Approach for signing message with HMAC (any recommendation for third party node?)
Hi!
I have a Python script that I would like to integrate into Node-RED. Essentially, it signs a message with HMAC/SHA256.
So far, I've attempted to implement Crypto-JS to create a function in Node-RED. However, this approach isn't very flexible if I want to share the flow with others and also I'havent succeed :frowning:
Perhaps someone has created a similar example using a third-party flow and can assist or guide me through the process.
def mymessagesigned(mysecret, message, randomh):
    random_header_bytes = randomh.encode('utf-8')
    shared_secret_bytes = mysecret.encode('utf-8')
    signature = hmac.new(shared_secret_bytes, digestmod=hashlib.sha256)
    signature.update(random_header_bytes)
    signature.update(message.encode('utf-8'))
    return signature.hexdigest()
thank you
Why not? You can simply add crypto to a function nodes settings tab. The flow will be exportable and importable by anyone who you share it with.
Have you tried the existing contrib nodes? Library - Node-RED
THX for the info
I only read the "functionglobacontext" but didn't read further
https://nodered.org/docs/user-guide/writing-functions#loading-additional-modules
With the settings tab it`s easy :slight_smile: thx
