Array data to telegram
I'm trying to understand how I get data from an array into Telegram Notify node. I'd like to include all three parts of the array, one on each line.
I've read and re-read the guides on here but I'm not able to understand where I go from here (noob)
Apologies if this post isn't in the correct location etc.
flows.json (3.8 KB)
 [{"id":"18d2a40e.69977c","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"a923a71f.23b0e8","type":"change","z":"18d2a40e.69977c","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"Goal! ","fromt":"str","to":"Goal,","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Half-time. ","fromt":"str","to":"Half-time,","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Finished. ","fromt":"str","to":"Finished,","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"Red card! ","fromt":"str","to":"Red card,","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":":0 ","fromt":"str","to":":0","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":":1 ","fromt":"str","to":":1","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":":2 ","fromt":"str","to":":2","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":":3 ","fromt":"str","to":":3","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":":4 ","fromt":"str","to":":4","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":":5 ","fromt":"str","to":":5","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":":6 ","fromt":"str","to":":6","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":":7 ","fromt":"str","to":":7","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":":8 ","fromt":"str","to":":8","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":":9 ","fromt":"str","to":":9","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":":10 ","fromt":"str","to":":10","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":". ","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"] ","fromt":"str","to":"]","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":350,"y":140,"wires":[["9bbd6fce.f5668"]]},{"id":"ba0a8018.3dad2","type":"debug","z":"18d2a40e.69977c","name":"Step 1","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":260,"y":260,"wires":[]},{"id":"9c91e38e.6249","type":"inject","z":"18d2a40e.69977c","name":"Trigger","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"Goal! Fred - Bob 0:[1] ,35' Jeff T. ","payloadType":"str","x":120,"y":140,"wires":[["a923a71f.23b0e8"]]},{"id":"9bbd6fce.f5668","type":"split","z":"18d2a40e.69977c","name":"","splt":",","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":260,"y":200,"wires":[["ba0a8018.3dad2","3f3ca270.e11e5e"]]},{"id":"3f3ca270.e11e5e","type":"join","z":"18d2a40e.69977c","name":"","mode":"custom","build":"array","property":"payload","propertyType":"msg","key":"topic","joiner":"\\n","joinerType":"str","accumulate":false,"timeout":"","count":"3","reduceRight":false,"reduceExp":"","reduceInit":"","reduceInitType":"","reduceFixup":"","x":500,"y":200,"wires":[["f5e52174.b079b","e790a2c6.17048"]]},{"id":"708a8ba8.a59e24","type":"debug","z":"18d2a40e.69977c","name":"Step 3","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":680,"y":260,"wires":[]},{"id":"f5e52174.b079b","type":"function","z":"18d2a40e.69977c","name":"1","func":"msg.payload = msg.payload[0];\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":680,"y":200,"wires":[["708a8ba8.a59e24","d41ad78d.0a9f98"]]},{"id":"e790a2c6.17048","type":"debug","z":"18d2a40e.69977c","name":"Step 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":500,"y":260,"wires":[]},{"id":"d41ad78d.0a9f98","type":"telegrambot-notify","z":"18d2a40e.69977c","name":"","bot":"","chatId":"","message":"","parseMode":"","x":910,"y":200,"wires":[]}]
Can anyone give me an example of how to use data from an array to send it across to a TelegramNotify node pls?
Are you able to send a normal string? Where is it you think the problem is?
Can you please also tell us what actual Node you are using? It will be node-red-contrib-xxxxx
There are 2 main Nodes for Telegram and they both work somewhat differently from each other.
I'm using node-red-contrib-telegrambot-home as can be seen below
What I'm trying to achieve is this.
But what I'm getting is this.
Is there a example of your array?
I'll be the first to admit, I'm in way over my head here. I've no idea if I'm even doing this the right way around.
Use a templete node set out like -
{{payload.0}}
{{payload.1}} {{payload.2}}
{{payload.3}}
Perfect thankyou, that's exactly what I needed.
