:h<=s;e=0<=h?++s:--s)t[e]=this.parseValue(t[e]);if(t.length>this.gp.length)for(e=n=0,r=t.length-this.gp.length;0<=r?n<r:r<n;e=0<=r?++n:--n)(i=new p(this)).setOptions(this.options.pointer),this.gp.push(i);else t.length<this.gp.length&&(this.gp=this.gp.slice(this.gp.length-t.length));for(a=e=0,o=t.length;a<o;a++)(l=t[a])>this.maxValue?this.options.limitMax?l=this.maxValue:this.maxValue=l+1:l<this.minValue&&(this.options.limitMin?l=this.minValue:this.minValue=l-1),this.gp[e].value=l,this.gp[e++].setOptions({minValue:this.minValue,maxValue:this.maxValue,angle:this.options.angle});return this.value=Math.max(Math.min(t[t.length-1],this.maxValue),this.minValue),AnimationUpdater.add(this),AnimationUpdater.run(this.forceUpdate),this.forceUpdate=!1},M.prototype.getAngle=function(t){return(1+this.options.angle)*Math.PI+(t-this.minValue)/(this.maxValue-this.minValue)*(1-2*this.options.angle)*Math.PI},M.prototype.getColorForPercentage=function(t,i){var e,s,n,o,a,h,r;if(0===t)e=this.percentColors[0].color;else for(e=this.percentColors[this.percentColors.length-1].color,n=o=0,h=this.percentColors.length-1;0<=h?o<=h:h<=o;n=0<=h?++o:--o)if(t<=this.percentColors[n].pct){e=!0===i?(r=this.percentColors[n-1]||this.percentColors[0],s=this.percentColors[n],a=(t-r.pct)/(s.pct-r.pct),{r:Math.floor(r.color.r*(1-a)+s.color.r*a),g:Math.floor(r.color.g*(1-a)+s.color.g*a),b:Math.floor(r.color.b*(1-a)+s.color.b*a)}):this.percentColors[n].color;break}return\"rgb(\"+[e.r,e.g,e.b].join(\",\")+\")\"},M.prototype.getColorForValue=function(t,i){var e;return e=(t-this.minValue)/(this.maxValue-this.minValue),this.getColorForPercentage(e,i)},M.prototype.renderStaticLabels=function(t,i,e,s){var n,o,a,h,r,l,p,c,u,d;for(this.ctx.save(),this.ctx.translate(i,e),l=/\\d+\\.?\\d?/,r=(n=t.font||\"10px Times\").match(l)[0],c=n.slice(r.length),o=parseFloat(r)*this.displayScale,this.ctx.font=o+c,this.ctx.fillStyle=t.color||\"#000000\",this.ctx.textBaseline=\"bottom\",this.ctx.textAlign=\"center\",a=0,h=(p=t.labels).length;a<h;a++)void 0!==(d=p[a]).label?(!this.options.limitMin||d>=this.minValue)&&(!this.options.limitMax||d<=this.maxValue)&&(r=(n=d.font||t.font).match(l)[0],c=n.slice(r.length),o=parseFloat(r)*this.displayScale,this.ctx.font=o+c,u=this.getAngle(d.label)-3*Math.PI/2,this.ctx.rotate(u),this.ctx.fillText(g(d.label,t.fractionDigits),0,-s-this.lineWidth/2),this.ctx.rotate(-u)):(!this.options.limitMin||d>=this.minValue)&&(!this.options.limitMax||d<=this.maxValue)&&(u=this.getAngle(d)-3*Math.PI/2,this.ctx.rotate(u),this.ctx.fillText(g(d,t.fractionDigits),0,-s-this.lineWidth/2),this.ctx.rotate(-u));return this.ctx.restore()},M.prototype.renderTicks=function(t,i,e,s){var n,o,a,h,r,l,p,c,u,d,g,m,x,f,v,y,V,w,S,M;if(t!=={}){for(l=t.divisions||0,w=t.subDivisions||0,a=t.divColor||\"#fff\",f=t.subColor||\"#fff\",h=t.divLength||.7,y=t.subLength||.2,u=parseFloat(this.maxValue)-parseFloat(this.minValue),d=parseFloat(u)/parseFloat(t.divisions),v=parseFloat(d)/parseFloat(t.subDivisions),n=parseFloat(this.minValue),o=0+v,r=(c=u/400)*(t.divWidth||1),V=c*(t.subWidth||1),m=[],S=p=0,g=l+1;p<g;S=p+=1)this.ctx.lineWidth=this.lineWidth*h,x=this.lineWidth/2*(1-h),M=this.radius*this.options.radiusScale+x,this.ctx.strokeStyle=a,this.ctx.beginPath(),this.ctx.arc(0,0,M,this.getAngle(n-r),this.getAngle(n+r),!1),this.ctx.stroke(),o=n+v,n+=d,S!==t.divisions&&0<w?m.push(function(){var t,i,e;for(e=[],t=0,i=w-1;t<i;t+=1)this.ctx.lineWidth=this.lineWidth*y,x=this.lineWidth/2*(1-y),M=this.radius*this.options.radiusScale+x,this.ctx.strokeStyle=f,this.ctx.beginPath(),this.ctx.arc(0,0,M,this.getAngle(o-V),this.getAngle(o+V),!1),this.ctx.stroke(),e.push(o+=v);return e}.call(this)):m.push(void 0);return m}},M.prototype.render=function(){var t,i,e,s,n,o,a,h,r,l,p,c,u,d,g,m;if(g=this.canvas.width/2,e=this.canvas.height*this.paddingTop+this.availableHeight-(this.radius+this.lineWidth/2)*this.extraPadding,t=this.getAngle(this.displayedValue),this.textField&&this.textField.render(this),this.ctx.lineCap=\"butt\",l=this.radius*this.options.radiusScale,this.options.staticLabels&&this.renderStaticLabels(this.options.staticLabels,g,e,l),this.options.staticZones)for(this.ctx.save(),this.ctx.translate(g,e),this.ctx.lineWidth=this.lineWidth,s=0,o=(p=this.options.staticZones).length;s<o;s++)r=(m=p[s]).min,this.options.limitMin&&r<this.minValue&&(r=this.minValue),h=m.max,this.options.limitMax&&h>this.maxValue&&(h=this.maxValue),d=this.radius*this.options.radiusScale,m.height&&(this.ctx.lineWidth=this.lineWidth*m.height,u=this.lineWidth/2*(m.offset||1-m.height),d=this.radius*this.options.radiusScale+u),this.ctx.strokeStyle=m.strokeStyle,this.ctx.beginPath(),this.ctx.arc(0,0,d,this.getAngle(r),this.getAngle(h),!1),this.ctx.stroke();else void 0!==this.options.customFillStyle?i=this.options.customFillStyle(this):null!==this.percentColors?i=this.getColorForValue(this.displayedValue,this.options.generateGradient):void 0!==this.options.colorStop?((i=0===this.options.gradientType?this.ctx.createRadialGradient(g,e,9,g,e,70):this.ctx.createLinearGradient(0,0,g,0)).addColorStop(0,this.options.colorStart),i.addColorStop(1,this.options.colorStop)):i=this.options.colorStart,this.ctx.strokeStyle=i,this.ctx.beginPath(),this.ctx.arc(g,e,l,(1+this.options.angle)*Math.PI,t,!1),this.ctx.lineWidth=this.lineWidth,this.ctx.stroke(),this.ctx.strokeStyle=this.options.strokeColor,this.ctx.beginPath(),this.ctx.arc(g,e,l,t,(2-this.options.angle)*Math.PI,!1),this.ctx.stroke(),this.ctx.save(),this.ctx.translate(g,e);for(this.options.renderTicks&&this.renderTicks(this.options.renderTicks,g,e,l),this.ctx.restore(),this.ctx.translate(g,e),n=0,a=(c=this.gp).length;n<a;n++)c[n].update(!0);return this.ctx.translate(-g,-e)},o=M,t(C,s),C.prototype.lineWidth=15,C.prototype.displayedValue=0,C.prototype.value=33,C.prototype.maxValue=80,C.prototype.minValue=0,C.prototype.options={lineWidth:.1,colorStart:\"#6f6ea0\",colorStop:\"#c0c0db\",strokeColor:\"#eeeeee\",shadowColor:\"#d5d5d5\",angle:.35,radiusScale:1},C.prototype.getAngle=function(t){return(1-this.options.angle)*Math.PI+(t-this.minValue)/(this.maxValue-this.minValue)*(2+this.options.angle-(1-this.options.angle))*Math.PI},C.prototype.setOptions=function(t){return null==t&&(t=null),C.__super__.setOptions.call(this,t),this.lineWidth=this.canvas.height*this.options.lineWidth,this.radius=this.options.radiusScale*(this.canvas.height/2-this.lineWidth/2),this},C.prototype.set=function(t){return this.value=this.parseValue(t),this.value>this.maxValue?this.options.limitMax?this.value=this.maxValue:this.maxValue=this.value:this.value<this.minValue&&(this.options.limitMin?this.value=this.minValue:this.minValue=this.value),AnimationUpdater.add(this),AnimationUpdater.run(this.forceUpdate),this.forceUpdate=!1},C.prototype.render=function(){var t,i,e,s;return t=this.getAngle(this.displayedValue),s=this.canvas.width/2,e=this.canvas.height/2,this.textField&&this.textField.render(this),(i=this.ctx.createRadialGradient(s,e,39,s,e,70)).addColorStop(0,this.options.colorStart),i.addColorStop(1,this.options.colorStop),this.radius,this.lineWidth,this.radius,this.lineWidth,this.ctx.strokeStyle=this.options.strokeColor,this.ctx.beginPath(),this.ctx.arc(s,e,this.radius,(1-this.options.angle)*Math.PI,(2+this.options.angle)*Math.PI,!1),this.ctx.lineWidth=this.lineWidth,this.ctx.lineCap=\"round\",this.ctx.stroke(),this.ctx.strokeStyle=i,this.ctx.beginPath(),this.ctx.arc(s,e,this.radius,(1-this.options.angle)*Math.PI,t,!1),this.ctx.stroke()},t(_,e=C),_.prototype.strokeGradient=function(t,i,e,s){var n;return(n=this.ctx.createRadialGradient(t,i,e,t,i,s)).addColorStop(0,this.options.shadowColor),n.addColorStop(.12,this.options._orgStrokeColor),n.addColorStop(.88,this.options._orgStrokeColor),n.addColorStop(1,this.options.shadowColor),n},_.prototype.setOptions=function(t){var i,e,s,n;return null==t&&(t=null),_.__super__.setOptions.call(this,t),n=this.canvas.width/2,i=this.canvas.height/2,e=this.radius-this.lineWidth/2,s=this.radius+this.lineWidth/2,this.options._orgStrokeColor=this.options.strokeColor,this.options.strokeColor=this.strokeGradient(n,i,e,s),this},n=_,window.AnimationUpdater={elements:[],animId:null,addAll:function(t){var i,e,s,n;for(n=[],e=0,s=t.length;e<s;e++)i=t[e],n.push(AnimationUpdater.elements.push(i));return n},add:function(t){if(x.call(AnimationUpdater.elements,t)<0)return AnimationUpdater.elements.push(t)},run:function(t){var i,e,s,n,o,a,h;if(null==t&&(t=!1),isFinite(parseFloat(t))||!0===t){for(i=!0,h=[],s=e=0,o=(a=AnimationUpdater.elements).length;e<o;s=++e)a[s].update(!0===t)?i=!1:h.push(s);for(n=h.length-1;0<=n;n+=-1)s=h[n],AnimationUpdater.elements.splice(s,1);return AnimationUpdater.animId=i?null:requestAnimationFrame(AnimationUpdater.run)}if(!1===t)return!0===AnimationUpdater.animId&&cancelAnimationFrame(AnimationUpdater.animId),AnimationUpdater.animId=requestAnimationFrame(AnimationUpdater.run)}},\"function\"==typeof window.define&&null!=window.define.amd?define(function(){return{Gauge:o,Donut:n,BaseDonut:e,TextRenderer:a}}):\"undefined\"!=typeof module&&null!=module.exports?module.exports={Gauge:o,Donut:n,BaseDonut:e,TextRenderer:a}:(window.Gauge=o,window.Donut=n,window.BaseDonut=e,window.TextRenderer=a)}).call(this);    \n</script>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"global","className":"","x":1500,"y":800,"wires":[[]]},{"id":"7fd322ae44092954","type":"ui_template","z":"9af9141769558c7a","group":"dce9e7a2.d20c78","name":"foo gauge","order":7,"width":"9","height":"8","format":"<canvas id=\"foo\">\n\n</canvas>\n\n<script>\nvar opts = {\n  angle: 0, // The span of the gauge arc\n  lineWidth: 0.32, // The line thickness\n  radiusScale: 0.85, // Relative radius\n  pointer: {\n  length: 0.66, // // Relative to gauge radius\n  strokeWidth: 0.057, // The thickness\n  color: '#000000' // Fill color\n  },\n  limitMax: false, // If false, max value increases automatically if value > maxValue\n  limitMin: false, // If true, the min value of the gauge will be fixed\n  colorStart: '#6FADCF', // Colors\n  colorStop: '#8FC0DA', // just experiment with them\n  strokeColor: '#E0E0E0', // to see which ones work best for you\n  generateGradient: true,\n  highDpiSupport: true,     // High resolution support\n  staticZones: [\n    {strokeStyle: \"#F03E3E\", min: 0, max: 130}, // Red from 100 to 130\n    {strokeStyle: \"#FFDD00\", min: 130, max: 550}, // Yellow\n    {strokeStyle: \"#30B32D\", min: 550, max: 2220}, // Green\n    {strokeStyle: \"#FFDD00\", min: 2220, max: 2660}, // Yellow\n    {strokeStyle: \"#F03E3E\", min: 2660, max: 3000} // Red\n  ],\n  staticLabels: {\n    font: \"10px sans-serif\",  // Specifies font\n    labels: [0, 130, 550, 2220, 2660, 3000],  // Print labels at these values\n    color: \"#000000\",  // Optional: Label text color\n    fractionDigits: 0  // Optional: Numerical precision. 0=round off.\n  },\n};\n\nvar target = document.getElementById('foo'); // your canvas element\nvar gauge = new Gauge(target).setOptions(opts); // create sexy gauge!\ngauge.maxValue = 3000; // set max gauge value\ngauge.setMinValue(0);  // Prefer setter over gauge.minValue = 0\ngauge.animationSpeed = 50; // set animation speed (32 is default value)\n//gauge.percentColors = [[0.0, \"#a9d70b\" ], [0.50, \"#f9c802\"], [1.0, \"#ff0000\"]],\n(function(scope) {\n\n  scope.$watch('msg', function(msg) {\n    if(msg) {\n      if (msg.topic == \"set\") {\n        gauge.set(msg.payload); // set actual value\n      }\n    }\n  });\n})(scope);\n</script>\n\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":1500,"y":840,"wires":[[]]},{"id":"a71899bf716e628e","type":"inject","z":"9af9141769558c7a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"set","payload":"50","payloadType":"num","x":1330,"y":800,"wires":[["7fd322ae44092954"]]},{"id":"d68ce9c08033dc5e","type":"inject","z":"9af9141769558c7a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"set","payload":"700","payloadType":"num","x":1330,"y":840,"wires":[["7fd322ae44092954"]]},{"id":"679930abd3f61438","type":"inject","z":"9af9141769558c7a","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"set","payload":"2689","payloadType":"num","x":1340,"y":880,"wires":[["7fd322ae44092954"]]},{"id":"dce9e7a2.d20c78","type":"ui_group","name":"Object detection","tab":"5132060d.4cde48","order":1,"disp":true,"width":"9","collapse":false},{"id":"5132060d.4cde48","type":"ui_tab","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Hi Steve,
Great help!
I would have never made it!
Many thanks!
regards Hannes
@Steve-Mcl If I am understanding this correctly, your example flow should be a simple import and deploy.
But as with other "self contained" JS gauge examples I have been testing, most just show a blank window.
To confirm, there is nothing more that needs to be downloaded and installed for your gauge.js example to work?
And BTW, Yes I have been Googling this and tried a few other (simular) examples like here: gauge.js with same (blank) results. Most frustrating.
Correct. Should be import and deploy. Do you see any errors in browser console?
OK, after disabling every other index node (that was set to head) across my flows and resetting to default theme... I can get partial results, at least with this example... still can't get other gauge methods (mentioned in another topic) working.
As for browser console errors... well... looks like that's a yes! But no idea how to interpret them.
EDIT... OK, I didn't realise none of the inject nodes fired on refresh... After triggering one, I now see full results of this gauge... but still all the errors.
OK, I see many of these errors are referring to other parts of my dashboard... makes sense as it is all one big webpage.
I guess I am just running too many experiments across differing CSS and file/image loading processes.
Hi @Gunner,
When you open the "Network" tabsheet in your browser Developer Tools, perhaps you then see (after a refresh) where the 404 is related to...
Bart
@BartButenaers the 404 is just for an optional “loading” page so is totally normal.
So I see... gotta love (node)-red herrings :laughing:
All of the other red highlighted errors seem to be from my four artless-gauge nodes. No idea why as they are working just fine, but when I disable them the errors go away. I guess that is another case of "errors safe to ignore" :innocent:
Hallo Steve,
I actually used another library on my former project.
You can find it at Github: https://github.com/Mikhus/canvas-gauges
How would you integrate this library into Node-Red.
Also copy the library into one template
and then in the second template the options etc. ?
Nice feature is, that you can get radial and linear gauges.
With linear gauges you get more information on one screen.
[Examples]
@Steve-Mcl Great to see, is it possible to integrate the Modbus data like our existing gauge(data coming from the Modbus TCP node and display a same value through gauge),
if possible how to integrate, can you help us on the same.
On the demo i provided, change the inject nodes to change nodes, set msg.topic to set and msg.payload as the modbus value you want to display.
The fact you have to ask that question tells me you are a beginner with node red. So I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
@Steve-Mcl Many thanks!
@Colin yeah sir, i am new to node red the link you shared me was helpful.
@Steve-Mcl hi,
i have 2 things
1.Modbus data getting Continuously feeding through msg.payload but still Gauge stroke is not moving and not showing exact value.
2.Second point would be like not able to display a multiple gauges in a single window i was tried to do it in single window but multiple window either one of the gauge only displaying.
1.
2.
