Array group by text based on certain character
I have been in a fight with an array which is similar to (original contains 5000+ elements):
    "Some Section  ⌄",
    "b",
    "c",
    "d",
    "e",
    "Some Other section  ⌄",
    "b",
    "c",
    "d",
    "x",
I want to produce an output that looks like:
		"section": "Some Section",
		"items":[
			"b",
    		"c",
    		"d",
    		"e"
		"section": "Some Other Section",
		"items":[
			"b",
    		"c",
    		"d",
    		"x"
So the "breaking point" or "grouping character" is the ⌄ symbol. I tried to capture the index into a new array and then loop from index to index -1 etc. Whatever I attempt, I fail, does anyone have a magic trick up their sleeve ? I can no longer see it properly :')
This may work then..
let input = [
    "Some Section  ⌄",
    "b",
    "c",
    "d",
    "e",
    "b",
    "c",
    "d",
    "x",
let output = []
let obj
input.forEach(item => {
    if (item.includes('⌄')){
        obj = {}
        obj.section = item.slice(0, -1).trim();
        obj.items = []
        output.push(obj)
    else{
        obj.items.push(item)
msg.payload = output
I swear that I had something similar, but it did not want to function like yours, thanks a lot! Can finally move forward.
Just as it isn't protected against possible variations in incoming data, be prepared for errors :smiley:
