Array.push is not a function
Hello, I want to ask about some function here's my code
function inject(joint, step, array) {
    if (joint != 0 && step >= 0) {
        array.push(joint);
        global.set("dummyArray", array);
        msg.payload = {
            "Inject To Array"   : joint,
            "Value In Array"    : dummyArray
    else if (joint == 0 && step == 299) {
        let summary = array.reduce((x, y) => {
            return x + y;
        var avg = summary / array.length;
        var min = array.min(...array);
        var max = array.max(...array);
Can you tell me what's wrong with my function, when I run in debug shows error : TypeError: array.push is not a function
The variable array is not an Array.
And you can use Array.isArray(array) to test that.
BTW, best not to use generic names like array in your code - it makes debugging really hard and can sometimes have unexpected results.
