Array to Json Object
Hi @jackie7
Sorry to nitpick but Json object is not a thing.
JSON is a string representation of a JavaScript object.
Ok, enough of that :slight_smile:
Use a function node, loop through the elements & add properties to an object...
  var arr = msg.payload; // get the array
  var rv = {};// create a new empty object
  for (var i = 0; i < arr.length; ++i) {
    let key = "Val"+(i+1); //built a key
    rv[key] = arr[i]; // set value in New object
  msg.payload = nv;
There are other, more modern/compact ways to achieve this but I kept it simple for clarity.
Disclaimer: the above code is untested/off the top of my head. :innocent:
